Intel® ARC™ Graphics
3359 Discussions
adaptive sync not using full range
Zano4455
I have a a770 connected to a LG monitor that has an adaptive sync range of 144hz to 48hz. When I run a game that goes under 60 fps the monitor goes into Low Framerate Compensation. This should only be happening when the framerate goes under 48 frames per second. I have verified this by comparing the fps reported in game to the refresh rate reported by the monitors OSD.
Earl_Intel
Hi Zano4455,
For us to further check on this, kindly provide us the needed information below:
  • What is the name of the game you're trying to play?
  • May I know if the game is working fine before?
  • What graphics driver are you using?
  • Have you tried rolling back your graphics drivers? if yes, may I know if the issue still persists?
  • What is the exact make and model of your monitor?
We will be able to move forward with the following step and try to address the problem you are having once we receive this information.
Earl E.
Zano4455
It is doing it in cyberpunk 2077 and shadow of the tomb raider. I get the full adaptive sync range on ratchet and clank.
I am using 32.0.101.6449.
It is a lg 27gl850.
edit: also ratchet and clank is very unstable with the latest drivers. it crashes randomly.
edit 2: the random crashes were caused by Steam.
Earl_Intel
Hi Zano4455,
Just wondering if you had a chance to look over the questions I posted. In order to decide on the appropriate course of action to address this issue, kindly inform me as soon as possible.
Earl E.
Earl_Intel
Hi Zano4455,
Thank you for sharing this information.
To further troubleshoot the issue, can you provide the additional questions listed below:
  • Have you tried using different GPU versions to check if the issue is also occurring on older drivers?
  • Can you provide us the game settings for Cyberpunk 2077 and Shadow if the Tomb Raider for us to try and replicate the issue on our end.
  • Have you check if your BIOS version is already up to date?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Earl_Intel
Hi Zano4455,
I was just curious whether you had a chance to review the questions I posted. Please let me know as soon as possible so that I can determine the best line of action to resolve this matter.
Earl E.
Earl_Intel
Hi Zano4455,
Earl E.
