Intel® ARC™ Graphics
3443 Discussions
arc 770 wot
arc770
merhaba sistemim ms ipro b 760 m-a wiife ddr5 anakart ddr5 goodram 16*2 32 gb cl 30
wiper ssd gen4*4 time tech sta ssd 1t b işlemcim i5 13400f erkan kartım arc770  wot oynadıktan sonra win tusuna basıp ana ekrana dönünce pixel pixel olmalar kırılmalar gerceklesiyor ama eski ekran kartım gtx 1050 ti taktıgımda sorun olmuyor 4k televizyonda bağlı awox 4k 30 hz son 24 ocaktaki güncellemeyi yukledim aldıgım yere geri iade ettim ancak bir sorun yok deyip geri gönderdiler bana telefondan yada dc den bağlanıp yardımcı olabilecek birilerine ihtiyacım var
ACarmona_Intel
Hello Arc770,
Thank you so much for posting in our Intel communities.
Lütfen sizi yalnızca İngilizce olarak destekleyebileceğimi unutmayın. Bu cevabı çevirmek için web çeviri araçlarını kullandım, bu yüzden yanlış bir çeviri olabilir.
We understand that you are having issues when playing WOT, as when pressing the win button, it returns to the main screen, and then pixels are breaking.
In order for me to isolate the issue and provide you with the best solution, please provide the following information:
  • When did the issue start?
  • Was the game working fine before?
  • Have you changed anything on the system that led to the issue?
  • Is World of Tank the only game that is having an issue?
  • Please provide the complete model and brand of your PSU.
  • Complete model and brand of your television:
  • What cable are you using?
  • Have you already enabled the resizable bar? If not, please enable the resolution, as it is important for the graphics performance.
  • I do not have sufficient details about your hardware and software configuration to help you. Please run the SSU report so I can check important details such as the OS build number, graphics driver version, errors logged in the system, etc.
  • If you have taken any steps to fix this issue before contacting us, please give me those details so we don't repeat any unnecessary steps.
Thank you, and have a great day ahead!
Carmona A.
ACarmona_Intel
Hello Arc770,
We are checking in with you on the Arc A770 issue we are having in case you have any additional queries or require further explanation. Please know that we would be happy to assist you if you have any.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello  Arc770,
We are checking in with you on the Arc A770 issue that we have, as we have not heard any response from you.
Carmona A.
ACarmona_Intel
Hello Arc770,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
