Intel® ARC™ Graphics
3371 Discussions
-bringing attention to texture bugging "fix"-
italian
latest drivers are installed and cleaned with DDU
Intel i5 13600kf
Asrock ARC A770 16GB
32GB DDR5
ASRock Z790 pro rs
  • I’ve been having issues with games crashing (especially when running over 60fps) and graphical glitches that started around 2 months ago. After trying to work with support from both intel and game devs, I’ve found what i think is the root of the issue.
  • A Highwire dev pointed out that every game that was having issues (Baldur's Gate 3, 6 Days in Falluja, Ready or Not, and Lethal Company) had Windows Error Reports containing a lot of "P1: 141" codes which is a main hardware fault.
  • My card (Asrock A770 16gb) is factory overclocked and would run at 2500Mhz; 500 over Intels’ spec. As I dropped the CPU Core Power Limit I watched the graphical glitches lessen with every few watts dropped until at 145W and 1800Mhz there were no graphical issues and the codes were gone.
  • I'm not sure if it's Asrock or intel drivers no longer working correctly with the overclock on this card. Either way I should not have to handicap my card for it to work properly.
  • Attached is a video
it starts at default settings (210W) - pause as I change settings- setting at 145W
Andres_Intel
Hello italian,
Thank you for posting on the Intel communities.
We appreciate the feedback and suggestions provided, it is very helpful and important for us to continue working on the solution of these issues.
If you need further assistance or recommendations related to the games you mentioned previously open a thread per issue and we will be glad to help you.
Let me know if you have further questions.
Andres P.
Andres_Intel
Hello italian,
I would like to know if you have further suggestions related to this thread topic or if you still need assistance.
Andres P.
Andres_Intel
Hello italian,
Andres P.
