Intel® ARC™ Graphics
3423 Discussions
bsod arc a750 counter strike 2
iov
I bought 3 bsods in 1.5 months I didn't care about the first 2 because my drivers weren't whql but now I'm using the latest whql driver but I only got a blue screen again in counter strike 2 or right after closing the game in this process I played games that require high system like silent hill remake ghost of tsushima but there was no problem in any of them
I use translation
16gb ram 3200mhz
bios latest version
i use ddu everytime for install driver
Mike_Intel
Hello iov,
  1. When did you purchase the Arc A750?
  2. Are you using an Intel brand Arc graphics?
  3. Was it working fine before?
  4. Just to clarify, you are only having issues with Counter Strike 2? No issues while playing the other titles that you mentioned?
  5. What are the troubleshooting steps that you tried so far?
Michael L.
iov
today i played cs2 for 2 hours i just hung out in one place but i didn't get bsod at the end of 2 hours i closed the game i played zzz and wuthering waves after i closed them i got bsod while hanging out on youtube i watched about 40 minutes of video
I have always monitored the temperature, it has never been above 70 degrees. I am sharing the minidumb file thanks
also pc stayed on for 4 hours
iov
1 year ago I bought arc a750 LE, a few months ago I got bsod once again but it didn't happen again and when I searched some forums it was because of antivirus programs, now I don't have any antivirus programs, the gpu was working without any problems, I only get bsod when playing cs2, I play ghost of tsusima elden ring sekiro wuthering waves and genshin impact, I don't get any bsod in them, but occasionally there is a problem of kicking out of the game, it doesn't give any error for example
Faulting application name: eldenring.exe, version: 2.2.0.0, timestamp: 0x6661ae30
Faulting module name: unknown, version: 0.0.0.0.0, timestamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x000000000000000000000000
Faulting process ID: 0x3E08
Application start time: 0x1DB549C9649C804
Faulting application path: E:\ELDEN RING\Game\eldenring.exe
Faulting module path: unknown
Report ID: 2cb73983-a062-4782-8c65-bea77e1b7de7
Faulting package full name:
Faulting package-relative application ID:
the problem solving steps I have tried so far
1) update driver to whql version (with ddu)
2) Windows Memory Diagnostic (no problems found)
3) updated the bios
4) I scanned the system with antivirus programs
5)activated secure boot
system temperatures are normal I get bsod 2-3 hours after playing cs2 and I don't have any problems before that
Thank you in advance
Mike_Intel
Hello iov,
Thank you for the update.
Based on you 2 post, I am also thinking that other components may cause the issue. You may also test them specially the RAM.
As for the Arc Graphics, let me gather more information.
  1. Can you share the specification of your power supply?
  2. Please help generate the SSU of your system. Please follow the steps in the link below:
Michael L.
iov
I already shared my system information with ssu system.txt in my first message
I tested my ram with windows memory identification and found no errors, if you want I can test it with memtest
my power supply fsp 650w 80 plus
Mike_Intel
Hello iov,
Upon reviewing the SSU logs, I found that your Graphics driver is not updated. You are using version 32.0.101.6325 and the latest that we have is version 32.0.101.6449.
Please update the driver using Clean driver installation method. Kindly follow the steps here:
You can download the version 32.0.101.6449 here:
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Michael L.
Mike_Intel
Hello iov,
Michael L.
iov
I could not test early because I had exams, I updated the driver, I played cs2 for a total of 6 hours for the last 2 days and I did not have any problems thank you for your interest in this process.
Mike_Intel
Hello iov,
Thank you for the update and I am glad that you are having no issues playing CS2 now.
Since the issue is now fixed, I need to close this inquiry.
Michael L.
