Hello AsterCrash,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Has the game (Unchartered 4) previously worked and only started getting crashes and performance issues lately?
2) If the answer above is yes, what were the changes you made prior to the issue?
3) Are there any other games or applications that crashes or with performance issues other than this game?
4) Describe the performance issue as best as you can. E.g. FPS drop when entering ‘x’ or ‘y’ section.
5) Provide screenshots or describe the graphics settings used in-game. E.g. Ultra quality preset, video resolution, ray-tracing on, etc. etc.
JeanetteC.
1. It was recently installed
3. and
4. It crashes when changing scenes
5. Ultra preset without ray tracing 1080p
Hello AsterCrash,,
Thank you for providing the requested information.
Please proceed with the following steps below:
1) Kindly update the BIOS firmware to the latest version (7D24v2K).
2) Make sure that the Resizable (Re-Size) BAR is enabled.
3) Try to reinstall the latest driver (32.0.101.8132) using the Display Driver Uninstaller (DDU) to Uninstall a Graphics Driver.
If the issue persists, please:
1) For performance issue, try if can submit CapFrameX capture data (.json files) reproducing the issue. *Capture data at least 3 times to define a good performance baseline.
2) For crashes kindly share your dump/log files.
Awaiting your response.
JeanetteC.
