I’m using the Intel Arc A770 16GB (3-fan version). When I set the fan to “advanced manual” mode and the PC wakes up from sleep, the fans stop working. After that, the GPU temperature keeps rising, and the system freezes. I’m using driver version 6790.
Is anyone else facing this issue? Is there any fix? Or is it a driver bug
Hi semmy,
- When did the issue start? Was it after a specific update?
- What are the troubleshooting steps that you tried so far?
- Is the Resizable Bar enabled?
- Have you used DDU to completely remove all residual drivers and installed a new one?
- Have you tried adjusting the graphics settings?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
Hi semmy,
Archie D.
Hi semmy,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Archie D.
