Intel® Arc™ Discrete Graphics
3644 Discussions
İntel Arc B580 Oyun performansı çok kötü
Atalay_
İntel Arc B580 ekran kartına sahibim. İ5 14400F ile darboğaz yaşamadan çalıştırıyorum. Minecrafta giriş yaptığımda 5-6 fps alıyorum. Gpu kullanımı %98 lerde geziyor ama fps değerleri çok düşük.
DhannielM_Intel
Hi Atalay_,
 Thank you for posting in the community. To further investigate this issue, please answer the following questions:
  1. Are you using a mod pack or playing vanilla Minecraft?
  2. Could you share your in-game settings?
  3. What is the current graphics driver installed on your system?
  4. Are there other games experiencing performance issues similar to Minecraft?
  5. Have you tested different graphics drivers for comparison?
  6. Have you used Display Driver Uninstaller (DDU) to completely remove the graphics driver and install a new one?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here.Help Guide for the Intel® System Support Utility
Dhanniel M.
DhannielM_Intel
Hi Atalay_,
I'm checking in to see if you've reviewed my previous message, which contains some important questions. Please respond at your earliest convenience so we can proceed with investigating the issue further.
Dhanniel M.
Atalay_
I would like to know that I solved the problem. I was using MSI Afterburn to see in -game FPS values. I started a test to see what my system will react under the implementation through the application. I think there was a problem with this. Now, when the application is not open, I can reach beautiful FPS values. Thanks for your time ..
DhannielM_Intel
Hi Atalay_,
I'm pleased to hear that your issue has been resolved. With that in mind, I will proceed to close this inquiry. If you require further assistance, please feel free to submit a new question, as this thread will no longer be monitored.
Dhanniel M.
