Intel® Arc™ Discrete Graphics
4038 Diskussionen
玩游戏森林之子2时,画面中地面区域出现白色透明
Snailrun1
Einsteiger
1.212Aufrufe
031aac6fa47ddf82bc8e636b1c05204.jpg8868f66e3e9abc795d1034f572c9bdb.jpgfec40676b32149dcf4e3aab329b8389.jpg
3 Antworten
VonM_Intel
1.142Aufrufe
Hi, Snailrun1.
请注意,我只能用英语为您提供支持。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译。
Thank you for posting in our Community. Based on the image you see, I see that you're experiencing a texture issue in Sons of the Forest 2 where the ground appears white and transparent. Have you tried adjusting the graphics settings in the game? If so, which settings have you changed? Are your graphics card drivers up to date? Have you tried using older versions of the drivers? Let's delve deeper and verify specifics such as the graphics models, precise driver versions, and any system errors. Using the Intel SSU tool will help us gather detailed information about your system setup, which could aid in identifying the underlying cause of this issue.
Furthermore, If you've conducted any other tests, please share the details so we can avoid repeating the same steps.
Have a nice day!
Von M.
VonM_Intel
1.125Aufrufe
Hello, Snailrun1.
Could you please confirm if you've reviewed the earlier post? Kindly let us know if you still need assistance.
Von M.
VonM_Intel
1.105Aufrufe
Hello, Snailrun1.
I have not heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
Antworten
