Intel® Arc™ Discrete Graphics
3679 Discussions
32.0.101.6557_101.6262The graphics card is not recognized when using the video program in this versi
가불기
When using the version driver, the graphics card is not recognized in video editing or encoding programs
What I checked was obs, Naver’s Prism Live (broadcast program)
Shortcut (open source video editing program)
For OBS and Prism Live, the option to use the graphics card in the output encoder is disabled.
OBS has only x264, and Prism Live has only three options: svt-av1, aom-av1, and x264.
(Attached file photo number 1)
In the case of shortcuts, coding is done using the CPU even if the qsv option is selected.
32.0.101.6460_101.6259 As for the version, it was not confirmed in the shortcut program, but it was confirmed to work properly in OBS Prism Live.
Sorry, I confirmed that the shortcut program is working properly.
I pressed the reframe option incorrectly, so only the CPU was working.
AND
2025-01-09  I inquired 듀얼 모니터 사용시 라이브 방송 버벅임(I tried to post a link, but it seemed to be treated as spam, so I deleted it.)
I am giving feedback because I have a solution to the problem I asked about previously.
The problem was resolved by changing the refresh rate of monitor 2 to 75 frames in the Intel Community Center (Beta) (photo 2 in attached file)
However, if it was not beta, there was no option to select 75 frames.
As far as I know, monitor number 2 was not originally a monitor that supported 75 frames.
I don't know why this phenomenon occurred, but in any case, the problem of live broadcasts and videos stuttering on the second monitor during gaming was resolved with this method.
Mike_Intel
Hello 가불기,
  1. Just to confirm, which program is now having issues?
  2. How did you update the driver?
  3. Can you still remember the driver version that worked before?
  4. Are you using an Intel brand Arc A750?
Michael L.
Mike_Intel
Hello 가불기,
Michael L.
Mike_Intel
Hello 가불기,
I am sending another follow up on the information that I requested.
Michael L.
