Intel® Arc™ Discrete Graphics
3498 Discussions
AOC G2590FX Variable Refresh Rate Has No Options To Select
Ian-P
I recently picked up my B580 and have been loving the performance gains, however I've noticed that I cannot enable Variable Refresh Rate for my monitor, the AOC G2590FX. When I pull up the intel Graphics Software, go to Display, and then scroll to the bottom under the "Global" accordion I see the option for Variable Refresh Rate Mode, but the drop down on the right has no options to choose from. I am currently on Driver version 32.0.101.6790.
I was using VRR for years on my GTX 1080 without issue, so I hope this can be addressed in a future driver update.
CaNeBuRy23
...some lower-quality cables may cause handshake or EDID read issues leading to missing features in the driver UI... Try to fully uninstall the existing Intel graphics driver using Display Driver Uninstaller (DDU) then reinstall the latest WHQL-certified driver from Intel’s Download Center rather than OEM-modified versions and try to confirm connection type make sure you are connected via DisplayPort (not HDMI), as HDMI VRR support is more limited on current Intel drivers.
Variable Refresh Rate (VRR) 'Not Supported' in Intel® Arc™ Control
...hope it helps
Ian-P
Thank you for the suggestions.
I do use a DisplayPort cable, the same one that supported VRR on my old card, so no dice on that front.
I've also used DDU to wipe all drivers from my PC and did a fresh install of the Intel drivers with no luck.
