Intel® Arc™ Discrete Graphics
3512 Discussions
ARC B580 doesnt boot when I restart my PC. Motherboard VGA Debug light On
Evilizer
I have a weird issue where if i restart my PC from windows, then it doesnt boot and the Motherboard debug VGA light lights up. I have to press the reset button in the casing and then can boot again.
Note that if i shutdown windows and then use the power button in my casing, it boots up normally.  Just when i click Restart on windows, it shutdowns and tries to boot but fails with VGA Debug light in MOBO.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
Gnep
my pc have same problem.CPU is i5 10400f and motherboard is MSI B460M.
