Intel® Arc™ Discrete Graphics
4039 Discussions
ARC b580/get freezing when play lostark
stopfreeze
While I play LOSTARK(DirectX 11), GPU usage is just 50~60% in 1920x1080, and suddenly it gets freeze. My screen get stop or trun into black, and GPU Usage goes 0%. I just update the latest graphic driver. Is there any solution to stop this problem? Here's my computer's part
CPU: AMD7 7700
Gpu: Arc b580 intel limited edtion
Ram: teamgroup 5600 cl 46
SSD: WD SN850X BLACK M2 NVMe SSD 1TB
motherborad: Asrock b650m pro rs
Mike_Intel
Hello stopfreeze,
  1. How long have you been using this Arc B580?
  2. Are you using an Intel brand Arc B580?
  3. Was it working fine before?
  4. Did you change any settings on your system before the issue started?
  5. What are the troubleshooting steps that you tried so far?
Michael L.
stopfreeze
Hi MIKE_intel
Sorry for late reply, I just checking my all computer's part.
1. I use my ARC B580 since 25/02/13
2. Yes I use ARC B580 intel edition
3. All game is ok but only LOSTARK got frozen
4. Yep.
5. I download window again, and re-download intel graphic driver, and also check my graphic card by store. But I got reply there is nothing problem with my graphic card
It got worse since I wrote the problem this community. Last time 2~3hours, now It frequently got frozen almost 1~2minute. I'm very sad the problem got happened.
Mike_Intel
Hello stopfreeze,
Michael L.
Mike_Intel
Hello stopfreeze,
Thank you for the update.
For me to further investigate this game issue, let me gather additional details:
  1. What is your game launcher?
  2. Can you share videos of the issue?
  3. Are you getting overheating issue? Can you provide screenshots of the temperature?
  4. Please help generate the SSU logs of your system. Please refer to the link below on how to generate the logs:
Michael L.
Mike_Intel
Hello stopfreeze,
I am just making a follow up on the information that I asked for further checking of this inquiry.
Michael L.
Mike_Intel
Hello stopfreeze,
I am sending another follow up on the information that I requested.
Michael L.
