Intel® Arc™ Discrete Graphics
4065 讨论
After update 101.4824 Intel Arc Control uses 9GB Memory/RAM
Noval
新手
76,936 次查看
This happened immediately when the laptop was just turned on and made my laptop temperature increase instantly
86 回复数
MasterNoMercy
初学者
20,804 次查看
I have to agree with you, i was using Arc for the first time trying to figure out why my GPU bottoms out and couldn't figure out why my PC kept crashing.  Figured out that Arc was using 100% of memory, then figured out that Arc keeps using memory till it crashes.  I wanted to capture the horror (i had to stop the capture before it crashed my PC wasn't sure the capture would save).  I will be uninstalling this program.
0 项奖励
MasterNoMercy
初学者
19,909 次查看
Update: After uninstalling the display driver, it reinstalled version 31.0.101.4502 which i believe is a roll back of the previous.  This seems to have resolved the memory issue for now.
0 项奖励
SaitamaOne
新分销商 I
20,542 次查看
0 项奖励
phoe
初学者
20,477 次查看
This situation brough me here lol
0 项奖励
Nazrex
新分销商 I
20,463 次查看
I'm still wondering why I'm NOT having this problem... and why the 4824 Driver and Arc Control Center works fine for me?
Maybe it has something to do with the Windows Version everyone is using?
I'm using Windows 10 Pro and I am NOT experiencing any memory leak issues at all.
0 项奖励
SaitamaOne
新分销商 I
20,301 次查看
It's weird hey? So many people with the same memory leak reported on here, Riddit, Github and videos on youtube... I am very jealous that you are not experiencing the same problem; Perhaps you can assist in showing us what we may being doing wrong, and what you have done right since it thankfully hasn't affected your PC, so that we can fix the issue instead of reporting it to, and bugging, Intel with the problem as they would definitely be too busy to help us?
0 项奖励
Stillwater
新手
20,358 次查看
I have the same issue. Arc Control continuously increases its memory usage until my memory is completely depleted. The driver version is 31.0.101.4284, and the Arc Control version is 1.73.5334.1. Here are my log files.
0 项奖励
JaimePF
初学者
20,323 次查看
The same is happening to me. This is very frustrating. I already followed the previous steps of uninstalling the drivers and reinstalling fresh, but I get the same result.
Here is the log file as requested and the information about the software version.Screenshot_drivers.png
0 项奖励
XImpalerX
新手
20,252 次查看
Here are my SSU logs as requested.
0 项奖励
Vampurrr
新手
20,241 次查看
Are people here using DDU as requested?
Uninstalling and reinstalling is not the same as using DDU.
Uninstalling still leaves remnants/rogue files and folders. DDU will get rid of them.
I was having issues with Arc Control, and my issues were fixed after using DDU.
0 项奖励
Nazrex
新分销商 I
20,214 次查看
Are people who are experiencing this problem, using an INTEL version of the GPU?
Or are they using an Acer, Asrock or some other third party manufacturer model?
Intel has often recommended on this forum that if you're using a third party version of the GPU... that you should NOT be using their reference driver/arc software; from their website... but instead that you should download the latest versions available from your GPU Manufacturer's website.
0 项奖励
XImpalerX
新手
20,197 次查看
All Intel Graphics are built-in to the Intel CPU's. You can't buy an Intel CPU that is created by Acer. You are confusing this with discrete graphics cards.
Actually I just found Intel Arc 7, so it looks like Intel now makes discrete cards, so I stand corrected.
0 项奖励
MichelN86
新分销商 I
19,930 次查看
@Nazrex, you do know when people who have msi or any other brand and install the intel arc drivers that it will auto update to the latest version from intel itself ?
0 项奖励
Nazrex
新分销商 I
20,209 次查看
So far...
I've looked at every SSU/IGCC report that has been posted on this thread.
The only common contributing factor that I've seen... so far... is those who are experiencing this issue, are running Windows 11.
While I am running Windows 10, and not experiencing this problem.
If more people who have this problem, could confirm whether they're running Windows 11... well, that alone could be valuable information for Intel to look at; and gives them a place to start looking for a fix.
0 项奖励
XImpalerX
新手
20,197 次查看
Yep, Windows 11 Pro
0 项奖励
Hugo_Intel
员工
20,147 次查看
Hello everyone, @Noval
We appreciate everyone's feedback on this issue. Following several user reports including the ones under this thread we have identified that whenever a Display Adapter other than Intel Display Adapters is installed in the system (e.g. Virtual Display adapters, a second Discrete Graphics card), the Arc Control software will start to incrementally consume RAM (memory leak).
We are at the moment investigating this issue as a top priority to come up with a resolution, in the meantime you can use the following workaround to use the latest driver with an older version of Arc Control:
  1. Uninstall driver 31.0.101.4824 using DDU
  2. Install driver 31.0.101.4676 which includes the previous version of Intel Arc Control (1.71).
  3. Perform a custom installation of driver 31.0.101.4824 unchecking the Arc Control installation option. This will keep the previous version (1.71) of Arc Control. (check attached screenshots)
Hugo O.
0 项奖励
Hugo_Intel
员工
20,136 次查看
We want to let you know we have just released a new driver version 31.0.101.4826 which includes a fix for this memory leak issue, please go ahead and check it out. If the issue still persists after a regular update, please use Display Driver Uninstaller.
Share with us your feedback and let us know if the issue gets resolved from your side.
Hugo O.
0 项奖励
LAOLIU818
新手
20,098 次查看
I have installed the latest version and it has not been repaired. There is still a memory leak.
0 项奖励
LAOLIU818
新手
20,094 次查看
new log file
0 项奖励
Stillwater
新手
20,091 次查看
I'm also experiencing the same issue. I've installed the latest driver, 31.0.101.4826, but the memory leak problem still persists. The Arc Control version remains the same at 1.73.5334.1.
0 项奖励
iQuan
新手
20,058 次查看
Very funny.
Fortunately, I didn't install it, because after reading the update info, they didn't say any about the issue of memory leakage.
回复
