Intel® Arc™ Discrete Graphics
3498 토론
Arc A770 Power consumption and clock frequency
Waldi
초급자
13,473 조회수
Hi Intel Team,
I am a new owner of the Arc A770.
So far everything works, but the idle power consumption of the GPU is around 42w.
All Bios changes done and also the energy settings in windows. But it changed nothing.
I also recognized that the GPU frequency never goes below 600MHz in idle. Is this normal?
Also the VRAM frequency is at 2186Mz and never below.
In another thread you said the fans start working above 56 degree. My fans never stop. In idle 49 C gpu temperature and 52 C VRam temperature.
Resolution is 4k and 60Hz, connected via HDMI
Any ideas? Or do I have to live with that
Waldi
0 포인트
8 응답
batkinson001
초급자
13,426 조회수
My a770 fans don't stop either, it's probably a software feature they still have to add.
0 포인트
Hugo_Intel
직원
13,396 조회수
Hello Waldi
Thank you for posting on Intel® ARC™ Graphics. I am sorry you are experiencing power consumption issues with your Intel® Arc™ A770 Graphics.
In order to configure the GPU for optimal power consumption, please configure your system and BIOS following the instruction in the following article:
High Power Consumption when Intel® Arc™ Graphics Card is Idle
Also, please make sure that you have installed the latest driver version 30.0.101.4148.
All the issues you mentioned should be correlated, so let us know how the system behaves once you complete the troubleshooting steps.
Hugo O.
0 포인트
PrzemekK
초급자
13,378 조회수
Hello Hugo,
same here,
- driver 4148
- bios changes accepted (power draw 15W)
- temp idle 47C
Fans still spining
Przemek
0 포인트
Waldi
초급자
13,331 조회수
Hello Hugo,
like I wrote in my first post ASPM settings are done in BIOS and also energy settings in windows.
I reinstalled Windows 11 completely, newest Arc Control beta is also installed.
Nothing changed. Still 40W power consumption. Also around 50C temperature in idle and the fans spinning all the time.
Waldi
0 포인트
Hugo_Intel
직원
13,306 조회수
Hello Waldi
Thank you for the information. In this case, since the previous troubleshooting did not make any effect on your system, we will need some more information to research the issue that you are experiencing. Please let us know the following:
1.-Did you overclock the GPU or made any changes to the performance tab on Intel® Arc™ Control? If yes, please reset the settings to default.
2.-Share with us a short video of the issue, showing the telemetry information from ALT+I or ALT+O.
3.-Create a log file with the Intel® System Support Utility and attach it to your reply. 4.-Create a System report following these instructions. Only use the instruction under Intel Graphics Command Center (Intel GCC):
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html
Hugo O.
0 포인트
Waldi
초급자
13,265 조회수
Hello Hugo,
For now we can close this case.
I just got the information from ASRock that the ASPM settings in the BIOS are not working properly and that they are working on an update.
I will post here if the problem still exists then.
Waldi
0 포인트
Hugo_Intel
직원
13,233 조회수
Hello Waldi
Thank you for letting us know. In this case, if the issue persists after Asrock fixes the issues with ASPM in their BIOS, do not hesitate in contacting us back, however, please open a new thread and reference this one since this thread will no longer be monitored. We appreciate the information and feedback you have provided.
Hugo O.
0 포인트
JakeTaco
초급자
12,800 조회수
Mine is the same. Did the bios change and nothing. Power draw is all over the place and over 40w at 3% utilization and idling close to 50c. From everything I've read, the bios fix only works on a750 and not the a770. Mine is the 16gb LE.
0 포인트
응답
