Intel® Arc™ Discrete Graphics
4047 Discussions
Arc GPU not appearing in Windows graphics settings (Two GPUs)
riskofrainenjoyer
Hi! I am running a Intel ARC A380 and a Nvidia RTX 3070. I have the RTX 3070 in the first x16 slot on my motherboard, and the ARC gpu in the one below it. I am attempting to assign OBS to run on the ARC gpu, but in windows power management settings, ARC does not appear as a low power option to assign the program to. See picture attached. The arc gpu appeared properly when the nvidia gpu was disabled, but only then. I know ARC is supported, because when the NVIDIA gpu was disabled, it booted and defaulted to that GPU without issue. I am on the current windows 10 installation build 19044.2728. Please let me know if you have more questions/information. Just looking to use this gpu as a video encode and video processing gpu when doing those workloads. Thanks!
Jean_Intel
Hello riskofrainenjoyer,
Thank you for posting on the Intel️® communities. We understand that you are experiencing issues when playing Call of Duty: Modern Warfare II.
To have a better understanding of your issue, please provide me with the following:
  • Share with us a screenshot when your  Intel ARC A380 is being detected by the windows power management settings.
  • We would like to gather more information about your system that will help us troubleshoot your issue, so please, provide us with a report using the Intel System Support Utility (Intel SSU):
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
Jean O.
Jean_Intel
We hope you are doing fine.
Jean O.
riskofrainenjoyer
Hi! I'm very sorry for the late response. If I don't receive a response through this thread, I will post the same question but monitor it more closely. My apologies. Here is the SSU scan, and I will also attach a screenshot of when I am able to get the ARC gpu to appear, by disabling the RTX 3070 in device manager. I will also attach the SSU log when that is done.
Jean_Intel
Best regards.
Jean O.
