Intel® Arc™ Discrete Graphics
3561 Discussions
Arc a750 video card power consumption
Umake
The Gunnir arc a750 video card consumes 40W in stock (without load). All conditions were met from the official website (https://www.intel.com/content/www/us/en/support/articles/000092564/graphics.html). How can this be fixed?
Mike_Intel
Hello Umake,
  1. Let me check the, the issue that you are asking is why the Arc graphics is consuming 40w without any load?
  2. When did you purchase the unit?
  3. Was it working fine before?
  4. Did you change any settings on this card?
  5. Can you share the screenshot of the card consuming 40w?
  6. Also, can you share screenshot of the task manager for me to check all the running applications.
Michael L.
Umake
Yes, I don't like that the graphics card consumes 40W at stock.
I bought the graphics card last year.
No, this problem was there from the very beginning.
No, I didn't change anything.
Viom
Mike_Intel
Hello Umake,
Thank you for the update.
Can you check this link and tell me if this guide will lower the idle power.
Michael L.
Umake
I did all the actions indicated in the link, but the power consumption is still not lower than 40W.
Mike_Intel
Hello Umake,
Michael L.
Mike_Intel
Hello Umake,
Have you tried updating the driver of the arc Graphics? If yes, please help generate the SSU logs of your system for me to further check.
Please follow the steps below:
Michael L.
Umake
Mike_Intel
Hello Umake,
Thank you for providing the SSU.
Upon initial review of the SSU, I found out that the Graphics driver is not update.
Please try to update the graphics driver and if it is still the same, please help generate a new set of SSU showing the latest driver.
You can download the driver here:
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Michael L.
GTX
Hi. I know why.
If you generate a report using the powercfg -energy command, you will see this message:
Platform Power Management Capabilities:PCI Express Active-State Power Management (ASPM) Disabled
PCI Express Active-State Power Management (ASPM) has been disabled due to a known incompatibility with the hardware in this computer.
This means that ASPM is currently not working properly.
Is there a solution? No. Sometimes it fixes and sometimes it doesn't.
If you turn Native ASPM and L1 ON and OFF dozens of times in BIOS, turn Link Power ON and OFF dozens of times in Windows Power Options, do several Windows updates, and reinstall the drivers dozens of times, ASPM L1 will eventually work normally. Sometimes it won't work.
I successfully enabled ASPM in W11 23H2 with the above method, but after updating to 24H2, I'm having the same problem again. But this is not a Windows 24H2 problem.
This is the only way I've found to fix ASPM.
Umake
Mike_Intel
Hello Umake,
Just checking if you still have clarifications after another forum user posted a reply.
Michael L.
Mike_Intel
Hello Umake,
Michael L.
Mike_Intel
Hello Umake,
I am sending another follow up to check if you tried our recommendations.
Michael L.
