Intel® Arc™ Discrete Graphics
3646 Discussions
B570 - Path of Exile 1 unplayable using Vulkan, DX 12 and 11 suer bad performance
RiL83
Opening my own thread since a moderator suggested I do so.
So for path of exile 1 there is only one way to play the game and that is by using Vulkan, but all drivers i have tried lead to instant crashes (meaning game just dies and there is no error report).
I have used DDU to remove old drivers and also when trying out different versions, no version Vulkan remains stable over 5 min, seams when drivers are freshly installed the game runs on Vulkan for about 5-10 min with nice FPS with good settings, even when playing in juiced maps with friends. But after the "first crash" it is like the Vulkan library is forever corrupted and then you can barley load the game before it crashes again.
I have included some reports here from event viewer and can produce more information or other testes if needed, main goal is to get Vulkan to work here.
EventData
AppName PathOfExile.exe
AppVersion 0.0.0.0
AppTimeStamp 69098694
ModuleName igc64.dll
ModuleVersion 32.0.101.6733
ModuleTimeStamp 67ed77d9
ExceptionCode c0000005
FaultingOffset 00000000011ebdbb
ProcessId 0x4dd0
ProcessCreationTime 0x1dc4e33fdd4e550
AppPath C:\Program Files (x86)\Grinding Gear Games\Path of Exile\PathOfExile.exe
ModulePath C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_9633261779bf071d\igc64.dll
IntegratorReportId 736de448-49ad-4764-8211-fda3d82c7746
PackageFullName
PackageRelativeAppId
AppVersion 0.0.0.0
ModuleVersion 32.0.101.8247
ModuleTimeStamp 68f8b8ae
FaultingOffset 000000000129643b
ProcessId 0x2d00
ProcessCreationTime 0x1dc4e363c0416f0
ModulePath C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_c9d58d8afce303a5\igc64.dll
IntegratorReportId 4bde9c63-4ec3-41c9-9408-101fe476a791
PackageFullName
EventData
AppVersion 0.0.0.0
ProcessId 0x26a8
ProcessCreationTime 0x1dc4e36ac4b0bd4
IntegratorReportId 8ba92efa-16ce-4420-a8a9-56ab664a3eb9
PackageFullName
EventData
AppVersion 0.0.0.0
AppTimeStamp 691530b7
ModuleVersion 32.0.101.8250
ModuleTimeStamp 690e3b93
FaultingOffset 00000000012963fb
ProcessId 0xd9c
ProcessCreationTime 0x1dc57321d205057
ModulePath C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_04d65f21e92ccd2d\igc64.dll
IntegratorReportId 17fd7310-d71a-4b0c-9f2c-a24d622db37c
PackageFullName
EventData
AppVersion 0.0.0.0
ModuleVersion 32.0.101.6647
ModuleTimeStamp 67c1f47d
FaultingOffset 00000000011d882b
ProcessId 0x3c90
ProcessCreationTime 0x1dc573607294266
ModulePath C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_eeea066e03c15baf\igc64.dll
IntegratorReportId 496848d1-472d-4cbb-842e-acb04bfa0e76
PackageFullName
JeanetteC_Intel
Hello RiL83,
Thank you for opening your own thread and providing details about the Vulkan crashes in Path of Exile.
To properly investigate this issue, I need the following:
  1. SSU (System Support Utility) log file - for system configuration analysis
  2. Crash/dump files - any available crash dumps or error logs
  3. Driver versions list - all Intel graphics driver versions you've tested with DDU
The pattern you describe suggests a specific system configuration issue that we can identify with proper diagnostic data.
Once I review this information, I can provide targeted troubleshooting steps.
JeanetteC.
RiL83
Hi Jeanette
I am fairly sure that I used DDU for all the listed drivers in my original post, I know with 100% that it was used to try 6647, 6733 and today 8250.
No dump files where generated since windows do not crash, I did however use NotMyFault to generate a dump file after latest crash, event error is attached, if you want the dump file kindly inform me how/where I upload this one (16GB).
I highly doubt this has anything to do with my configuration since there are multiple threads for the same issue on this game, as well as for Path of Exile 2. There are threads here on intel support page as well as on PoE, all have same story that DX 12 performance is so bad its not playable (other thread on Intel has links to youtube clips) and that for Vulcan it works nice for 1-few mins then the game just closes with no error msgs or anything.
JeanetteC_Intel
Hello RiL83,
Thank you for the detailed information and confirming your DDU usage with the driver versions.
Given the pattern you've described and the broader scope of this issue, I'll proceed with further internal investigation on our end. I'll keep you updated as our internal review progresses.
JeanetteC.
JeanetteC_Intel
Hello RiL83,
I wanted to update you that I am actively investigating this issue internally, and your assistance in providing an SSU log file would be invaluable to our analysis.
Given that this appears to be a widespread compatibility concern, we're systematically collecting SSU logs from affected systems to identify recurring patterns across hardware configurations, driver versions, and system settings. Your system data could provide the critical insight needed to isolate the root cause.
How your SSU log would contribute:
  • Enable comparison of your configuration with other affected systems
  • Help identify driver or firmware inconsistencies across cases
  • Reveal specific hardware combinations that may be triggering this issue
If you prefer to share the log file confidentially, I can arrange for private communication via email. Please let me know your preference, and I'll send you the appropriate instructions.
JeanetteC.
JeanetteC_Intel
Hello RiL83,
Were you able to review my last message?
I'll email you privately for the additional information needed. Please check your inbox and spam folder for my message.
JeanetteC.
Rainout
Its happening to everyone who owns a battlemage gpu, here are all the posts about in the forums:
https://www.pathofexile.com/forum/view-thread/3872651/
https://www.pathofexile.com/forum/view-thread/3871418
https://www.pathofexile.com/forum/view-thread/3874403
https://www.pathofexile.com/forum/view-thread/3872532
https://www.pathofexile.com/forum/view-thread/3871832
So its a common problem, its playable on dx12 but the performance is terrible compared to previous patch in vulkan.
JeanetteC_Intel
Hello Rainout,
I understand you and other Battlemage GPU owners are experiencing these performance issues based on the links you shared. To provide you with dedicated support and track our investigation properly, please create a new thread specifically for your system.
This will help us:
  • Focus on your specific hardware and logs
  • Provide personalized troubleshooting
  • Track your case without interference
  • Give you direct updates
This approach ensures better assistance while supporting our broader Battlemage investigation.
Thank you for your cooperation.
JeanetteC.
Ernesto_C_Intel1
Hi @RiL83,
I am reaching out on behalf of our technical team regarding the Vulkan crashes you reported in Path of Exile. I am currently working to reproduce these errors and will provide an update as soon as possible."
Ernesto C.
