Every time I updating the driver the graphic card will lost signal output. It can be recovered after reboot the system. I connect monitor with hdmi cable. It's there any solution to solve this problem? Thanks very much.
spec:
CPU: I5-12490F
GPU: MAXSUN ARC B580 MILESTONE
MB:MAXSUN B760M GAMING WIFI D4
RAM:16GB 3200MT/S
MONITOR:MSI PRO MP243
SYSTEM:WINDOWS11 23H2 22631.4751
链接已复制
Hello RyanL125,
- When did you purchase the unit?
- How did you update the driver?
- What are the troubleshooting steps that you tried so far?
Michael L.
hello Mike,
I built system on Dec.20th last year. I upgrade the driver by download directly. The Intel Graphic Software is too slow to download in China. So when new driver published, I just download .exe program directly and install it. Every time I updating the driver the graphic card will lost signal output., but it can be recovered after reboot the system.
Hello RyanL125,
Thank you for the update.
Let me ask more details about this issue.
- Can you provide the specification of your power supply?
- Just to get the exact issue, there will be no display once the system enters the OS or no POST at all?
- Can you share the driver link that you installed?
Michael L.
Hello RyanL125,
I am sending another follow up on the information that I requested.
Michael L.
