Intel® Arc™ Discrete Graphics
4064 Discussions
BSOD INTEL ARC A770
NtGreat
My pc just crashed an it popped up this code igdkmdn64.sys. not sure what this means
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If you find any Intel driver you might need, download and save it now.]
DeancR_Intel
Hi NtGreat,
Dean R.
DeancR_Intel
Hi NtGreat,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
