Intel® Arc™ Discrete Graphics
4070 讨论
Could not open any old game.
Hoshino
初学者
5,698 次查看
When I was using the A750 graphics card, I tried to open some old games (see the attached picture for details). When they were opened, they first had a white screen and then crashed (see the video). However, if I started some DX11 and 12 games, they could run normally (such as Hatsuyuki Sakura and Wuthering Waves). I have installed the official version of the driver, and most of the runtime can be installed, and tried to run in compatibility mode, but it didn't work. (There are two other games. Left 4 Dead 2 runs normally after adding "vulkan" to the startup options. Nekopara runs normally after using Windows 8 mode, but the above method does not work for the remaining two games.) I am almost going crazy. .
我在用A750显卡的时候,我试图开一些老游戏(具体见附件图),它们一打开先是白屏后是闪退(见视频)
但如果启动一些dx11和12的游戏,他们就能正常运行(如初雪樱,鸣潮)
我已经安装了官方正式版驱动了,大部分运行时能装的都装了,并尝试用兼容式模式运行,但不起作用
(还有两个游戏
求生之路2在给启动选项添加“vulkan”后正常运行
Nekopara用Windows8模式后正常运行,但上述方法对剩下两个游戏无效)
我快被折腾疯了。。
标签 (3)
0 项奖励
6 回复数
Mike_Intel
主持人
5,612 次查看
Hello Hoshino,
  1. What are the game launcher of the affected games?
  2. When did you purchased your Arc A750?
  3. Was it working fine before?
  4. Have you also tried updating the BIOS of your motherboard?
Michael L.
0 项奖励
Hoshino
初学者
5,493 次查看
steam;
three months before;
not sure in this pc;
yes
I think it's a problem with Steam (especially vac), because I can run the same game normally when I use other (offical) launchers
0 项奖励
Mike_Intel
主持人
5,562 次查看
Hello Hoshino,
Michael L.
0 项奖励
bobbycold_h
新分销商 I
5,544 次查看
Hi Hoshino,
there can sometimes be issues with games using DX10 or lower due to the Alchemist cards only natively supporting DX11 & 12. I've had a similar issue with Splinter Cell: Conviction before, which using ForceD3D9on12 fixed - maybe you'd like to give that a try?
You just have to open the game folders (navigate to them or while in Steam right-click on the game, "Manage", "Browse local files") and drop the files from the ForceD3D9on12 .zip file to the folder where the game executable resides.
You can download that from here: https://github.com/narzoul/ForceD3D9On12/releases/download/v1.0.0/ForceD3D9On12-v1.0.0.zip These files just enforce using the ForceD3D9on12 compatibility layer which is already included with Windows 10 and 11.
Please try it out if you're able to and reply if problems persist.
Robert W. (bobbycold_h)
0 项奖励
Hoshino
初学者
5,493 次查看
thanks for help,But i think it's probably the problems of steam(maybe vac),Because when i try to open the same game at another offical launcher and it works well.
0 项奖励
bobbycold_h
新分销商 I
5,438 次查看
That definitely seems likely then, or if the affected games aren't online multiplayer ones it might also be an issue with the SteamWorks (= Steam DRM system) integration. Verifiyng the game files in Steam might fix those issues.
0 项奖励
回复
