Intel® Arc™ Discrete Graphics
4043 Discussions
Crash between game, game overlay, mouse cursor overlay and Intel graphics drivers
fgdfgdfgdfgds
Débutant
17 683 Visites
A rather niche crash involving the interaction between Intel graphics drivers for Arc B580, the game Guild Wars 2, the add-on "ArcDPS", and any mouse overlay (for better cursor visibility):
Part 1: My Troubleshooting So Far
Certainly. Based on our extensive troubleshooting and the information you provided, I have compiled all relevant error reports and crash logs that will be of interest to Intel driver developers (responsible for the Arc B580).
This data consistently points to an interaction between the Intel Arc B580 GPU/drivers, the DirectX 11 stack, ArcDPS (which uses ImGui), and any form of mouse cursor modification.
Summary of Relevant Error Reports and Crash Logs
1. System Information (DxDiag)
  • Relevance: Provides a complete overview of the hardware and software environment where the crashes occur.
  • Key Points for Intel:
    • Graphics Card: Intel(R) Arc(TM) B580 Graphics (Intel Corporation, Device ID: 0xE20B)
    • Driver Version: 32.0.101.6913 (English), Driver Date/Size: 21/06/2025 (latest update)
    • Driver Model: WDDM 2.7
    • Hardware Scheduling: Supported:False Enabled:False Block List: DISABLE_HWSCH (May indicate specific driver configurations).
    • Operating System: Windows 10 IoT Enterprise LTSC 64-bit (10.0, Build 19044) – While not standard, it shouldn't rule out driver compatibility issues.
    • Processor: AMD Ryzen 5 7500F 6-Core Processor
    • Presence of amd_ags_x64.dll: (Seen in WinDbg trace, though not directly a cause of error, could suggest a mixed environment).
2. WinDbg Crash Dump Analysis (Most Important Evidence for Intel)
This log is the most detailed and shows the error directly in the Windows DirectX 11 library, which is a strong lead pointing to the Intel driver.
  • Problem Constellation: Occurred with ArcDPS, Blish HUD, in-game mouse pointer visibility enhancement (identical to crashes with Blish HUD Mouse Overlay Plugin).
  • Core Information:
    • Exception Code: e06d7363 (C++ EH exception)
    • Exception Address: 00007ff87171af29 (within KERNELBASE!RaiseException)
    • Faulting Module: d3d11.dll (The Windows DirectX 11 runtime library)
    • Call Stack (most relevant parts):
      • KERNELBASE!RaiseException+0x69
      • d3d11!D3D11CoreRegisterLayers+0x21f59f
      • Further calls within d3d11.dll and then in Gw2-64.exe.
    • Relevance for Intel: The crash in an internal d3d11.dll function like D3D11CoreRegisterLayers strongly suggests that the Intel Arc driver doesn't react as expected to a d3d11.dll call or state (initiated by ArcDPS), causing d3d11.dll to trigger an internal C++ exception. This is a direct interface problem between the Windows DX11 stack and the Intel driver.
3. Event Viewer Error Messages (Consistent Patterns)
These error messages show the consistent patterns of crashes in various configurations.
  • Error Pattern 1 (Frequent, with Cursor Modification):
    • Faulting application name: Gw2-64.exe
    • Faulting module name: ArcDPS.dll
    • Exception code: 0xc0000005 (Access Violation)
    • Configurations where this error occurred:
      • ArcDPS, Blish HUD, Blish HUD Mouse Overlay Plugin.
      • ArcDPS, Blish HUD, in-game mouse pointer visibility enhancement.
      • ArcDPS, Nexus, in-game mouse pointer visibility enhancement (most recently reproduced crash).
    • Relevance: This is the core problem. Although WinDbg showed d3d11.dll as the Faulting Module, Event Viewer and ArcDPS logs often point to ArcDPS.dll itself. This is likely a consequence of d3d11.dll instability affecting ArcDPS. The 0xc0000005 is a very generic error, but highly specific in this context.
  • Error Pattern 2 (With Old YoloMouse Version):
    • Faulting module name: Yolo64.dll_unloaded
    • Configuration: ArcDPS, YoloMouse 0.11.3 (often visible as "Yolo64.dll_unloaded").
    • Relevance: Shows that the old YoloMouse version itself caused massive incompatibility issues, which might also be related to the Intel driver. The fact that the problem also occurs with the in-game mouse pointer option, which doesn't inject external DLLs, makes this point less central for the latest insights into the fundamental incompatibility with ArcDPS and any cursor modification on Intel Arc.
  • Error Pattern 3 (Heap Corruption, less frequent but relevant):
    • Faulting module name: C:\windows\SYSTEM32\ntdll.dll
    • Exception code: 0xc0000374 (Heap Corruption)
    • Configuration: General with ArcDPS and/or YoloMouse.
    • Relevance: Heap corruptions are often a secondary error of access violations or improper memory management caused by injectors interacting with the driver. It's a deeper memory problem that could stem from the same root cause.
Summary Problem Description for Intel
Intel Arc driver developers should be aware of the following key points:
  • Problem: System crashes of Guild Wars 2 (Gw2-64.exe) with Exception code: 0xc0000005 (Access Violation) and e06d7363 (C++ EH exception), where the faulting module is often ArcDPS.dll or directly the Windows d3d11.dll. Less frequently, ntdll.dll (Heap Corruption) crashes also occur.
  • Reproducibility: These crashes consistently occur whenever ArcDPS (which uses ImGui for its UI) is active simultaneously with ANY form of mouse pointer modification (be it the in-game mouse pointer option, YoloMouse, or a Blish HUD mouse overlay plugin).
  • Hardware Specifics: The problem is specific to the Intel Arc B580 Graphics GPU. It occurred after switching from an NVIDIA GTX 980 Ti to Intel Arc, and it happens on a system with an AMD Ryzen 5 7500F Processor and Windows 10 IoT Enterprise LTSC.
  • Depth of Error: WinDbg analyses show errors in d3d11.dll (e.g., in d3d11!D3D11CoreRegisterLayers), indicating a fundamental incompatibility or an error in the interaction between the Windows DX11 stack and the Intel Arc driver when complex rendering and hooking operations (by ArcDPS and cursor modification) occur simultaneously. ArcDPS's ImGui rendering is a relevant factor here.
  • Multi-Monitor Setup: Operating three monitors with different resolutions (2560x1440 and 2x 1920x1080) might exacerbate the instability, but it's not the sole cause (as it also crashed with the in-game option). The latest tests with YoloMouse 0.11.3 on a single monitor will provide more clarity on this.
What You Should Send to Intel
When you submit this information to Intel, you should include the following:
  1. A concise description of the problem: "Guild Wars 2 crashes with ArcDPS whenever a mouse pointer modification is active, specifically on Intel Arc B580."
  2. Your complete DxDiag report.
  3. The complete WinDbg output of the !analyze -v command that you provided. This is the most important and technical piece of evidence.
  4. The Event Viewer crash logs for the various configurations (which you provided throughout our conversation) to show the consistency of the error pattern.
  5. The reference to ArcDPS as an ImGui user, as this is a likely lead.
This comprehensive collection of data will provide Intel developers with the best possible basis to investigate this specific compatibility issue.
Part 2: The System Diagnostic Report
Report Date: Tuesday, 08 July 2025
Report Time [hh:mm:ss]: 02:51:17 PM
Operating System: Microsoft Windows 10 IoT Enterprise LTSC 10.0.19044
IGCC Version: 1.100.5688.0
Language: en-GB
Physical Memory: 31.59 GB
Current Resolution: 2560x1440
Processor Speed: 3701 MHz
GFX Driver Name: Intel® Arc(TM) B580 Graphics
Shader Version: 5.1
OpenCL* Version: 3.0
  • Microsoft DirectX* *
    Runtime Version: 12
    Hardware-Supported Version: 12
    Vendor ID: 8086
    Device ID: E20B
    Device Revision: 00
    GFX Driver Version: 32.0.101.6913
    Dedicated RAM: 12 GB
    Shared RAM: 16 GB
    Max Supported Displays: 4
    GFX Vulcan: 1.4.315
    Option ROM (OpROM) Version: 23.0.1051.0
  • Devices connected to the Graphics Accelerator *
Active Displays: 3
  • Digital Display 1 *
Display Name: DELL S3222DGM
Display Type: Digital
Serial Number: HZ340M3
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Maximum Image Size
Horizontal - 27.56 inches
Vertical - 15.75 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1280 x 1024 (60p Hz)
1280 x 1024 (75p Hz)
1600 x 900 (60p Hz)
1600 x 1200 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (120p Hz)
1920 x 1080 (144p Hz)
1920 x 1080 (165p Hz)
1920 x 1200 (60p Hz)
2560 x 1440 (60p Hz)
2560 x 1440 (120p Hz)
2560 x 1440 (144p Hz)
2560 x 1440 (165p Hz)
Power Management Support
Standby Mode Supported
Suspend Mode Supported
Active Off Mode Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC 0F D1 56 4B 33 30
2B 22 01 04 A5 46 28 78 FB 21 76 A9 53 44 94 23
1C 4D 5A A5 4B 00 A9 C0 B3 00 D1 00 71 4F A9 40
81 80 D1 C0 01 01 56 5E 00 A0 A0 A0 29 50 30 20
35 00 B9 88 21 00 00 1A 00 00 00 FF 00
0 Compliments
11 Réponses
JedG_Intel
Modérateur
17 580 Visites
Hello fgdfgdfgdfgds,
I appreciate your effort ion providing a detailed description of the issue. To address this issue properly, kindly share the information below.
1. Is the issue isolated to Guild Wars 2?
2. Is the game working without ArcDPS?
3. Where are you seeing the error message?
4. Kindly share the download link to the game.
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
0 Compliments
JedG_Intel
Modérateur
17 502 Visites
Jed G.
0 Compliments
fgdfgdfgdfgds
Débutant
17 090 Visites
Huh, pretty sure I specifically subscribed to my thread so I would get notified. But I wasn't notified about your first message, yet I did receive a notification for your second. But are shown as not subscribed.
Odd.
Anyway.
Apologies for the lack of reaction, here are your answers and additional infos I managed to get in the meantime:
Seemingly, yes.
Yes.
Event Viewer, mostly, but also DxDiag or crash- and error logs of the game and add-on.
https://account.arena.net/content/download/gw2/win/64
New information:
In the meantime I managed to further zero in on the cause. My initial assumption that Mouse Overlays cause the crash has been proven wrong. I have been able to play with the initially suspected overlay for days without issue. What has actually been causing the crashes are the hardware monitor programs I used to search for the issue, turning the entire attempt at troubleshooting into a Benny Hill Show of a cat chasing its own tail.
Current analysis:
Stable set-up: Guilds Wars 2, Raidcore Nexus, ArcDPS, YoloMouse, 3 Monitors with 1 monitor having a higher resolution.
Crashes when introducing: Device Manager, Performance Tab of the Task Manager, the trio of CPU-Z, GPU-Z, SpeedFan.
Odd outlier: crashed when introduced Libre Calc & Edge. Gotta check on that more later.
NOT crashing: adding HWiNFO64 to the stable set-up.
NOT crashing: adding following PowerShell command to the set-up: while ($true) { Get-CimInstance -ClassName Win32_VideoController | Select-Object Name, DriverVersion, AdapterRAM, VideoProcessor; Start-Sleep -Seconds 5 }
Crash-pattern: game sputters for 0,5-1 seconds, then freezes for 0-2 seconds, and then closes itself in 99% of all cases and stays frozen in 1%. Interestingly, this pattern also occurs during a stable set-up, but does not end with the game crashing. So maybe something about those hardware monitors is interfering with something that is re-stabilizing the game.
There might be a clue in the Event Viewer, more details on that at the end of this message.*
Current plan:
Testing current stable set-up specifically with ONLY Performance Tab added. Then repeating with SpeedFan, CPU-Z, GPU-Z, etc.
Each test takes 2-3 days because of the the unpredictable nature of the crashes. Sometimes right after two minutes, sometimes an entire day nothing and five crashes on the second. Basically I have to repeat the entire battery of tests while being very aware of what hardware monitors and background programs are running on the side.
Stable programs in the background and on the side so far: Discord, Steam, Thunderbird, Firebird with its 87 tabs, Youtube streaming music non-stop, Signal (the messenger).
* Event Viewer shows the usual Windows noise after boot-up, but has an interesting couple of entries that also point to the graphics drivers as seen in the screenshot.
Event ID 3 is ALWAYS
Session "Intel-Gfx-Driver" stopped due to the following error: 0xC000003A
Event ID 1 is ALWAYS
The backing-file for the real-time session "WDC.BE95A9B1-DE15-4B78-B923-A12AB70BE951" has reached its maximum size. As a result, new events will not be logged to this session until space becomes available. This error is often caused by starting a trace session in real-time mode without having any real-time consumers.
Event ID 2 is ALWAYS
Session "PerfDiag Logger" failed to start with the following error: 0xC0000035
For the sake of completeness, here the "noise":
The Network List Manager reports no connectivity to the internet.
A connection to the Windows Update service could not be established.
Metadata staging failed, result=0x80070490 for container '{FA095ECC-E13E-40E7-8E6C-1CED6F5B626C}'
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}
and APPID
{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}
to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
and APPID
Windows Hello for Business provisioning will not be launched.
Device is AAD joined ( AADJ or DJ++ Not Tested
User has logged on with AAD credentials: No
Windows Hello for Business policy is enabled: Not Tested
Windows Hello for Business post-logon provisioning is enabled: Not Tested
Local computer meets Windows hello for business hardware requirements: Not Tested
User is not connected to the machine via Remote Desktop: Yes
User certificate for on premise auth policy is enabled: Not Tested
Machine is governed by none policy.
Cloud trust for on premise auth policy is enabled: Not Tested
User account has Cloud TGT: Not Tested
See https://go.microsoft.com/fwlink/?linkid=832647 for more details.
Metadata staging failed, result=0x80070490 for container '{0A568158-2954-F19C-89F3-03ACAEE1F85E}'
Metadata staging failed, result=0x80070490 for container '{D397268A-724C-B4EF-D641-C9234BA2948B}'
Metadata staging failed, result=0x80070490 for container '{CA0E9E80-3E97-FCAC-730A-8CB080FA2581}'
Metadata staging failed, result=0x80070490 for container '{05BEA633-466C-11F0-8AB1-C8A3E8C11BD2}'
{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}
and APPID
{15C20B67-12E7-4BB6-92BB-7AFF07997402}
to the user DESKTOP\Dirili SID (S-1-5-21-588804776-4000661037-1743724292-1000) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
Windows.SecurityCenter.WscBrokerManager
and APPID
Unavailable
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Windows.SecurityCenter.SecurityAppBroker
and APPID
Unavailable
Windows.SecurityCenter.WscDataProtection
and APPID
Unavailable
Failed with 0x57 retrieving AppModel Runtime status for package Windows.
{C2F03A33-21F5-47FA-B4BB-156362A2F239}
and APPID
{316CDED5-E4AE-4B15-9113-7055D84DCC97}
to the user DESKTOP\Dirili SID (S-1-5-21-588804776-4000661037-1743724292-1000) from address LocalHost (Using LRPC) running in the application container Microsoft.Windows.ShellExperienceHost_10.0.19041.5072_neutral_neutral_cw5n1h2txyewy SID (S-1-15-2-155514346-2573954481-755741238-1654018636-1233331829-3075935687-2861478708). This security permission can be modified using the Component Services administrative tool.
The Secure Boot update failed to update a Secure Boot variable with error Secure Boot is not enabled on this machine.. For more information, please see https://go.microsoft.com/fwlink/?linkid=2169931
Metadata staging failed, result=0x80070490 for container '{59D71D1B-45F3-11F0-8AA5-806E6F6E6963}'
Metadata staging failed, result=0x80070490 for container '{59D71D29-45F3-11F0-8AA5-806E6F6E6963}'
Metadata staging failed, result=0x80070490 for container '{74DA7DDC-1087-5676-885A-174F5EE9BDD4}'
Metadata staging failed, result=0x80070490 for container '{59D71DE4-45F3-11F0-8AA5-D45BF1C9C392}'
Metadata staging failed, result=0x80070490 for container '{904F6325-F9D0-5549-8CC4-8610FA2EADE8}'
Metadata staging failed, result=0x80070490 for container '{59D71D1E-45F3-11F0-8AA5-806E6F6E6963}'
Metadata staging failed, result=0x80070490 for container '{59D71D2D-45F3-11F0-8AA5-806E6F6E6963}'
Metadata staging failed, result=0x80070490 for container '{59D71CE1-45F3-11F0-8AA5-806E6F6E6963}'
Metadata staging failed, result=0x80070490 for container '{51889F4F-56F0-567B-B13B-CBA74AB96373}'
Metadata staging failed, result=0x80070490 for container '{8252D069-542B-11F0-8ADA-C8A3E8C11BD2}'
Metadata staging failed, result=0x80070490 for container '{8069E46D-6686-5C52-9F68-EA647C0DB414}'
Metadata staging failed, result=0x80070490 for container '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'
0 Compliments
spamgaway
Débutant
17 445 Visites
Intel is making it excessively hard to use this forum. It bans me from using one-time tokens and forces me to give up my phone number to be able to continue the exchange here. On top of that it seems to have deleted a long and detailed answer I've given earlier today. This makes it very hard to motivate myself to continue wasting my time with a system that is actively trying to keep me out and negating my efforts.
Anyway, I'll aggregate all my information one more time and try and post it here and maybe hopefully it'll stay up. If you were to be able to provide a simple e-mail, it'd be much appreciated.
Answers first:
Seemlingly, yes.
Yes.
Event Viewer, error logs, crash dumps, etc.
Long story short: it is actually not the mouse overlays, it's the hardware monitors that I used to trace the problem.
Current status
Stable base system: Guild Wars 2, Raidcore Nexus, ArdDPS, YoloMouse
Crashes when introducing: Device Manager, or Performance Tab of Task Manager, or Trio of GPU-Z, CPU-Z & SpeedFan
Crashing behaviour: studders for 0,5-2 seconds followed by 0-2 seconds of freeze, then crash in 99% of all cases or permanent freeze in 1% of all cases
Crash timing: everything between after 2 minutes to after 8 hours after introduction of crash-inducting program/s.
Fun fact: without hardware monitors, the crashes also sometimes occur until the point of the stutter/freeze, but then the game "catches itself" and continues. Almost as if whatever is re-stabilizing the game is being interfered with by hardware monitors.
Current tests:
HWiNFO64 + stable set-up: STABLE
PowerShell Command + stable set-up: STABLE
(Command: while ($true) { Get-CimInstance -ClassName Win32_VideoController | Select-Object Name, DriverVersion, AdapterRAM, VideoProcessor; Start-Sleep -Seconds 5 })
Every test takes 2-3 days because of the erratic occurance of the crashes.
Upcoming tests: stable set-up with SPECIFICALLY ONLY Performance Tab, then SpeedFan.
Hope: **bleep**ing find out what actually causes the crashes and what doesn't.
Additional information:
Event Viewer has some entries that correlate, see screenshot.
EDIT: seems like I can't add files on mobile.
0 Compliments
spamgaway
Débutant
17 090 Visites
Event Viewer: https://i.imgur.com/aNmxh38.png
SSU report:
# SSU Scan Information
Scan Info:
Version:"4.1.0.0"
Date:"07/15/2025"
Time:"00:00:26.3642423"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASRock"
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends International, LLC. 3.25 , 05/14/2025"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"AMD Ryzen 5 7500F 6-Core Processor , AuthenticAMD"
Secure Boot State:"Off"
SMBIOS Version:"3.4"
Sound Card:"USB Audio 2.0"
System Manufacturer:"ASRock"
System Model:"X870E Taichi"
System SKU:"Default string"
System Type:"x64-based PC"
- "Graphics"
Intel ® Graphics Driver Version:"32.0.101.6913"
- "Intel(R) Arc(TM) B580 Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"2.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Arc(TM) B580 Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Arc+B580+Graphics"
CoInstallers:"oem11.inf,BMG_IAG_E20B_FWU,Internal,Intel(R) Arc(TM) B580 Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"12188 MB"
Driver:"igdkmdnd64.sys"
Driver Date:"06/21/2025 02:00 AM"
Driver Path:"C:\windows\system32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_ad653a309640ce11\igdkmdnd64.sys"
Driver Provider:"Intel Corporation"
INF:"oem11.inf"
INF Section:"BMG_IAG_E20B_FWU"
Install Date:"Not Available"
Installed Drivers:"C:\windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_ad653a309640ce11\igd9trinity64.dll,C:\windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_ad653a309640ce11\igd10iumd64.dll,C:\windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_ad653a309640ce11\igd10iumd64.dll,C:\windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_ad653a309640ce11\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_E20B&SUBSYS_18771025&REV_00\6&33FA9F01&0&00080009"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"165 Hz"
Refresh Rate - Minimum:"50 Hz"
Resolution:"2560 X 1440"
Scan Mode:"Noninterlaced"
Service Name:"igfxnd"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"16171 MB"
Video Processor:"Intel(R) Arc(TM) B580 Graphics Family"
- "Memory"
Physical Memory (Available):"20.97 GB"
Physical Memory (Installed):"32 GB"
Physical Memory (Total):"31.59 GB"
- "P0 CHANNEL A"
Capacity:"16 GB"
Channel:"DIMM 1"
Configured Clock Speed:"6000 MT/s"
Configured Voltage:"1100 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"Not Available"
Manufacturer:"Unknown"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"F5-6000J3038F16G"
Serial Number:"4155D3F1"
Status:"Not Available"
Type:"Not Available"
- "P0 CHANNEL B"
Capacity:"16 GB"
Channel:"DIMM 1"
Form Factor:"DIMM"
Serial Number:"8859CBF7"
- "Motherboard"
BIOS:"3.25, ALASKA - 1"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"05/14/2025 12:00 AM"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"ACPI\PNP0C01\C8"
Product:"X870E Taichi"
Serial Number:"M80-J1009901303"
Status:"OK"
Version:"Default string"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00 AM"
Driver Path:"C:\windows\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.19041.5848"
Index:"0008"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"07/15/2025 02:38 AM"
MAC Address:"C8:A3:E8:C1:1B:D2"
Manufacturer:"Microsoft"
Net Connection ID:"Bluetooth Network Connection"
NetCfgInstanceId:"{1B9FC19A-D46F-4B94-A924-8284A25517F2}"
PNP Device ID:"BTH\MS_BTHPAN\A&12190B12&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Internet Protocol Version 6 (TCP/IPv6):
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
- "Realtek PCIe 5GbE Family Controller"
Caption:"Realtek PCIe 5GbE Family Controller"
Default IP Gateway:"192.168.178.1;fe80::1eed:6fff:fe5b:626c"
DHCP Enabled:"Yes"
DHCP Lease Expires:"07/25/2025 02:38 AM"
DHCP Lease Obtained:"07/15/2025 02:38 AM"
DHCP Server:"192.168.178.1"
Driver:"rt640x64.sys"
Driver Date:"12/03/2024 12:00 AM"
Driver Path:"C:\windows\system32\drivers\rt640x64.sys"
Driver Provider:"Realtek"
Driver Version:"10.71.312.2024"
Index:"0009"
INF:"oem24.inf"
INF Section:"RTL8126.ndi.NT"
Installed:"Yes"
IP Address:"192.168.178.29;fe80::2abb:4b1d:a9ee:77a1;2a02:810d:b702:8300:252e:5274:231d:6e16;2a02:810d:b702:8300:13bd:6910:1673:dff0"
IP Subnet:"255.255.255.0;64;128;64"
MAC Address:"9C:6B:00:9A:0C:7E"
Manufacturer:"Realtek"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{AEA90ACE-7A8B-49E9-88FD-2725AF9F2A65}"
PNP Device ID:"PCI\VEN_10EC&DEV_8126&SUBSYS_81261849&REV_01\7E0C9A006B9C000000"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Realtek PCIe 5GbE Family Controller"
Service Name:"rt640x64"
Status:"Enabled"
QoS Packet Scheduler:
- "Settings"
*EEE:Energy-Efficient Ethernet:"Enabled (1)"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*InterruptModeration:Interrupt Moderation:"Enabled (1)"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
*JumboPacket:Jumbo Frame:"Disabled (1514)"
*LsoV2IPv4:Large Send Offload v2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload v2 (IPv6):"Enabled (1)"
*ModernStandbyWoLMagicPacket:Wake on magic packet when system is in the S0ix power state:"Disabled (0)"
*NumRssQueues:Maximum Number of RSS Queues:"4 Queues (4)"
*PMARPOffload:ARP Offload:"Enabled (1)"
*PMNSOffload:NS Offload:"Enabled (1)"
*PriorityVLANTag:Priority & VLAN:"Priority & VLAN Enabled (3)"
*ReceiveBuffers:Receive Buffers:"1024 (1024)"
*RSS:Receive Side Scaling:"Enabled (1)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*TransmitBuffers:Transmit Buffers:"512 (512)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on pattern match:"Enabled (1)"
AdvancedEEE:Advanced EEE:"Disabled (0)"
EEEMaxSupportSpeed:EEE Max Support Speed:"1.0 Gbps Full Duplex (1000)"
EnableGreenEthernet:Green Ethernet:"Enabled (1)"
GigaLite:Gigabit Lite:"Enabled (1)"
PowerSavingMode:Power Saving Mode:"Enabled (1)"
RegVlanid:VLAN ID:"0 (0)"
S5WakeOnLan:Shutdown Wake-On-Lan:"Enabled (1)"
WolShutdownLinkSpeed:WOL & Shutdown Link Speed:"10 Mbps First (0)"
- "Operating System"
.Net Framework Version:"4.0,4.8"
Boot Device:"\Device\HarddiskVolume3"
Internet Browser:"Mozilla Firefox, Internet Explorer,11.3636, Microsoft Edge,138.0"
Locale:"Deutschland"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 10 IoT Enterprise LTSC"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"4.75 GB"
Physical Memory (Available):"20.98 GB"
System Directory:"C:\windows\system32"
Version:"10.0.19044 Build 19044.6093"
Virtual Memory (Available):"20.40 GB"
Virtual Memory (Total):"36.34 GB"
Windows Directory:"C:\windows"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB5003791:"Update [10/6/2021]"
KB5005699:"Security Update [10/6/2021]"
KB5011048:"Update [6/5/2025]"
KB5054977:"Update [6/5/2025]"
KB5056578:"Update [7/9/2025]"
KB5058526:"Security Update [6/5/2025]"
KB5059504:"Update [6/11/2025]"
KB5062554:"Security Update [7/9/2025]"
KB5063706:"Security Update [7/8/2025]"
Microsoft ASP.NET Core 8.0.14 - Shared Framework (x86):".NET [28/06/2025]"
Microsoft ASP.NET Core 8.0.17 - Shared Framework (x64):".NET [28/06/2025]"
- "Processor"
Not Available:
- "Storage"
- "PLEXTOR PX-256M3P"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"PLEXTOR PX-256M3P"
Cylinder - Total:"31130"
Description:"Disk drive"
Driver:"Not Available"
Driver Version:"10.0.19041.4597"
Error Code:"Device is working properly"
Firmware Revision:"1.04"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Interface Type:"IDE"
Manufacturer:"(Standard disk drives)"
Model:"PLEXTOR PX-256M3P"
Partitions:"1"
Physical Sector Size:"4096"
PNP Device ID:"SCSI\DISK&VEN_PLEXTOR&PROD_PX-256M3P\9&2AAE109E&0&030000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
Sectors - Per Track:"63"
Sectors - Total:"500103450"
Serial Number:"P02223100658"
Size – Available:"231.04 GB"
SMART Attributes:"Self-Test: 10 minutes, OK, Short Self-Test: 1 minutes, OK"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"7938150"
- "D:"
Availability:"Not Available"
Caption:"D:"
Compression Method:"Not Compressed"
Description:"Local Fixed Disk"
File System:"NTFS"
Serial Number:"E213EED5"
Volume Dirty:"No"
- "SMART"
0x01 Raw Read Error Rate:0:"0"
0x05 Reallocated Sector Count:0:"10"
0x09 Power-On Hours:18882:"0"
0x0C Power Cycle Count:9772:"0"
0xB1 Wear Range Delta:226445:"0"
0xB5 Program Fail Count Total:0:"10"
0xB6 Erase Fail Count:0:"10"
0xBB Uncorrectable Error Count:0:"0"
0xC0 Unsafe Shutdown Count:186:"0"
0xC4 Reallocation Count:0:"0"
0xC6 Uncorrectable Sector Count:0:"0"
0xC7 CRC Error Count:0:"0"
0xE8 Available Reserved Space:0:"0"
- "Samsung SSD 850 PRO 128GB"
Caption:"Samsung SSD 850 PRO 128GB"
Cylinder - Total:"15566"
Firmware Revision:"EXM04B6Q"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Model:"Samsung SSD 850 PRO 128GB"
Partitions:"1"
Physical Sector Size:"512"
PNP Device ID:"SCSI\DISK&VEN_SAMSUNG&PROD_SSD_850_PRO_128G\9&2AAE109E&0&010000"
Sectors - Total:"250067790"
Serial Number:"S1SMNSAG322723X"
Size – Available:"119.10 GB"
SMART Attributes:"Self-Test: 68 minutes, OK, Short Self-Test: 2 minutes, OK"
Status:"OK"
Tracks - Total:"3969330"
- "E:"
Caption:"E:"
File System:"NTFS"
Serial Number:"10B50BCA"
Volume Dirty:"No"
- "SMART"
0x09 Power-On Hours:41943:"0"
0x0C Power Cycle Count:7885:"0"
0xB1 Wear Range Delta:670:"0"
0xB3 Used Reserved Block Count Total:0:"10"
0xB7 SATA Downshift Count:0:"10"
0xBE Temperature - Current:33° C:"0"
0xBE Temperature - Highest:Not Available:"0"
0xBE Temperature - Lowest:Not Available:"0"
0xC3 Hardware ECC Recovered:0:"0"
0xEB Good Block Count:250:"0"
0xF1 Total LBAs Written:59069771927:"0"
- "Samsung SSD 980 1TB"
Capablities:"Random Access, Supports Writing"
Caption:"Samsung SSD 980 1TB"
Cylinder - Total:"121601"
Firmware Revision:"3B4QFXO7"
Heads - Total:"255"
Index:"3"
INF:"disk.inf"
Interface Type:"SCSI"
Model:"Samsung SSD 980 1TB"
Partitions:"2"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_SAMSUNG_SSD_980\7&3A2B98F2&0&000000"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"2"
Sectors - Total:"1953520065"
Serial Number:"0025_38DC_21A3_E3CB."
Size – Available:"542.27 GB"
Status:"OK"
Tracks - Total:"31008255"
- "C:"
Caption:"C:"
File System:"NTFS"
Serial Number:"5C5DEF8A"
Volume Dirty:"No"
- "ST4000DM000-1F2168"
Caption:"ST4000DM000-1F2168"
Cylinder - Total:"486401"
Firmware Revision:"CC54"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Model:"ST4000DM000-1F2168"
Partitions:"1"
PNP Device ID:"SCSI\DISK&VEN_&PROD_ST4000DM000-1F21\7&2064BCD1&0&010000"
Sectors - Total:"7814032065"
Serial Number:"Z303T046"
Size – Available:"2.45 TB"
SMART Attributes:"Self-Test: 255 minutes, OK, Short Self-Test: 1 minutes, OK"
Status:"OK"
Tracks - Total:"124032255"
- "F:"
Caption:"F:"
File System:"NTFS"
Serial Number:"6AF19E1B"
Size – Available:"2505.92 GB"
Volume Dirty:"No"
- "SMART"
0x01 Raw Read Error Rate:70570864:"0"
0x03 Spin Up Time:0:"0"
0x04 Start/Stop Count:15239:"0"
0x07 Seek Error Rate:15103583:"0"
0x09 Power-On Hours:40141:"0"
0x0A Spin Retry Count:0:"0"
0x0C Power Cycle Count:7804:"0"
0xB8 End-to-End Error Detection Count:0:"0"
0xBC Reported Command Timeouts:0:"0"
0xBD High Fly Writes:0:"0"
0xBE Temperature - Current:37° C:"0"
0xBE Temperature - Highest:40° C:"0"
0xBE Temperature - Lowest:24° C:"0"
0xBF G-sense Rate/Servo Tracking:0:"0"
0xC0 Unsafe Shutdown Count:71:"0"
0xC1 Load/Unload Cycle Count:162204:"0"
0xC2 Internal Device Temperature:37° C:"0"
0xC5 Current Pending Errors Count:0:"0"
0xF0 Head Flying Hours:12429:"0"
0xF1 Total LBAs Written:27412595190:"0"
0xF2 Total LBAs Read:53502644368:"0"
...#SSU#...
0 Compliments
spamgaway
Débutant
17 089 Visites
REPOST OF DELETED POST
SSU report:
Scan Info:
Version:"4.1.0.0"
Date:"07/15/2025"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
- "Graphics"
Bits Per Pixel:"32"
INF:"oem11.inf"
Monochrome:"No"
Status:"OK"
- "Memory"
- "P0 CHANNEL A"
Capacity:"16 GB"
Channel:"DIMM 1"
Form Factor:"DIMM"
- "P0 CHANNEL B"
Capacity:"16 GB"
Channel:"DIMM 1"
Form Factor:"DIMM"
- "Motherboard"
Status:"OK"
- "Networking"
DHCP Enabled:"Yes"
Driver:"bthpan.sys"
Index:"0008"
INF:"bthpan.inf"
Installed:"Yes"
Status:"Enabled"
DHCP Enabled:"Yes"
Index:"0009"
INF:"oem24.inf"
Installed:"Yes"
Status:"Enabled"
- "Settings"
- "Processor"
Not Available:
- "Storage"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Partitions:"1"
Status:"OK"
- "D:"
Caption:"D:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Partitions:"1"
Status:"OK"
- "E:"
Caption:"E:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
Heads - Total:"255"
Index:"3"
INF:"disk.inf"
Partitions:"2"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"2"
Status:"OK"
- "C:"
Caption:"C:"
File System:"NTFS"
Volume Dirty:"No"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Partitions:"1"
Status:"OK"
- "F:"
Caption:"F:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
...#SSU#...
0 Compliments
spamgaway
Débutant
17 090 Visites
TESTING OF WHAT LEADS TO AUTOMATIC DELETION
SSU report:
Scan Info:
Version:"4.1.0.0"
Date:"07/15/2025"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
- "Graphics"
Bits Per Pixel:"32"
INF:"oem11.inf"
Monochrome:"No"
Status:"OK"
- "Memory"
- "P0 CHANNEL A"
Capacity:"16 GB"
Channel:"DIMM 1"
Form Factor:"DIMM"
- "P0 CHANNEL B"
Capacity:"16 GB"
Channel:"DIMM 1"
Form Factor:"DIMM"
- "Motherboard"
Status:"OK"
- "Networking"
DHCP Enabled:"Yes"
Driver:"bthpan.sys"
Index:"0008"
INF:"bthpan.inf"
Installed:"Yes"
Status:"Enabled"
DHCP Enabled:"Yes"
Index:"0009"
INF:"oem24.inf"
Installed:"Yes"
Status:"Enabled"
- "Settings"
- "Processor"
Not Available:
- "Storage"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Partitions:"1"
Status:"OK"
- "D:"
Caption:"D:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Partitions:"1"
Status:"OK"
- "E:"
Caption:"E:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
Heads - Total:"255"
Index:"3"
INF:"disk.inf"
Partitions:"2"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"2"
Status:"OK"
- "C:"
Caption:"C:"
File System:"NTFS"
Volume Dirty:"No"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Partitions:"1"
Status:"OK"
- "F:"
Caption:"F:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
...#SSU#...
0 Compliments
spamgaway
Débutant
17 087 Visites
The Event Viewer: https://i.imgur.com/aNmxh38.png
Seems like posting the log into the text box leads to a shadow deletion without notification. You only notice your post gone if you refresh or come by later. However, there is a file upload box in the edit box if not at the reply box, so that's something I guess.
0 Compliments
JedG_Intel
Modérateur
17 281 Visites
Hello spamgaway,
I'm sorry to hear that you encountered difficulties with posting your responses here on the thread. To ensure that I'll be able to support you properly, I sent you an email. Please check your inbox at your earliest convenience.
Best regards
Jed G.
0 Compliments
RandyT_Intel
Modérateur
16 650 Visites
I'm reaching out on behalf of my colleague regarding a concern we previously emailed about. Could you please check on your end for any updates or responses?
Additionally, we’re referring to a homebrew code, raw executable code that runs without an emulator and is specifically designed to reproduce the issue in question. We’re seeking clarification on its relevance and any guidance you can provide.
Randy T.
0 Compliments
JedG_Intel
Modérateur
16 252 Visites
We have not heard back from you so we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
0 Compliments
Répondre
