I will not have any of those problem if I enable my CSM
The only fix I know right now is turn on my PC with CSM enable, once It load windows, I restart, then disable CSM, and I can install or do any windows related task without my PC restarting.
Iv'e done :
Reinstall windows 10 multiple time
Make sure it's GPT partition instead of MBR
Using DDU on safe mode to reinstall driver
Checking my ram stability
Using windows 11
Using linux
My spec :
Ryzen 5 5600
Intel Arc b580 titan OC
ASRock b550m pro4
PSU MSI mag a550bn
after bringing it technician, they fix it, apparently the ram slot is dirty, sorry for the inconvenience
Hello FlyingCat,
Greetings from Intel Customer Support,
Thank you for posting your query on the Intel Community Forum.
We appreciate the detailed information you have provided regarding the issue.
To assist with our investigation, we kindly request the following information:
- What is the current BIOS version installed on your ASRock B550M Pro4 motherboard?
- Have you updated the motherboard to the latest BIOS version available from ASRock?
- Are Resizable BAR (ReBAR) and Above 4G Decoding enabled in the BIOS?
- You mentioned that you are using both Windows 10 and Linux. Could you please let us know on which operating system the issue occurs?
If the issue occurs on Windows 10, please generate and share an Intel System Support Utility (SSU) report using the link below:
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
If the issue occurs on Linux, please generate and share an SSU report using the link below:
Please ensure that the Networking option is unchecked while generating the SSU report.
Additionally, we recommend performing the following checks:
- Ensure that the latest Intel graphics driver is installed.
- Temporarily disable any overclocking settings and verify whether the issue persists.
- Check Windows Event Viewer for any critical Kernel-Power (Event ID 41) entries following an unexpected restart and share the details with us.
Once you have completed the above steps, please share the results with us. This information will help us determine whether the issue is related to the system configuration or another component within the platform.
We look forward to your response.
Roy
sorry for the late reply
1. i'm using bios 3.90
2. not yet, but it's just one version apart
3. yes, it's on
4. currently i'm using windows 10
i will put SSU result bellow
i'm on intel latest driver
i'm not using overclocking
here is the event viewer from event ID 41
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 06/06/2026 02:26:41
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: DESKTOP-OHM2BMC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2026-06-06T09:26:41.7153990Z" />
<EventRecordID>698</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-OHM2BMC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
Hello @FlyingCat,
Upon reviewing the SSU logs, we can see that the device is currently running Windows 10.
Could you please upgrade the operating system to Windows 11 and let us know once the upgrade has been completed if the issue still persists so that we may know if the issue is on all the operating systems or just the Windows 10?
Thank you for your cooperation and understanding.
Manas
Hello FlyingCat,
Thank you for the update.
We understand that you have already tested the system with Windows 11. To assist us with further investigation, could you please provide the latest Intel System Support Utility (SSU) report generated from your current system configuration?
Additionally, if available, we would appreciate it if you could share a short video demonstrating the issue. This will help us better understand the behavior and expedite our analysis.
We appreciate your cooperation and look forward to your response.
Roy
The system just reboot instantly whenever i tried to install program, i also change to new ssd, and the problem still occur
Hello FlyingCat,
I understand that you reverted to Windows 10 and that the issue persists even after testing with Windows 11, Bazzite, and a different SSD. I appreciate the troubleshooting steps you have already performed.
To assist us with further investigation, could you please share a short video demonstrating the issue? Specifically, we would like to see the behavior when the system unexpectedly restarts during a program installation.
The video will help us better understand the circumstances under which the issue occurs and allow us to continue our analysis more effectively.
Roy
Hello FlyingCat,
Greetings from Intel Customer Support.
Thank you for your response and for providing additional details regarding the issue. We understand that the system restarts can now be observed when launching games and that you recently experienced another unexpected restart while opening the Messenger application.
We appreciate your efforts in attempting to reproduce the issue and for sharing this information with us.
Please be assured that your case is currently under review, and I am actively working on it. I will provide you with an update as soon as possible.
Thank you for your patience and cooperation.
Roy
