Intel® Arc™ Discrete Graphics
3544 Discussions
Driver Update breaking Intel Arc Control
Heilstein
Card: Intel Arc A770 SPARKLE ROC Luna
Hi there,
every Driver Update I do seems to not go smooth at all. Since I bought the card I had the driver update seem "unfinished" with Intel Arc Control closing itself during the install and not reopening itself. After manually opening Intel Arc Control back up, the driver version is the newest, however the "Check for updates" is unable to find an update / unable to reach the Server after the driver Update.
To "FIX" this Intel Support just tells people to use DDU and reinstall Intel Arc Control, however for me next Driver Update breaks it again. Whats even the point of having a Software to Update your drivers, if I have to manually remove and reinstall the drivers every second Driver Update.
Anyone got a real fix for this behavior, or do I need to hit the lottery every second Update?
Mike_Intel
Hello Healing stone,
For us to further check this, please help provide the following details:
You are correct, the recommendations for this issue is to reinstall the Arc Control Panel.
Let me just share the links:
https://www.intel.com/content/www/us/en/support/articles/000096688/graphics.html
https://www.intel.com/content/www/us/en/support/articles/000096682/graphics.html
However, since you are using a 3rd party Arc Graphics, they may have altered or modify this card and may require their own driver.
You may also try to check if there is available driver from Sparkle.
Michael L.
Heilstein
This is not an acceptable fix as I said. There are no vendor specific drivers for Sparkel cards.
Mike_Intel
Thank you for the quick reply.
Please help generate the SSU logs of your system for us to further check this issue.
Kindly download the utility here:
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
Michael L.
Mike_Intel
Michael L.
Mike_Intel
I am sending another follow up on the information that I requested.
Michael L.
