Intel® Arc™ Discrete Graphics
3510 Discussions
Dual Mode oled disables all screens but igpu screen
Bandit8623
New Contributor III
i recently aquired a 4th monitor.  it seems the arc770 can not use all 4 ports.  if i have all 3 displayports active. when using the last hdmi port the screen i cannot activate. soo
so to get 4th screen working i used my intel 8700k igpu hdmi port on motherboard.  All is good until i want to game and change my oled 4k 240 hz monitor to dual mode 1080p 480hz.
When i change modes all screens go black but the igpu screen.  I have to go into display settings and re-enable the 3 screens thats get disabled.    same thing happens when i go back top 4k mode, below is screen model.
32GS95UE-B.AUS
  this happens on windows 10 and 11. this info im attaching is from windows 10.
showing first blank to 1080p 480hz  and having to change all to enabled again.
https://drive.google.com/file/d/1IQKHiNvs42gDF2TvcaOQnMBaIlultkrc/view?usp=sharing
showing after enabled and going back to 4k
https://drive.google.com/file/d/1IRvYJ44DnQ9adEy4jqiokUW44vzRgTS9/view?usp=sharing
this doesnt happen when using 3 monitors on my arc only.
DhannielM_Intel
Hi Bandit8623,
Thank you for posting in the community, and for sharing the information about your issue. To further investigate this I will be asking you some questions. Please provide the following information below
  1. Based on the SSU that you have provided, I see that you are using the latest graphics driver (32.0.101.5989), when you acquire your fourth monitor, have you already updated your driver or you updated after you plug the fourth monitor on the graphics card?
  2. Have you perform clean installation on the graphics driver?
  3. Have you tried using the displayport on the fourth monitor and unplug one of the monitor connected on the displayport to test?
  4. Also, can you try using HDMI on one of your first three monitors to perform some testing?
I am looking forward hearing back from you.
Dhanniel M.
Bandit8623
New Contributor III
Hi there,
1- initially i was on the new driver,  but then added 4th monitor.  i also tried ddu after blanks and reinstalled.
2- yes ddu
3-i havent tried this.  and recently as a few days ago i can now do dual mode and nothing blanks anymore.
4- seems to work now as is.  very weird..
poosbible fix below
everytime i installed the 630 driver ,arc control would show the 630 driver version even though in device manager would show 32.0.101.5989 for arc and 2130 for the onboard driver .
ddu everything then
i installed the latest arc 770 driver,  then i manually had to extract the driver files for the onboard 630 and through device manager install there by using "have disk" method.
now everything is working.
basicly i dont think the 630 driver and arc driver play nice with each other.
Bandit8623
New Contributor III
Even with installing newest driver arc control thinks im running 2130 driver.  im on latest.
DhannielM_Intel
Hi Bandit8623,
Thanks for letting me know, just one more question is would you still require assistance with this or is it alright for you to close this thread?
Dhanniel M.
Bandit8623
New Contributor III
Hopefully it keeps working. This can be closed.
DhannielM_Intel
Hi Bandit8623,
Thanks for the confirmation, as such I will be closing this thread. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dhanniel M.
Bandit8623
New Contributor III
@DhannielM_Intel
every new driver update and install the same issue appears.  i have to go through the display manager and reactivate each screen.  onces done it works till  the next driver update.
