Intel® Arc™ Discrete Graphics
4126 Discussions
Enshrouded Vulkan Crash
ColonelForbin
Recently (within the last few weeks) I've been encountering repeated, random crashes to desktop while playing Enshrouded.
Sometimes this will occur when starting up my own, privately hosted server, rendering the game unplayable even for solo play.
I dug into the logs from the crash dumps and they all (every. single. one.) has the same error message:
vkQueueSubmit 'Frame' failed with error 'VK_ERROR_DEVICE_LOST'
Vulkan device lost...
Stopping process due to unrecoverable GPU crash!
I've tried everything from verifying game files, clean install of Arc A770 graphics drivers, rollback of drivers, attempted a vulkan fix, but nothing works. I believe this to be an issue with the graphics card, so I wanted to report the error here in the hopes that it makes its way to the team and eventually a driver fix.
I've included the crash dump with the error from the game.
Labels (3)
DhannielM_Intel
Hi ColonelForbin,
Thank you for posting in the community.
I have some information that I would like to ask you about so I can identify a possible resolution for your issue. Please share the information by answering the following questions below:
  1. What is the version of driver you are using when the random crashes happened?
  2. When you say you tried rolling back the drivers, can you tell me the version you used?
  3. Also, can you share the game setting you are using on Enshrouded?
  4. Please also include the version of Enshrouded you are playing?
  5. Does the crashes happen when you are fighting an enemy or when the game is just on idle?
Also, to better understand your entire system information, please use the System Support Utility (SSU). This will generate a text file that compiles all your system information. You can follow this link for instructions and send the text file here. How to get the Intel® System Support Utility Logs on Windows. I am looking forward hearing from you.
Dhanniel M.
DhannielM_Intel
Hi ColonelForbin,
Dhanniel M.
DhannielM_Intel
Hi ColonelForbin,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dhanniel M.
