Intel® Arc™ Discrete Graphics
4332 Discussions
Error Need For Speed Heat
addelucas123
New Contributor III
good night
I am David, and I come to say that I have a problem with Need For Speed Heat, it does not start, it uses DX11 and I think it is a lack of drivers and to improve all the games that use DX11, I wanted to play Need For Speed Heat for a while and my Intel Arc graphics card A770 does not want to start that game I get an error box some stability or performance, please report
It happens to me all the time, whether the drivers are updated or not updated, the game does not start, I currently have the driver 31.0.101.4255 and I have everything updated, I tried several ways and nothing works
I need to report and more than 100 games that use DX11 the same all reported
Jean_Intel
Hello David1997,
Thank you for posting on the Intel️® communities. We understand that you are experiencing issues when playing Need For Speed. We would be more than glad to help you with this issue.
  • Is this issue since day one?
    • If the game used to work, do you recall any hardware or software changes before the issue started?
  • Provides us with a screenshot of the graphics settings you use.
  • What is the game distribution service? ( Blizzard, Epic, Origin, Steam, Xbox, Ubisoft connect)
  • Create a report using the following tools:
  • Intel System Support Utility (Intel SSU)
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
  •  Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
addelucas123
New Contributor III
No hardware change or anything, that is, I've had it since I bought the graphics card, etc. I updated the latest version and it's still the same, that is, the game doesn't start, so I think we have to report it again
addelucas123
New Contributor III
addelucas123
New Contributor III
I send it to you
Jean_Intel
Hello David1997,
We will proceed to check the issue internally and post back soon with more details.
Jean O.
Jean_Intel
Hello David1997,
Thanks for the information provided.
After investigating this matter, we want to let you know that this has been debugged by our driver team already and it is in fact an application issue. This error appears because the game is checking the driver version against a very old format, so the driver looks old to the game even though it isn't. We recommend you contact the game developer to report this issue for further support.
Jean O.
Jean_Intel
Hello David1997,
We hope you are doing fine.
Best regards.
Jean O.
MeMuHeK
Intel Grafik Kartı konusunda tani olduğundan bu gibi problemleri olmasını normal karşılıyorum. Fakat merak ediyorum destek merkezi de oyunu kurup deniyor mu acaba.
Yok kursalar hataları görecekler ve gereksiz yazışma olmayacak. Yok ddu ile silin! Yok son sürüme güncelleyin! Vs boş yazışmalar olmayacak.
Umarım hızlı aksiyon alınır.
