Intel® Arc™ Discrete Graphics
3565 Discussions
Facing shatter lag while playing genshin impact - Arc A750- driver- 4672
CAUSE
I'm facing shatter lag while playing valorant( low graphic) and genshin impact(max graphic setting - gpu usage 55%) after installing September 2023 driver update.
My computer specs:
Processor - Ryzen 7 5700x
GPU - Intel arc a750
Motherboard - gigabyte B550 DS3H
Cooler - deepcool AG400 RGB
PSU- Corsair cv650
Ram - T-force Vulcan Z (8x2)
SSD- xpg sx6000 pro m.2 256gb
HHD- WD 7200 rpm 1tb
Moniter- gigabyte g24f2(165hz)
ReBAR - enabled
Andres_Intel
Hello CAUSE,
Thank you for posting on the Intel communities. As a gamer, I know how annoying is to have lags in Genshin Impact, I will be more than happy to help you.
I see you have the same issue in two different games, to keep this thread organized and help you in the best way, please open a new thread for the Valorant issue.
Before starting with the troubleshooting steps, please answer the following questions:
0507MAZ
Hi, i also have similar issue regarding Genshin Impact. Its very frustrating to play when the game keep getting some lags or straight up stuck on a screen. My PC uses Intel Iris XE. Here is my game setting. I want to emphasize that previously i play on a medium setting, not at low settings which is a very disappointing performance since the september update, knowing even in low settings, the problem is still there.
In the attachment, I provided a screenrecord of the game from the start of booting the game. Somehow, the screenrecord doesnt capture the screen glitching and flashing slightly occasionally but it does happen. It probably an effect that affect directly towards my laptop screen. As you can see, the video shows a very slow load, but it does depends on how long i have had my laptop on. Though, i usually had it on, before booting the game, at most 1-2hours. I even try restarting my laptop just to play the game. And when the game just straight up stuck, i need to force shutdown the laptop by holding the power button, which really bothers me for the health of my laptop. I literally cant do anything once it stucked. I couldnt alt-f4 or alt-tab. Do tell me if there are other safer way to force stop the game besides force shutdown the laptop.
I also attached the .txt from the Intel SSU.
Im new to the forum, so i hope the all files are uploaded as intended.
Andres_Intel
Hello CAUSE,
Were you able to run Intel® (SSU)?
Andres P.
0507MAZ
Yes, I am able to run it fine.
Andres_Intel
Hello CAUSE,
Thank you for letting me know that you were not able to run the Intel® SSU.
Remember to attach the report generated by following the steps below:
  1.  Scan: Check the box Everything.
  2. Click Scan.
  3. Review: When finished scanning, click Next.
  4. Click Save.
Andres P.
0507MAZ
Im sorry? I did informed you that i can run it just fine. I also send you the report in the attachment in (.txt) form in the first message.
Andres_Intel
Hello @0507MAZ,
Thank you for your response.
I see you attached the Intel® SSU in your first post, now I just waiting for CAUSE to attach it to be able to continue.
Andres P.
Andres_Intel
Hello CAUSE,
@0507MAZ to continue please make a new post related to this issue., and we will be more than glad to help you.
Andres P.
Andres_Intel
Hello CAUSE,
Before we close the thread, I want to let you know that we are going to test the game internally and verify the bug report against our latest drivers.
As soon I have the results I will let you know.
Andres P.
Andres_Intel
Hello CAUSE,
Thank you for your time.
We still testing the game, and we are waiting for the results, as soon I have them I will let you know.
Andres P.
Andres_Intel
Hello CAUSE,
Thank you for your patience.
I want to let you know that the reproduction is in progress, we are working really hard to get the results, as soon I ahve them I will let you know.
Andres P.
Andres_Intel
Hello CAUSE,
Thank you for your wait time.
We will have the reproduction results soon, and once we have them I will let you know.
Andres P.
Andres_Intel
Hello CAUSE,
Thank you for your time and patience.
We have completed the replication of your issue, but we have been unable to reproduce this issue. We tested Genshin Impact on Intel® Arc™ A750 Graphics and Intel® Arc™ A770 Graphics on a system with Core i9-13900K + Windows 11 22H2 and driver 31.0.101.4887 and as per CapFrameX data no stuttering occurred. See screenshots of CapFrameX data below
The graphics settings are visible at the end of the video recording (4K, High presets). Video: https://youtu.be/lAl1bt6JD0o
Please update the graphics driver to version 31.0.101.4887 by following the article How to Install an Intel® Graphics Driver in Windows® 10 & Windows 11 and re-test the game.
Let me know the results.
Andres P.
Andres_Intel
Hello CAUSE,
Were you able to update the graphics driver to version 31.0.101.4887?
Andres P.
Andres_Intel
Hello CAUSE,
Andres P.
