Intel® Arc™ Discrete Graphics
3562 Discussions
Forspoken v.1.22: Is new AMD FSR 3 + Frame Generation always crashing on Intel Arc?
LynxRufus
forspoken updated to version 1.22  today,
and is now the first game released  with AMD's new FSR3 + Frame Generation feature.
In theory - as communicated across the internet -  I thought this should work on any 'modern/recent' GPU regardless of vendor/manufacturer,  including Intel Arc dGPUs as well,
however, it appears to be like this, currently:
https://www.youtube.com/watch?v=9QHo_DlLvpg
so, as title says ,  can you try out if  the game Forspoken ( or DirectX) is really always crashing,
as soon as you enable FSR 3 + frame generation, as seen in above video?
(you don't even have to buy the game, there's a free Demo for everybody on steam eg. and it's been also updated to v.1.22 which includes FSR3+frame gen..)
I've googled the directx error message displayed in above video, and it has been mentioned before, but back then related to a nvidia rtx 4070 (ti) crashing randomly, long before that new patch that rolled out today..
unfortunately I can't check it out myself because currently I switched out my Arc A770 for a RX 6700 XT,
as I'm in the middle of creating some extensive benchmark & image quality comparisons throughout all sorts of games, mostly those that already offer XeSS as well..
just wanted to give a small heads-up,
because as of right now, I'm not sure if the creator of the game Forspoken,
or AMD as the developer of FSR3,
and also Intel , responsible for Arc & it's drivers, are even aware of the issue right now.
I wish I had a second test-rig so I don't have to switch cards all the time, but can't afford it right now (unless someone would be willing to sponsor/donate )
LynxRufus
short answer:
no, not always crashing, at least not for everyone:
https://www.youtube.com/watch?v=goOEZ6onBJM
long answer:
I finally also tried now on my own Arc A770 16GB VRAM,
with 32GB RAM same driver *.4826 ,
and it did crash, only once,
on first launch after update, when trying to activate FSR3 .
however, on second attempt I lowered every other detail setting including resolution first,
then I was able to activate FSR3 + Framegen.
(forspoken steam demo v 1.22)
didn't find FSR3 or FSR3+FrameGen any useful at all,
havent found acceptable settings for 1440p with significantly more than 60fps without crippling either frametimes or image quality/stability,
imho the new  frame generation feature from AMD has very limited use cases,
(and basically you already need at least stable 60 fps to start with before you should even think about activating it, for acceptable results)
so I switched back to XeSS + custom settings for 60 fps capped, at least in this game.
well see what Intel will come up with ( I hope they got something they're working on and that it will be good, just like current XeSS),
and maybe wait for next games with FSR3/framegen and first bug fix releases from AMD/game developers.
LynxRufus
short answer:
long answer:
nisan
thank you for the solution
Andres_Intel
Hello LynxRufus,
Thank you for posting on the Intel communities. As a gamer I understand how frustrating is when having a game crashes, I will be happy to help you.
I see you have marked this thread as solved I would to confirm, is this thread solved already?
In case this issue is not solved, to have a better understanding of the situation, please answer the following questions:
Andres P.
Andres_Intel
Hello LynxRufus,
Were you able to run the Intel® SSU?
Andres P.
MarcoTheFirst
Hi Everybody,
why is this thread marked as solved? There is still no solution on this topic. It is surley not a solution to lower all details.
In my case - Intel Arc 770 LE is crashing with an error code like "Device removed because of DX 12 hung".... First it crashes on the desktop/Steam, when I tried it again the whole Windows/PC crashed.
Marco
Andres_Intel
Hello LynxRufus,
@MarcoTheFirst seems thread was marked as solved by thread owner, in this case, I see you have a similar issue and we will be more than happy to help you, since this thread will be closed, I recommend you opening a new thread related to your issue.
Andres P.
Andres_Intel
Hello LynxRufus,
Before I close the case, I want to thank you for submitting this feedback to us, our driver debug team is looking into this issue. No ETA for a fix yet but it is being worked on.
For now, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
Andres_Intel
Hello LynxRufus,
Before closing this thread, I want to let you know that the issue is resolved with graphics driver version 31.0.101.4900 released this week, please update it by following the article How to Install an Intel® Graphics Driver in Windows® 10 & Windows 11.
Let me know the results.
Andres P.
Andres_Intel
Hello LynxRufus,
Were you able to update the graphics driver to version 31.0.101.4900?
Andres P.
Andres_Intel
Hello LynxRufus,
Andres P.
