Intel® Arc™ Discrete Graphics
Game openning
SoldierGabi
Jean_Intel
Hello SoldierGabi,
Thank you for posting in the Intel Communities. We see that you are experiencing crashing issues when opening a game. But before we continue to assist you, we want to let you know that our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool; hence, the translation may not be completely accurate.
Based on the information you have shared, we would like to confirm the following:
  • What graphics adapter model do you have? In case you are using an Intel Arc, provide us with the exact card model and manufacturer.
  • What is the affected game? What distribution service did you use to install the game? (Steam, Microsoft store, XBOX Game Pass, Epic Games)
  • Which driver version have you updated to? Was it the latest 31.0.101.4887?
  • What driver version did you install previously?
  • Does the issue improve if you revert your graphics driver?
Best regards
Jean O.
Jean_Intel
Hello SoldierGabi,
We are checking your thread to see if you have gathered the information we requested. Note that the information will help us to understand better your issue to assist you more efficiently.
Best regards
Jean O.
Jean_Intel
Hello SoldierGabi,
We have not heard back from you, so we will proceed to close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards
Jean O.
