As shown in the picture, every time I try to update the driver, I encounter this error. I purchased a B580 in May, and since then, I have been updating the drivers without any issues until recently. At first, I didn’t pay much attention and planned to update later. However, when I realized I had missed several driver versions, I tried to resolve the issue but couldn’t find a solution. Please help me. Thank you.
Additionally, the Chinese text in the image reads: '无法调用方法。此语言模式仅支持核心类型的方法调用。所在位置 行:4 字符:1'. I hope this information is helpful for you.
Hi Catgray,
Thank you for reaching out to the Intel Community Forum. I appreciate your message and want to assure you that I’m here to assist you with your concern. To better understand the issue and provide accurate support, could you please share the following details:
- Are you running PowerShell as Administrator when this error occurs?
- Which PowerShell version are you using?
- How exactly are you trying to update the driver?
- Through Device Manager?
- Manual PowerShell commands?
- Windows Update?
- What specific command or action triggers this error? (The error shows it's related to [Environment]::GetEnvironmentVariable())
- Have you made any recent changes to your system?
- Windows updates?
- PowerShell execution policy changes?
- Security software installations?
- System language or region changes?
- When did this issue first start occurring?
Additionally, to help us better understand your system configuration and provide accurate support, we kindly request that you share the Intel® System Support Utility (SSU) logs from your device. These logs contain important details about your hardware and software environment, which are crucial for troubleshooting.
Please follow these steps:
- Download and run the Intel® SSU application.
- The tool will generate a text file containing your system information.
- Refer to this guide for detailed instructions: Help Guide for the Intel® System Support Utility
- Once completed, please attach the generated file to your response.
If you have any additional questions or need further assistance, please don’t hesitate to contact us.
Kent Russel P.
Hello Kent,
Regarding your first four questions:
The PowerShell version I am using is 5.1.26100.6899. I did not launch PowerShell manually—I simply ran the update program downloaded from the official website as usual, and then the PowerShell error appeared. I did try running the update program with administrator privileges, but it didn’t help.
For your fifth and sixth questions:
My Windows updates automatically. Since the issue did not appear recently, I can’t confirm whether it was caused by a specific update. I have never modified PowerShell execution policies or installed any security software.
Considering that my current driver version is 32.0.101.8132, and the next version (32.0.101.8135) was released on October 1st, the issue must have started occurring after October.
I have attached the files you requested. Looking forward to your reply.
Hi Catgray,
Thank you for getting back to me. Please rest assured that I will conduct a thorough investigation into your concern. If you have any further questions or need additional assistance, feel free to reach out at any time.
Kent Russel P.
Hi Catgray,
Thank you for your patience. To assist with the investigation and further review of your concern, could you please answer the following questions:
- Have you tried rolling back the Windows update?
- Have you used Display Driver Uninstaller (DDU) before installing or updating the graphics driver?
Kent Russel P.
Hello, thank you for your reply. I tried rolling back the recent two quality updates for Windows, but it didn't resolve the issue. Regarding DDU, I didn't use it before updating—I just ran the update program directly. Although I did consider using it to uninstall the driver and then reinstall it after the driver installation failed, given the current situation, I was concerned that I might not be able to reinstall the driver after uninstalling it, so I didn't dare to proceed. Looking forward to your reply. Thank you.
Hi @Catgray,
I am reaching out on behalf of my colleague. Based on my assessment, this appears to be an installation issue. Kindly try performing a clean installation of the graphics driver using DDU (Display Driver Uninstaller), then install the latest graphics driver version 32.0.101.8250.
Once completed, please let me know if the issue remains unresolved.
Randy T.
Hello Randy,
regarding the suggestion you mentioned, I gave it a try today. Unfortunately, using DDU to uninstall the graphics driver didn’t allow me to successfully run the driver installation. After that, I reinstalled my system and attempted to install the driver again. Luckily, this time it worked, and I haven’t encountered any other issues so far. I truly appreciate the help from you and Kent. Thank you!
Hi Catgray,
I hope you're doing well. Thank you for confirming that the issue has been resolved. With that in mind, I will proceed to close this inquiry. Should you need further assistance or have additional questions, please feel free to submit a new request. Kindly note that this thread will no longer be monitored once closed.
Kent Russel P.
