Intel® Arc™ Discrete Graphics
3554 Discussions
Intel ARC A750 Crashing on Launch after changing graphics settings
hekubas
I've had the card for awhile now but after running into a number of issues with it lately I've decided to start reporting them. I won't put past things I've experienced and have no proof of.
Recently I've installed "The First Descendant" through Steam and now "Off the Grid" through the Epic store. Both games launched to the title screen and TFD let me play a little bit. However, after changing the graphics settings I am now no longer able to play.
I tried many things with TFD that showed a weird PHYSX Untrusted system file error after crashing to desktop. Eventually it would just crash with no error. After everything I tried to get TFD working, installing the latest ARC Driver fixed the issue!
Now I just installed Off the Grid. It launched to the title menu. I messed with the graphics settings a bit but had to close the game. I come back to open the game and it crashes after the intro video. I've attached the SSU file, UE Crash Files, and the gamesettings.ini inside the crash folder.
Labels (2)
ACarmona_Intel
Hello Hekubas,
Please allow me time to further investigate our issue internally; I might replicate the issue that we have in our lab.
I'll get back to you as soon as I have an update on our case.
Thank you so much for your patience.
Carmona A.
BannHead
Hi Mod,
The Off The Grid game crashes if the Global Illumination Quality parameter is set to low
BannHead
Hi hekubas,
I had the same problems as you with Off The Grid. To avoid crashing you must not set Global Illumination Quality to low.
On my PC to have fps above 40 I have to set everything to low except for that parameter, and FSR to performance.
To be able to restart it you can edit the configuration file, setting sg.GlobalIlluminationQuality to 2 or higher
GG
EDIT:
Go to
%USERPROFILE%\Saved Games\OTG\
Open this
GzGameUserSettings.json
Change
"globalIlluminationQuality"
ACarmona_Intel
Hello Hekubas,
Thank you for patiently waiting on my update.
To further investigate the issue, please provide the following information below:
1. Which graphics settings are you changing that causes the issue?
2. Is the problem occurring only with "Off the Grid" now? Based on the information, the issue with "The First Descendant" seems to be resolved.
3. Have you used DDU (Display Driver Uninstaller) when installing the latest graphics driver? If not, please perform a DDU and then install the latest driver.
4. Is it possible that you can share your game settings with me so I can better replicate the issue?
5. Are there any error messages when "Off the Grid" crashes?
6. Is it feasible that you can share with me the event viewer logs? This will help me determine the root cause of the crash and the timestamp when it occurs.
By the way, you may also try the recommendation provided by @BannHead, as it appears that he has the same problem as ours and has already discovered a workaround or solution.
I will be waiting for your response!
Carmona A.
ACarmona_Intel
Hello Hekubas,
Regarding our case, we are following up to check if you already have the answers to our questions so we can further analyze our issue.
And also, if you have any questions, please let me know.
I look forward to your response!
Carmona A.
ACarmona_Intel
Hello Hekubas,
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Carmona A.
ACarmona_Intel
Hello Hekubas,
I hope you are doing well.
Since I have not heard back from you, I will now be closing our case.
If, in case you are just busy and still needed assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
