Intel® Arc™ Discrete Graphics
3563 Discussions
Intel Graphics Panel on Lenovo Thinkpad laptop
msharif77
Hi guys I am new here and I don't know if I am posting this question under correct category/subcategory or not.
I recently purchased a Lenovo Thinkpad T490s (8th Gen intel) core i5. Each time I plug in or plug out the charger, the display flickers (turns black) for a few milliseconds. I found it was due to the refresh rate being different (plugged in 60Hz and plugged out 48Hz). I tried every possible method I know of or from online forums, I am not able to force the refresh rate stay at 60Hz (either on charge or battery).
I downloaded the Intel Graphics Driver from Lenovo's official website, when I install it, I don't either see the tray icon for intel graphics software nor do I see any option for intel graphics control center (when I right click on desktop).
I installed different versions of windows 10 and 11 but the issue persists and I can't gain access to the intel graphics control center where I can keep the refresh rate constant.
It is extremely annoying as I have been trying several methods/3rd party softwares since a few days but nothing seems to be working.
Any solution please?
The video drivers I use are:
(https://pcsupport.lenovo.com/us/en/products/laptops-and-netbooks/thinkpad-t-series-laptops/thinkpad-t490s-type-20nx-20ny/downloads/driver-list/component?name=Display%20and%20Video%20Graphics&id=635380F4-448F-4129-AA77-265289D96F6F
DhannielM_Intel
Hello msharif77,
Thank you for contributing to the community! Occasionally, the Intel Graphics Command Center (IGCC) might not appear in the system tray unless it has been opened. To locate it, try searching for "Intel Graphics Command Center" in your Windows search bar. If you still can't find it, you can download the application from the Microsoft Store under the name "Intel Graphics Command Center (Beta)."
After installing the IGCC on your system, please follow the steps outlined below:
  • Disable Dynamic Refresh Rate Switching in IGCC (Intel Graphics Command Center)
  1. Open IGCC.
  2. Go to System.
  3. Set Dynamic Refresh Rate Switching to Off.
  • Disable Power Saving Mode in IGCC
  1. Open IGCC.
  2. Go to power settings.
  3. Set Power Saving Mode to Off.
Additionally, can you answer the following questions below:
  • When installing the graphics driver, have you attempted a "Clean Installation" or used the Display Driver Uninstaller (DDU)?
  • Have you tested with the latest graphics driver available on the Intel website?
  • Have you reached out to Lenovo for additional support?
Additionally, I want to set the right expectations regarding this issue. Since you are using a Lenovo laptop, which is an Original Equipment Manufacturer (OEM) device, I can only provide general troubleshooting advice. If these steps do not resolve the issue, I recommend contacting Lenovo's support team for further assistance.
Dhanniel M.
DhannielM_Intel
Hello msharif77,
I'm reaching out to see if you've had a chance to review the recommendations and questions I included in my previous response. Please feel free to share your answers with me at your earliest convenience.
Dhanniel M.
DhannielM_Intel
Hello msharif77,
As I haven't heard back from you, I encourage you to try my recommendation. If the issue persists, I suggest reaching out to your laptop manufacturer for further assistance. Since I haven't received a response, I will be closing this inquiry. If you need additional help, please feel free to submit a new question, as this thread will no longer be monitored.
Dhanniel M.
