Intel® Arc™ Discrete Graphics
4336 Discussions
Intel Graphics Software Needs Urgent Updates: XeSS Frame Gen Limitation
Jaynus-
Hi everyone,
I’m an Intel Arc A750 user. While I truly appreciate the hardware quality and the potential of the Arc architecture, I believe the biggest bottleneck for Arc users right now is the Intel Graphics Software ecosystem. I’ve prepared a detailed report outlining the missing features and performance issues that need to be addressed for the platform to compete with NVIDIA and AMD.
1. XeSS Frame Generation and Profile Inconsistency
Currently, the 2x/3x/4x Frame Generation Override feature is visible and functional in the Intel Graphics Software profile tab for Battlefield 6 (BF6). However, this critical feature is missing for almost all other games (for example, ARC Raiders).
Request:
Why is Frame Generation limited to specific game profiles? We need this to become a universal option within the software for all DX11, DX12, and Vulkan titles.
2. Missing Core Display and User Experience Features
The current state of Intel Graphics Software lacks basic quality-of-life settings that have been industry standard for over a decade:
  • Custom Resolutions: There is still no proper, integrated way to create custom resolutions directly within the software.
  • Professional Color Calibration: The existing color tools are extremely basic. To match the visual output of competing GPUs, we need professional-level controls for vibrance, saturation, and gamma.
  • Right-Click Menu Integration: One of the most requested features — Intel Graphics Software should appear in the desktop right-click context menu for quick access.
3. Performance and Optimization Bottlenecks
I noticed a specific issue in BF6: when I enable 2x Frame Generation, I see around 200 FPS, but the experience feels stuttery — as if it’s running at 80–90 FPS. Even though the FPS counter shows high numbers, GPU utilization appears to behave as if it’s running at 80–90 FPS, and overall smoothness is not as it should be.
When Frame Generation is active, there seems to be a clear optimization gap in how the software manages frame pacing and GPU utilization.
4. Missing “Advanced 3D Settings” List
For hardware enthusiasts and competitive players, Intel Graphics Software lacks critical driver-level settings. We would like to see the following added to the Graphics tab (at minimum, in my opinion):
  • DSR Factors
  • Texture Filtering – Quality
  • Texture Filtering – Anisotropic Sample Optimization
  • Texture Filtering – Negative LOD Bias
  • Texture Filtering – Trilinear Optimization
  • Vertical Sync
  • Low Latency Mode
  • Anisotropic Filtering
  • Shader Cache Size
  • Power Management Mode
  • Anti-Aliasing Mode
  • Anti-Aliasing – FXAA
  • Anti-Aliasing – Gamma Correction
  • Anti-Aliasing – Mode
  • Maximum Frame Rate
  • Monitor Technology
  • OpenGL GDI Compatibility
  • OpenGL Rendering GPU
  • Ambient Occlusion
  • Vulkan/OpenGL Present Method
  • Image Settings Preset (Performance / Quality options)
Conclusion
Intel Arc hardware has incredible potential, but Intel Graphics Software feels unfinished. For this ecosystem to grow, we need strong game profiles, automatic optimization, and a software package that doesn’t feel like a stripped-down version of its competitors.
I’m curious whether other Arc users are experiencing the same software limitations.
CaNeBuRy23
New Contributor II
it's like a GPT format Bro,
anyway.. First off, I feel you. You’re not wrong. The Intel Arc A750 hardware? Solid. Punches above its weight. But the software side? Yeah… it’s still catching up. Now let’s break this down. You’re absolutely right to question why Frame Gen override shows up for one title like Battlefield but not others. That’s not random. Frame Generation and certain overrides are often whitelisted per game profile because stability, motion vectors, and engine behavior differ per title. If Intel just unlocked it globally for every DX11/DX12/Vulkan game, we’d probably see crashes, artifacts, or wild frame pacing issues.
Now about that “200 FPS but feels like 80 FPS” situation, that screams frame pacing issue, not raw performance. Frame Gen can inflate FPS counters, but if frame delivery isn’t consistent, it feels stuttery. That’s optimization territory. Not hardware weakness. Software scheduling and pacing need refinement.
Yeah… that one’s hard to argue. Custom resolution support and right-click desktop access are basic quality-of-life things in 2026. Those should absolutely be tighter and more integrated.
Now, if you want this to actually move the needle, I’d suggest:
  1. Testing with Frame Gen + V-Sync on/off combinations to isolate pacing behavior
  2. If you’re seeing 200 FPS with 2x Frame Generation on your Intel Arc A750 but it feels like 80–90 FPS, that’s almost certainly a frame pacing issue rather than a raw performance limitation. Frame Generation can inflate FPS numbers, but if frame delivery isn’t consistent, it will feel stuttery. The first thing I recommend is setting an FPS cap slightly below your monitor’s refresh rate
  3. Use the in-game limiter if available, or a tool like RTSS. At the same time, disable in-game V-Sync and avoid stacking multiple sync technologies together. Let your monitor’s Adaptive Sync handle synchronization if supported. Running Frame Generation uncapped with V-Sync layered on top is a common cause of inconsistent smoothness.
