Intel® Arc™ Discrete Graphics
4079 Discussions
Intel Graphics Software installation problems - cannot install
JanG2
Dear All,
I have Win11 on a HP laptop.
I updated the Intel Arc driver to its newest version and wanted to install also the Intel Graphics Software in order to have some customisation options.
However I tried several times - every time I do it with there is a problem and the installer finishes its work with statement that IGS could not be installed (ver. 25.44.2010.4).
I read through the forums here and tried to:
-uninstall intel support & driver assistant
-uninstall all NET.framework versions
without any help.
I also tried to run it directly by clicking the IGS installer after unpacking the driver&sotware. Strange thing - at first it had to uninstall the IGS so it seems like it got somehow installed, but I couldn't find any program with such name in Start Menu, Search and therefore couldn't open the console of IGS.
So I uninstalled what has been installed and ran the installer ones again but this time pressed to install IGS. However after few minutes of installation process I got few upcoming alerts that "Service 'Intel Graphics Software' could not be deleeted. Verify that you have sufficient privileges to remove system services". Simultaneously in the list of installed applications in the computer new apps show up - again several new NET.framework applications, that were previously uninstalled.
At the end I get an alert Setup Failed due to erro 0x80070643 with the log file (attached below).
Anyone can offer help with this please?
VonM_Intel
Hi JanG2,
Thank you for posting in our Community.
Based on your description, it appears that the Intel® Graphics Software (IGS) installation is being blocked by a service or framework conflict, which may explain the repeated reinstallation of .NET components and the error 0x80070643. The message indicating that the “Intel Graphics Software” service could not be deleted also suggests a possible permission, leftover service, or OEM restriction issue on the system. To help me narrow this down and determine the best resolution, could you please provide the following details?
  • What is the exact HP laptop model you are using?
  • Are you logged in using a local administrator account, and have you tried running the installer explicitly as Administrator?
  • Was the Intel® Arc™ graphics driver installed using:
    • Intel’s generic driver, or
    • An HP-provided (OEM) graphics driver?
  • Have you checked whether HP Command Center / HP graphics utilities are installed? These can sometimes block or override Intel Graphics Software installation.
  • Could you confirm your current Windows 11 version and build number?
  • If available, could you please share the Intel® System Support Utility (SSU) report to review the system configuration in detail?
In some OEM systems, graphics customization tools are controlled by the manufacturer, which may prevent Intel Graphics Software from installing correctly unless the OEM-supported driver stack is used.
Have a nice day!
Von M.
VonM_Intel
Hello JanG2,
Have a nice day!
Von M.
JanG2
I had a chance to get support from your support service.
Had to install a driver from the website dedicated to my processor 165H and the installation went smoothly and now I have IGS running.
Thank you for your assistance!
VonM_Intel
Hello JanG2,
Thank you for the update. I'm glad to hear the driver from the processor-specific page for the 165H installed successfully and that IGS is now running as expected. Since the issue has been resolved, I’ll go ahead and close this inquiry. If you have any additional questions or need further assistance in the future, please feel free to submit a new question, as this thread will no longer be monitored. I’ll be happy to help.
Von M.
