Intel® Arc™ Discrete Graphics
3563 Discussions
Intel arc a770 limites édition Big problèmes whit performance in games
axolotenul
Hello i'm asking for help because i have Big problems with my games with my New Intel arc770 limited édition my performance is so bad that i no longer enjoy playing games for exemple fornite in performance mode all un low run at 100fps whit little lag sometime and if i Switch to directx12 i can't even play because i run in 0-15fps with Big lag and its the same with the other games i have already updated all the drivers and i have already activated the resizable bar i ask you to help me please .
Jean_Intel
Hello axolotenul,
Thank you for posting in the Intel Communities. We would be more than happy to assist you with the performance issue with Fortnite. We also understand that other games are experiencing performance problems; however, we recommend reporting one issue per thread to keep the thread organized. Thus, we invite you to open other threads about the other affected games so we can further help you.
To further assist you on the Fortnite performance issue, we would like to ask for the following details:
  • When did the issue start? Was it after a hardware or software change?
  • Was there another graphics card before you installed the Intel Arc A770 Limited Edition?
  • When you use the DX12 mode, do you also use the performance mode for the game?
  • Is this performance issue related to a specific game mode or location?
  • Provide us with a screenshot of the video settings you used.
  • So we can have more details about the system, please share with us an Intel System Support Utility (Intel SSU) report:
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan, click "Next" and "Save."
Best regards
Jean O.
axolotenul
Le problème a commencé depuis l'installation de la carte graphique. Il y avait une rtx 2060 super oc . Oui . Je ne pense pas . Désoler je ne peut pas envoyer de capture d'écran mes paramètres sur fornite son plein écran fenêtre 1930x1080 16:9 synchro verticale non taux de rafraîchissement illimité performance qualité visuelle resolution 3d 0pourcent non proche faible faible . Voilà le ssu mon défaut »
Type de système : « PC x64 »
- "Afficher"
Version du pilote graphique Intel ® : « Non disponible »
- "Graphiques Intel(R) Arc(TM) A770"
Compatibilité de l'adaptateur : "Intel Corporation"
Type d'adaptateur DAC : "interne"
RAM de l'adaptateur : "1,00 Go"
Disponibilité : "En fonctionnement ou à pleine puissance"
Bits par pixel : « 32 »
- "Légende": "Graphique Intel(R) Arc(TM) A770"
Lien : "http://www.intel.com/content/www/us/en/search.html?keyword=Arc+A770+Graphics"
Coinstallateurs : "oem41.inf, iDG2_Client_FWU_w10_DS, interne, famille de graphiques Intel(R) Arc(TM) A770"
Entrées de la table des couleurs : "4294967296"
Mémoire vidéo dédiée : « Non disponible »
Pilote : "igdkmdnd64.sys"
Date du conducteur : "21/12/2023 01:00"
Chemin du pilote : "C:\WINDOWS\system32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igdkmdnd64.sys"
Fournisseur de pilotes : « Intel Corporation »
Version du pilote : « 31.0.101.5084 »
INF : "oem41.inf"
Section INF : "iDG2_Client_FWU_w10_DS"
Date d'installation : « Non disponible »
Pilotes installés : "C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igdumdim64.dll, C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igd10iumd64 .dll,C:\WINDOWS\System32\DriverStore "
Dernier code d'erreur : « Non disponible »
Description du dernier code d'erreur : « Non disponible »
Dernière réinitialisation : « Non disponible »
Emplacement : "Bus PCI 3, périphérique 0, fonction 0"
Fabricant : « Intel Corporation »
Version Microsoft DirectX* : « DirectX 12 »
Monochrome : "Non"
Nombre de couleurs : « 4294967296 »
Nombre de pages vidéo : « Non disponible »
ID de périphérique PNP : "PCI\VEN_8086&DEV_56A0&SUBSYS_10208086&REV_08\6&3734951C&0&00080008"
Capacités de gestion de l'alimentation : « Non disponible »
Gestion de l'alimentation prise en charge : « Non disponible »
Taux de rafraîchissement - Courant : "60 Hz"
Taux de rafraîchissement - Maximum : "75 Hz"
Taux de rafraîchissement - Minimum : "50 Hz"
Résolution : "1920 X 1080"
Mode de numérisation : « Non entrelacé »
Nom du service : "igfxnd"
Statut : "OK"
Architecture vidéo : "VGA"
Mémoire vidéo : « Inconnue »
Processeur vidéo : "Famille graphique Intel(R) Arc(TM) A770"
- "Mémoire"
Mémoire physique (disponible) : « 10,17 Go »
Mémoire physique (installée) : « 16 Go »
Mémoire physique (totale): "15,90 Go"
- "BANQUE 0"
Capacité : « 8 Go »
Canal : "Contrôleur0-ChannelA"
Vitesse d'horloge configurée : « 2 667 MHz »
Tension configurée : « 1 350 millivolts »
Largeur des données : "64 bits"
Facteur de forme : « DIMM »
Position entrelacée : « Première position »
Fabricant : "G Skill Intl"
Tension maximale : « Non disponible »
Type de mémoire : « Inconnu »
Tension minimale : « Non disponible »
Numéro de pièce : « F4-3200C16-8GIS »
Numéro de série : "00000000"
Statut : « Non disponible »
Tapez : « Synchrone »
- "BANQUE 1"
Capacité : « 8 Go »
Canal : "Contrôleur0-ChannelB"
Position entrelacée : "Deuxième position"
- "Carte mère"
BIOS : "1.20, ALASKA - 1072009"
Légende : "Carte-mère"
Chipset : « Non disponible »
Date :"01/11/2022 01:00"
Fabricant : "Micro-Star International Co., Ltd."
Modèle : « Non disponible »
Numéro de pièce : « Non disponible »
ID de périphérique PNP : « Non disponible »
Produit : "H510M PRO-E (MS-7D23)"
Numéro de série : "07D2312_M11E321595"
Statut : "OK"
Version : "1.0"
- "La mise en réseau"
Options d'installation des connexions réseau Intel ® : « Non disponible »
Version des connexions réseau Intel® : « Non disponible »
Version du logiciel Intel® PROSet/Wireless : « Non disponible »
- "Contrôleur de la famille Realtek PCIe GbE"
Légende : « Contrôleur de la famille Realtek PCIe GbE »
Coinstallateurs : « Non disponible »
Passerelle IP par défaut : "192.168.1.254;fe80::8a0f:a2ff:fecf:ee05"
DHCP activé : "Oui"
Le bail DHCP expire : "01/12/2024 11:39"
Bail DHCP obtenu : "01/11/2024 11:39"
Serveur DHCP : « 192.168.1.254 »
Pilote : "rt640x64.sys"
Date du conducteur : "11/11/2021 12h00"
Chemin du pilote : "C:\WINDOWS\system32\drivers\rt640x64.sys"
Fournisseur de pilotes : « Realtek »
Version du pilote : « 10.54.1111.2021 »
Indice : "0001"
INF : "oem17.inf"
Section INF : "RTL8168H.ndi.NT"
Installé : "Oui"
Adresse IP : "192.168.1.128;fe80::1c7a:5be0:342a:b529;2001:861:57c2:6b00:d4f8:2194:3e1d:d2ac;2001:861:57c2:6b00:1ad5:71d0:9707:7a36 "
Sous-réseau IP : "255.255.255.0;64;128;64"
Dernière réinitialisation : "01/11/2024 11:36"
Emplacement : "Bus PCI 5, périphérique 0, fonction 0"
Adresse MAC : "D8:BB:C1:D5:2C:8A"
Fabricant: "Realtek"
ID de connexion réseau : "Ethernet"
NetCfgInstanceId : "{8340BE42-2610-4D03-B545-9298F091C41A}"
ID de périphérique PNP : "PCI\VEN_10EC&DEV_8168&SUBSYS_7D231462&REV_15\4&7CC7CAC&0&00E0"
Port : « Non disponible »
Gestion de l'alimentation (faible consommation) : « non disponible »
Gestion de l'alimentation (Wake On LAN) : « Non disponible »
Gestion de l'alimentation (Wake on Magic Packet) : « Non disponible »
Gestion de l'alimentation prise en charge : « Non »
Type de produit : « Contrôleur de la famille Realtek PCIe GbE »
Nom du service : "rt640x64"
Statut : "Activé"
Tapez : "Ethernet 802.3"
- "Liaisons de service"
Client pour les réseaux Microsoft :
Partage de fichiers et imprimantes Réseaux Microsoft :
Pilote de protocole LLDP Microsoft :
Pilote E/S de mappage de découverte de topologie de la couche de liaison :
Planificateur de paquets QoS :
Protocole Internet version 4 (TCP/IPv4) :
Protocole Internet version 6 (TCP/IPv6) :
Répondeur de découverte de la topologie de la couche de liaison :
- "Paramètres"
*EEE:Ethernet à économie d'énergie:"Activé (1)"
*FlowControl:Contrôle de flux:"Rx & Tx activé (3)"
*InterruptModeration :Interruption de modération :"Activé (1)"
*IPChecksumOffloadIPv4:IPv4 Somme de contrôle hors charge:"Rx & Tx activé (3)"
*JumboPacket:Cadre jumbo:"Désactivé (1514)"
*LsoV2IPv4:Grand envoi hors charge v2 (IPv4):"Activé (1)"
*LsoV2IPv6:Grand envoi hors charge v2 (IPv6):"Activé (1)"
*ModernStandbyWoLMagicPacket : Réveil sur paquet magique lorsque le système est dans l'état d'alimentation S0ix : "Désactivé (0)"
*NumRssQueues:Nombre maximum de fichiers d'attente RSS:"4 fichiers d'attente (4)"
*PMARPOffload:Décharge ARP:"Activé (1)"
*PMNSOffload:Décharge NS:"Activé (1)"
*PriorityVLANTag:Priorité & VLAN:"Priorité & VLAN activé (3)"
*ReceiveBuffers:Mémoires tampon de réception:"512 (512)"
*RSS:Echelle côté réception:"Activé (1)"
*SpeedDuplex:Vitesse & Duplex:"Négociation auto (0)"
*TCPChecksumOffloadIPv4:TCP Somme de contrôle hors charge (IPv4):"Rx & Tx activé (3)"
*TCPChecksumOffloadIPv6:TCP Somme de contrôle hors charge (IPv6):"Rx & Tx activé (3)"
*TransmitBuffers:Mémoires tampon de transmission:"128 (128)"
*UDPChecksumOffloadIPv4:UDP Somme de contrôle hors charge (IPv4):"Rx & Tx activé (3)"
*UDPChecksumOffloadIPv6:UDP Somme de contrôle hors charge (IPv6):"Rx & Tx activé (3)"
*WakeOnMagicPacket:Réveil sur Magic Packet:"Activé (1)"
*WakeOnPattern:Avertir lors de la correspondance de motif:"Activé (1)"
AdvancedEEE:Advanced EEE:"Désactivé (0)"
AutoDisableGigabit:Désactiver auto gigaoctet:"Désactivé (0)"
EnableGreenEthernet:Ethernet vert:"Activé (1)"
GigaLite:Gigabit Lite:"Activé (1)"
Mode d'économie d'énergie : Mode d'économie d'énergie : "Activé (1)"
RegVlanid : ID de VLAN : "0 (0)"
S5WakeOnLan:Arrêt Réveil par réseau:"Activé (1)"
WolShutdownLinkSpeed:WoL / Arrêt vitesse réseau:"10 Mbps en premier (0)"
- "Système opérateur"
Version du framework .Net : "2.0,3.0,3.5,4.0,4.8"
Périphérique de démarrage : "\Device\HarddiskVolume4"
Navigateur Internet : « Internet Explorer, 11.3636, Microsoft Edge, 120.0 »
Localité : "France"
Fabricant du système d'exploitation : "Microsoft Corporation"
Nom du système d'exploitation : « Microsoft Windows 10 Professionnel »
Description d'un autre système d'exploitation : « Non disponible »
Fichier d'échange : "C:\pagefile.sys"
Espace du fichier de page : « 7,50 Go »
Mémoire physique (disponible) : « 10,18 Go »
Répertoire système : "C:\WINDOWS\system32"
Version : « 10.0.19045, version 19045 »
Mémoire virtuelle (disponible) : « 12,91 Go »
Mémoire virtuelle (totale): "23,40 Go"
Répertoire Windows : "C:\WINDOWS"
- "Mises à jour installées"
KB2468871 : « Microsoft .NET Framework 4 étendu [non disponible] »
KB2468871 : « Profil client Microsoft .NET Framework 4 [non disponible] »
KB2468871v2 : « Profil client Microsoft .NET Framework 4 [non disponible] »
KB2468871v2 : « Microsoft .NET Framework 4 étendu [non disponible] »
KB2478063 : « Profil client Microsoft .NET Framework 4 [non disponible] »
KB2478063 : « Microsoft .NET Framework 4 étendu [non disponible] »
KB2533523 : « Profil client Microsoft .NET Framework 4 [non disponible] »
KB2533523 : « Microsoft .NET Framework 4 étendu [non disponible] »
KB2544514 : « Profil client Microsoft .NET Framework 4 [non disponible] »
KB2544514 : « Microsoft .NET Framework 4 étendu [non disponible] »
KB2600211 : « Profil client Microsoft .NET Framework 4 [non disponible] »
KB2600211 : « Microsoft .NET Framework 4 étendu [non disponible] »
KB2600217 : « Profil client Microsoft .NET Framework 4 [non disponible] »
KB2600217 : « Microsoft .NET Framework 4 étendu [non disponible] »
KB5011048 : « Mise à jour [30/12/2023] »
KB5011058 : « Mise à jour [30/12/2023] »
KB5012170 : « Mise à jour de sécurité [30/12/2023] »
KB5014032 : « Mise à jour de sécurité [30/12/2023] »
KB5015684 : « Mise à jour [30/12/2023] »
KB5016705 : « Mise à jour [30/12/2023] »
KB5020372 : « Mise à jour [30/12/2023] »
KB5020683 : « Mise à jour [30/12/2023] »
KB5022924 : « Mise à jour [30/12/2023] »
KB5023794 : « Mise à jour [30/12/2023] »
KB5025183 : « Mise à jour [30/12/2023] »
KB5025315 : « Mise à jour [30/12/2023] »
KB5025801 : « Mise à jour [30/12/2023] »
KB5026879 : « Mise à jour [30/12/2023] »
KB5028318 : « Mise à jour [30/12/2023] »
KB5028380 : « Mise à jour [30/12/2023] »
KB5029709 : « Mise à jour [30/12/2023] »
KB5031539 : « Mise à jour [30/12/2023] »
KB5032392 : « Mise à jour [30/12/2023] »
KB5032907 : « Mise à jour [30/12/2023] »
KB5033918 : « Mise à jour [1/9/2024] »
KB5034122 : « Mise à jour de sécurité [1/9/2024] »
Microsoft ASP.NET Core 7.0.7 - Framework partagé (x64) : ".NET [30/12/2023]"
- "Processeur"
- "Processeur Intel(R) Core(TM) i3-10105F à 3,70 GHz"
Architecture : "x64"
ATPO : « Non disponible »
Légende : « Intel64 famille 6 modèle 165 Stepping 3 »
- "Nom du chipset": CPU Intel(R) Core(TM) i3-10105F à 3,70 GHz »
Lien : "http://www.intel.com/content/www/us/en/search.html?keyword=Core+i3+10105F+CPU+"
Vitesse du processeur : « 3 696 GHz »
Tension actuelle : "1,6 volts"
Pilote : « Non disponible »
Date du conducteur : "21/04/2009 12h00"
Chemin du pilote : "C:\WINDOWS\system32\drivers\intelppm.sys"
Fournisseur de pilotes : « Microsoft »
Version du pilote : « 10.0.19041.3636 »
Poste Famille : « Non disponible »
FPO : « Non disponible »
INF : "cpu.inf"
Section INF : « IntelPPM_Inst.NT »
Cache niveau 1 : « 4 x 256 Ko »
Cache niveau 2 : « 4 x 1 024 Ko »
Cache niveau 3 : « 6 Mo »
Charge : « 9 % »
Fabricant : « Authentique Intel »
Modèle:"165"
Nom : « Processeur Intel(R) Core(TM) i3-10105F à 3,70 GHz »
Nombre de cœurs : « 4 »
Nombre de cœurs activés : « 4 »
Nombre de processeurs logiques : « 8 »
Numéro de pièce : « à remplir par OEM »
ID du processeur : "BFEBFBFF000A0653"
Révision : « Non disponible »
Numéro de série : « À remplir par l'OEM »
Nom du service : "Intelppm"
Statut : "OK"
Pas à pas : « 3 »
Version : « Non disponible »
- "Stockage"
- "SAMSUNG HD103UJ"
Capacités : « Accès aléatoire, prend en charge l'écriture, notification SMART »
Légende : « SAMSUNG HD103UJ »
Cylindre - Total : "121601"
Description:"Lecteur de disque"
Date du conducteur : "21/06/2006 12h00"
Code d'erreur : "L'appareil fonctionne correctement"
Révision du micrologiciel : « 1AA01113 »
Têtes - Total : "255"
Indice : "0"
INF : "disque.inf"
Type d'interface : "IDE"
Fabricant:"(Lecteurs de disque standard)"
Modèle : « SAMSUNG HD103UJ »
Nom : "\\.\PHYSICALDRIVE0"
Partitions : « 1 »
Taille du secteur physique : « 512 »
ID du périphérique PNP : "SCSI\DISK&VEN_SAMSUNG&PROD_HD103UJ\4&10077EA0&0&000000"
Stratégies : « Priorité de rétention en lecture = EqualPriority, Priorité de rétention en écriture = EqualPriority, Scalar Prefetch = Non disponible, Block Prefetch = Non disponible »
Secteurs - Par piste : "63"
Secteurs - Total:"1953520065"
Numéro de série : "S13PJ9BQC14809"
Taille:"931,51 Go"
Taille – Disponible : « 508,33 Go »
Attributs SMART : « Auto-test : 191 minutes, OK, Auto-test court : 2 minutes, OK »
Statut : "OK"
Pistes - Par cylindre : « 255 »
Pistes - Total : "3 100 8255 »
- "D:"
Disponibilité : « Non disponible »
Légende : « D : »
Méthode de compression : « Non compressé »
Description:"Disque monté local"
Système de fichiers : "NTFS"
Nom : "jeux"
Numéro de série : « 4297DEFA »
Taille:"931,510738372803 Go"
Taille – Disponible : "508,331024169922 Go"
Volume sale : "Non"
- "INTELLIGENT"
0x01 Taux d'erreur de lecture brute : 0 : "51"
0x03 Temps de rotation : 8610 : "11"
0x04 Nombre de démarrages/arrêts : 27053 : "0"
0x05 Nombre de secteurs réaffectés :0 : "10"
0x07 Taux d'erreur de recherche : 0 : "51"
0x08 Performances de la minuterie de recherche :0 : "15"
0x09 Heures de mise sous tension : 35491 : "0"
0x0A Nombre de nouvelles tentatives : 1 : "51"
Nombre de tentatives d'étalonnage 0x0B : 0 : "0"
0x0C Nombre de cycles d'alimentation : 7917 : "0"
Taux d'erreur de lecture logicielle 0x0D : 0 : "0"
0xB7 Nombre de rétrogradations SATA : 0 : "0"
0xB8 Nombre de détections d'erreurs de bout en bout : 0 : "0"
0xBB Nombre d'erreurs non corrigibles : 0 : "0"
0xBC Délais d'expiration des commandes signalés :0 : "0"
0xBE Température - Courant : 18 ° C : "0"
Température 0xBE - La plus élevée : 18 ° C : "0"
Température 0xBE - La plus basse : 7 ° C : "0"
0xC2 Température interne de l'appareil : 24 ° C : "0"
0xC3 Matériel ECC récupéré : 32164 : "0"
Nombre de réallocations 0xC4 :0 : "0"
0xC5 Nombre d'erreurs en attente actuelles : 0 : "0"
0xC6 Nombre de secteurs non corrigibles : 0 : "0"
Nombre d'erreurs CRC 0xC7 : 0 : "0"
Taux d'erreur d'écriture 0xC8 :0 : "0"
0xC9 Taux d'erreur de lecture logicielle : 0 : "0"
- "SanDisk SDSSDA240G"
Légende : « SanDisk SDSSDA240G »
Cylindre - Total : "29185"
Révision du micrologiciel : « Z32080RL »
Indice : « 2 »
INF : "disque.inf"
Modèle : « SanDisk SDSSDA240G »
Nom : "\\.\PHYSICALDRIVE2"
Partitions : « 3 »
ID du périphérique PNP : "SCSI\DISK&VEN_SANDISK&PROD_SDSSDA240G\4&10077EA0&0&030000"
Secteurs - Total : "468857025"
Numéro de série : « 170104457010 »
Taille:"223,57 Go"
Taille – Disponible : « 133,87 Go »
Attributs SMART : « Auto-test : 10 minutes, OK, Auto-test court : 2 minutes, OK »
Statut : "OK"
Pistes - Total : "7442175"
- "C:"
Légende : « C : »
Nom non disponible"
Numéro de série : "0E0DEEDC"
Taille:"222,847549438477 Go"
Taille – Disponible : "133,872737884521 Go"
Volume sale : "Non"
- "INTELLIGENT"
0x0C Nombre de cycles d'alimentation : 1623 : "0"
0xAA Espace réservé disponible :0 : "0"
Nombre d'échecs du programme 0xAB : 0 : "0"
0xAC Nombre d'échecs d'effacement : 0 : "0"
0xAD Nombre de niveaux d'usure : 72 : "0"
0xAE Nombre de retraits de mise hors tension : 164 : "0"
0xC2 Température interne de l'appareil : 35 ° C : "0"
0xE6 État de protection de la durée de vie du lecteur : 5935712699750 : « 0 »
0xE8 Espace réservé disponible : 100 : "0"
Indicateur d'usure du support 0xE9 : 17277 : "0"
0xEA Nombre maximum d'effacements : 39202 : "0"
0xF1 Nombre total de LBA écrits : 24462 : "0"
0xF2 Total LBA lu : 23358 : "0"
- "ST500LM021-1KJ152"
Légende : "ST500LM021-1KJ152"
Cylindre - Total : "60801"
Révision du micrologiciel : « 0005SDM1 »
Indice : « 1 »
INF : "disque.inf"
Modèle : « ST500LM021-1KJ152 »
Nom : "\\.\PHYSICALDRIVE1"
Partitions : « 1 »
Taille du secteur physique : « 4096 »
ID de périphérique PNP : "SCSI\DISK&VEN_&PROD_ST500LM021-1KJ15\4&10077EA0&0&010000"
Secteurs - Total : "976768065"
Numéro de série : « W62G69Z3 »
Taille:"465,76 Go"
Taille – Disponible : « 458,19 Go »
Attributs SMART : "Auto-test : 79 minutes, OK, Auto-test court : 1 minute, OK"
Statut : "OK"
Pistes - Total : "15504255"
- "E :"
Légende : « E : »
Name:"logiciel et travaille"
Numéro de série : « 24237E08 »
Taille:"465,745113372803 Go"
Taille – Disponible : "458,188312530518 Go"
Volume sale : "Non"
- "INTELLIGENT"
0x01 Taux d'erreur de lecture brute : 69769624 : "51"
0x03 Temps de rotation :0 : "11"
0x04 Nombre de démarrages/arrêts : 20827 : "0"
0x07 Taux d'erreur de recherche : 144378069 : "51"
0x09 Heures de mise sous tension : 8710 : "0"
0x0A Nombre de nouvelles tentatives de rotation : 0 : "51"
0x0C Nombre de cycles d'alimentation : 5354 : "0"
0xBD High Fly écrit : 0 : "0"
0xBE Température - Courant : 22 ° C : "0"
Température 0xBE - La plus élevée : 22 ° C : "0"
Température 0xBE - La plus basse : 14 ° C : "0"
0xBF Taux G-sense/Suivi servo : 191 : "0"
0xC0 Nombre d'arrêts non sécurisés : 23 : "0"
0xC1 Nombre de cycles de chargement/déchargement : 134898 : "0"
0xC2 Température interne de l'appareil : 22 ° C : "0"
0xF0 Heures de vol de la tête : 6266 : "0"
0xF1 Nombre total de LBA écrits : 49956112627 : "0"
0xF2 Total LBA lu : 50125455023 : "0"
0xFE Protection contre les chutes libres :26 : "0"
...#SSU#...
Jean_Intel
Hello axolotenul,
Thank you for the information provided, and we apologize for the delay in our response, as it has been visible to us until recently (it seems that the post was marked as Spam automatically). Nevertheless, as you mentioned that you previously had an RTX 2060 Super OC, we would recommend you run the Display Driver Uninstaller (DDU) to eliminate all the previous driver files and leftovers, and then you should install the new Intel Graphics driver 31.0.101.5085/31.0.101.5122 (WHQL Certified)
Best regards
Jean O.
Jean_Intel
Hello axolotenul,
We are checking in your case to see if you have been able to test the new driver 31.0.101.5085/31.0.101.5122 (WHQL Certified), after running the DDU software to eliminate all the previous graphics drivers. Let us know if the problem remains.
Best regards
Jean O.
Jean_Intel
Hello axolotenul
Unfortunately, since we have not heard back from you, we will proceed to close this thread. If you have any other questions, please submit a new thread, as this one will no longer be monitored.
Best regards
Jean O.
