Intel® Arc™ Discrete Graphics
4043 Discussions
Minecraft最新快照版26.2的VulkanAPI表现极差,基于最新8629驱动
Azure_Archives
快照版糟糕的性能表现让我不禁对后续的minecraft版本改用Vulkan后的性能表现抱有忧虑。以前采用OpenGL的minecraft在b580上表现普遍糟糕,我希望采用vulkan的新minecraft将可以获得足够优秀的性能表现,而不是现在这样:Screenshot 2026-04-08 105021.png在默认图形设置下,打开无上限帧数,关闭垂直同步后只能运行在60FPS左右
(我实在HMCL启动器里面设置Vulkan API,所以游戏设置内显示为默认)
当然更多情况是这样:
直接报错“The game crashed because of a problem with your graphics driver”
CM_Intel
Hello Azure_Archives,
请注意,我只能用英语支持你。我用网络翻译工具翻译了这条回复;因此,可能存在一些不准确的翻译。
Thank you for posting your query on the Intel Community Forum.
I understand that you’re encountering low frame rates and repeated graphics driver–related crashes while running Minecraft snapshot version 26.2 using Vulkan on the Intel Arc B580.
To assist you further and investigate the issue more effectively, I kindly request that you provide the following details:
1. SSU (System Support Utility) Report
You can download the SSU tool using the link below:
Please note: While generating the SSU report, kindly uncheck the “Networking” option.
2. Please share the crash dump files related to the issue, along with the relevant Windows Event Viewer logs.
3. Please share the source from which the game was downloaded. If available, kindly provide the download link.
Thank you for your patience and cooperation. We look forward to your response so we can continue assisting you.
CM
CM_Intel
I hope you’re doing well.
I’m writing to follow up on our previous message regarding the information we requested to further investigate the issue you reported. At your convenience, please let us know if you were able to gather and share the requested details.
If you have any questions or encounter any difficulties, feel free to reach out—we’ll be happy to assist.
Thank you for your time and cooperation. We look forward to your update.
CM
CM_Intel
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
CM
