Intel® Arc™ Discrete Graphics
4042 Discussions
msi claw-a1mのクラッシュとパフォーマンスについて
KIC
I'm playing games on an MSI Claw A1M. I have the latest BIOS and graphics drivers, but I'm experiencing crashes during the opening of Monster Hunter Wilds and frame rates of only 10-20 frames per second in Resident Evil Requiem, making it unplayable. I'm especially experiencing problems with major titles. While optimizing the graphics drivers is essential, are there any settings I can adjust to play games?
Mike_Intel
Hello KIC,
  1. When did you start having this issue? Is it with the latest driver only or even with the older drivers?
  2. What are the troubleshooting steps that you tried before contacting us?
  3. For me to review the hardware and the driver installed, please help generate the SSU logs of your system. Kindly refer to the link below for the steps:
Michael L.
KIC
Thank you for your reply.
1. I purchased the game two days ago, so I'm unaware of any compatibility issues between the previous and current drivers.
2. I tried troubleshooting by reducing all game settings to low to minimize load and reinstalling the drivers, but there was no change.
3. I created a system SSU log.
Please see the attached file for reference.
Thank you for your assistance.
Mike_Intel
Hello KIC,
Thank you for the quick update.
Regarding your inquiry about settings and optimizing your device, kindly try the following steps:
  1. Update your BIOS to the latest version available. Contact MSI Support for instructions on this procedure.
  2. Install Intel® Arc™ Graphics Driver 32.0.101.8629. Find recommendations to prevent windows update driver rollbacks
  3. Set the user scenario in MSI Center M to Balanced Mode and enable Over Boost with the toggle selector (upper right corner) to enable optimized in-game performance. The Over Boost feature requires BIOS 108 or newer and a system restart when toggled. It is also suggested to have the OS in balanced mode while gaming.
Michael L.
Mike_Intel
Hello KIC,
Michael L.
KIC
ご連絡ありがとうございます。
教えて頂いた通り、デバイスの最適化を試みました。
1:BIOSを最新のバージョンに更新してください。この手順についてはMSIサポートまでお問い合わせください。
MSIで配信している最新バージョンにしました。
2:設置 Intel® Arc™グラフィックスドライバー32.0.101.8629。Windows Updateのドライバーロールバックを防ぐための推奨情報を見つけてください
上記の最新のドライバーへ更新しました。
3:MSI Center Mでユーザーシナリオをバランスモードに設定し、トグルセレクター(右上)でオーバーブーストを有効にすると、ゲーム内パフォーマンスを最適化できます。オーバーブースト機能はBIOS 108以降が必要で、切り替える際にはシステムの再起動が必要です。また、ゲーム中はOSをバランスモードにすることも推奨されています。
トルグセレクターがありません。
調べたとこと、BIOSの更新でトルグセレクターは廃止になっていました。
上記の通りに最適化をしましたが、症状は改善しませんでした。
開発陣営も当機で実際にテストしてみてはいかがでしょうか。
グラフィックドライバーの改善を待つ他ないと思っています。
BrenzL_Intel
Hello KIC,
I will do further research on this matter and post the response on this thread once it is available.
Brenz L.
BrenzL_Intel
Hello KIC,
After careful review, we have confirmed that your system is using integrated graphics only. As a result, the system does not meet the minimum requirements specified by the game developer.
Based on our assessment, the game falls outside the supported system requirements for your current configuration. We recommend reaching out to the game developer directly to inquire whether future support for the reported integrated GPU (iGPU) may be added.
As there are no further troubleshooting steps available on our end, this case will now be closed. If you have other concerns or require additional assistance, please submit a new support request, as this thread will no longer be monitored.
Brenz L.
