Intel® Arc™ Discrete Graphics
4126 Discussions
Minecraft FPS Stuck to 30
Asphenix
As the title Says Im Currently experiencing an annoying fps problem which makes my game get around 10-25 fps avg. and stuck at 30 FPS at some point  when Using Minecraft Shader(Basically something like RTX) and i have to close and re-open the whole session again to fix that which also closes servers and etc so me and my friends have to close-reopen the session over and over again which is quite annoying in long playing sessions...
Some information about my system:
+MOTHERBOARD
Manufacturer
ASUSTeK COMPUTER INC.
Model
PRIME H610M-R D4
+PROCESSOR
12th Gen Intel® Core™ i5-12400F
  • ManufacturerGenuineIntel
  • DescriptionIntel64 Family 6 Model 151 Stepping 5
  • Architecturex64
  • # of Cores6
  • # of Threads12
  • Processor Base Frequency2500 MHz
  • Current Voltage1.7
  • Level 2 Cache7680 Kb
  • Level 3 Cache18432 Kb
+GRAPHICS
Intel® Arc™ A750 Graphics
 Resolution1360 x 768
  • Refresh Rate - Current59 Hz
  • Refresh Rate - Maximum60 Hz
  • Refresh Rate - Minimum23 Hz
+MEMORY
16 GB
Hugo_Intel
Hello Asphenix
Thank you for posting on the Intel® ARC™ Graphics Communities.
In order to help with this issue, we would like to know the version of the game that you are running and if the issue only happens when using the mod that you mentioned, if not tested yet, test the latest version of the game and without any mod installed and check if the issue persists.
Also, please share with us a report from the Intel® System Support Utility so we can get you drivers and hardware configuration.
Hugo O.
Asphenix
My fps returns to normal when i switch Shaders off i tried differend Minecraft versions and Shaders and yet FPS thing still happens
and Shaders is Pretty popular and well known thing so i dont thing that has anything to do with it in the other hand i was not able to open report in Google and i got an error at google and i was not able to connet the website so heres the report
Asphenix
The issue seems to happen with most of the versions while using Shaders the fps returns normal when i Disable shaders i tried different versions of minecraft and shaders but problem did not solved it still happens and Shaders is an Well Known and Pretty Popular thing so problem seems to related with me and there is the report
Thanks for helping
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"01.16.2024"
Time:"00:00:23.4860016"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASUSTeK COMPUTER INC."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends Inc. 2212 , 12/13/2022"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"12th Gen Intel(R) Core(TM) i5-12400F , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"3.4"
Sound Card:"Realtek High Definition Audio"
System Manufacturer:"ASUS"
System Model:"System Product Name"
System SKU:"SKU"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Arc(TM) A750 Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Arc(TM) A750 Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Arc+A750+Graphics"
CoInstallers:"oem60.inf,iDG2_Client_FWU_w10_DS,Internal,Intel(R) Arc(TM) A750 Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdnd64.sys"
Driver Date:"12.21.2023 03:00 ÖÖ"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igdkmdnd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"31.0.101.5084"
INF:"oem60.inf"
INF Section:"iDG2_Client_FWU_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_56A1&SUBSYS_10218086&REV_08\6&2EB9C70&0&00080008"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"1360 X 768"
Scan Mode:"Noninterlaced"
Service Name:"igfxnd"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Arc(TM) A750 Graphics Family"
- "Memory"
Physical Memory (Available):"0,91 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15,82 GB"
- "BANK 0"
Capacity:"8 GB"
Channel:"Controller0-ChannelA-DIMM0"
Configured Clock Speed:"2133 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First position"
Manufacturer:"G Skill Intl"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"F4-3200C16-8GVKB"
Serial Number:"00000000"
Status:"Not Available"
Type:"Synchronous"
- "BANK 0"
Capacity:"8 GB"
Channel:"Controller1-ChannelA-DIMM0"
Form Factor:"DIMM"
Interleave Position:"Second position"
Type:"Synchronous"
- "Motherboard"
BIOS:"2212, ALASKA - 1072009"
Caption:"Anakart"
Chipset:"Not Available"
Date:"12.13.2022 03:00 ÖÖ"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"PRIME H610M-R D4"
Serial Number:"230317709400780"
Status:"OK"
Version:"Rev 1.xx"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "LogMeIn Hamachi Virtual Ethernet Adapter"
Caption:"LogMeIn Hamachi Virtual Ethernet Adapter"
CoInstallers:"Not Available"
Default IP Gateway:"2620:9b::1900:1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"01.15.2025 02:47 ÖS"
DHCP Lease Obtained:"01.16.2024 02:47 ÖS"
DHCP Server:"25.0.0.1"
Driver:"Hamdrv.sys"
Driver Date:"03.30.2015 12:00 ÖÖ"
Driver Path:"C:\Windows\system32\DRIVERS\Hamdrv.sys"
Driver Provider:"LogMeIn Inc."
Driver Version:"15.28.40.464"
Index:"0010"
INF:"oem30.inf"
INF Section:"Hamachi.ndi"
Installed:"Yes"
IP Address:"25.49.156.193;fe80::ed42:9cb0:fef2:3354;2620:9b::1931:9cc1"
IP Subnet:"255.0.0.0;64;64"
Last Reset:"01.13.2024 09:58 ÖÖ"
MAC Address:"7A:79:19:31:9C:C1"
Manufacturer:"LogMeIn Inc."
Net Connection ID:"Hamachi"
NetCfgInstanceId:"{E481E995-3223-41A8-8E15-ACB2CB69A497}"
PNP Device ID:"ROOT\NET\0000"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"LogMeIn Hamachi Virtual Ethernet Adapter"
Service Name:"Hamachi"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Bağlantı Katmanı Topolojisi Bulma Eşleyicisi G/Ç Sürücüsü:
Bağlantı Katmanı Topolojisi Bulma Yanıtlayıcısı:
İnternet Protokolü Sürüm 4 (TCP/IPv4):
İnternet Protokolü Sürüm 6 (TCP/IPv6):
Microsoft Ağları için Dosya ve Yazıcı Paylaşımı:
Microsoft Ağları için İstemci:
Microsoft LLDP Protokolü Sürücüsü:
- "Realtek PCIe GbE Family Controller"
Caption:"Realtek PCIe GbE Family Controller"
Default IP Gateway:"192.168.1.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"01.16.2024 11:44 ÖS"
DHCP Lease Obtained:"01.16.2024 10:44 ÖS"
DHCP Server:"192.168.1.1"
Driver:"rt640x64.sys"
Driver Date:"08.15.2023 12:00 ÖÖ"
Driver Path:"C:\Windows\system32\drivers\rt640x64.sys"
Driver Provider:"Realtek"
Driver Version:"10.68.815.2023"
Index:"0001"
INF:"oem36.inf"
INF Section:"RTL8168H.ndi.NT"
Installed:"Yes"
IP Address:"192.168.1.35;fe80::8209:6f95:8ba6:65e"
IP Subnet:"255.255.255.0;64"
MAC Address:"08:BF:B8:34:95:AC"
Manufacturer:"Realtek"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{8C1DA071-51ED-4F6D-AF26-AE276DF78F63}"
PNP Device ID:"PCI\VEN_10EC&DEV_8168&SUBSYS_86771043&REV_15\01000000684CE00000"
Power Management (Low Power):"Active: Yes, Enable: No"
Power Management (Wake On LAN):"Active: Yes, Enable: No"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Realtek PCIe GbE Family Controller"
Service Name:"rt640x64"
Status:"Enabled"
QoS Paket Zamanlayıcısı:
- "Settings"
*EEE:Enerji Tasarruflu Ethernet:"Devre Dışı Bırakıldı (0)"
*FlowControl:Akış Denetimi:"Devre Dışı Bırakıldı (0)"
*InterruptModeration:Hafifletmeyi Kes:"Devre Dışı Bırakıldı (0)"
*IPChecksumOffloadIPv4:IPv4 Boşaltmayı Sağla:"Devre Dışı Bırakıldı (0)"
*JumboPacket:Jumbo Çerçeve:"Devre Dışı Bırakıldı (1514)"
*LsoV2IPv4:Boşaltmayı Geniş Gönder v2 (IPv4):"Devre Dışı Bırakıldı (0)"
*LsoV2IPv6:Boşaltmayı Geniş Gönder v2 (IPv6):"Devre Dışı Bırakıldı (0)"
*ModernStandbyWoLMagicPacket:Wake on magic packet when system is in the S0ix power state:"Devre Dışı Bırakıldı (0)"
*NumRssQueues:En Fazla RSS Sırası Sayısı:"4 Sıra (4)"
*PMARPOffload:ARP Yük Boşaltma:"Devre Dışı Bırakıldı (0)"
*PMNSOffload:NS Yük Boşaltma:"Devre Dışı Bırakıldı (0)"
*PriorityVLANTag:Öncelik & VLAN:"Öncelik & VLAN Etkinleştirildi (3)"
*ReceiveBuffers:Arabellekleri Al:"512 (512)"
*RSS:Yan Ölçüyü Al:"Devre Dışı Bırakıldı (0)"
*SpeedDuplex:Hız & İkili:"Otomatik Görüşme (0)"
*TCPChecksumOffloadIPv4:TCP Boşaltmayı Sağla (IPv4):"Devre Dışı Bırakıldı (0)"
*TCPChecksumOffloadIPv6:TCP Boşaltmayı Sağla (IPv6):"Devre Dışı Bırakıldı (0)"
*TransmitBuffers:Arabellekleri İlet:"128 (128)"
*UDPChecksumOffloadIPv4:UDP Boşaltmayı Sağla (IPv4):"Devre Dışı Bırakıldı (0)"
*UDPChecksumOffloadIPv6:UDP Boşaltmayı Sağla (IPv6):"Devre Dışı Bırakıldı (0)"
*WakeOnMagicPacket:Sihirli Paket Eşleştirme Uyanması:"Etkinleştirildi (1)"
*WakeOnPattern:Desen eşleştirme uyanması:"Devre Dışı Bırakıldı (0)"
AdvancedEEE:Advanced EEE:"Devre Dışı Bırakıldı (0)"
AutoDisableGigabit:Gigabit’i (PowerSaving) Otomatik Olarak Devredışı Bırak:"Devre Dışı Bırakıldı (0)"
EnableGreenEthernet:Yeşil Ethernet:"Devre Dışı Bırakıldı (0)"
GigaLite:Gigabit Lite:"Devre Dışı Bırakıldı (0)"
PowerSavingMode:Power Saving Mode:"Devre Dışı Bırakıldı (0)"
RegVlanid:VLAN ID:"0 (0)"
S5WakeOnLan:Yerel Ağ Üzerinden Kapat:"Etkinleştirildi (1)"
WolShutdownLinkSpeed:WOL & Kapatma Bağlantı Hızı:"10 Mbps Önce (0)"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Internet Explorer,11.3636, Microsoft Edge,120.0"
Locale:"Türkiye"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 10 Pro"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"28,49 GB"
Physical Memory (Available):"0,93 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.19045 Build 19045"
Virtual Memory (Available):"3,08 GB"
Virtual Memory (Total):"44,37 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [9/8/2023]"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [9/8/2023]"
KB2467173:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [9/8/2023]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [9/8/2023]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB5011048:"Update [11/12/2023]"
KB5011071:"Update [9/27/2023]"
KB5014032:"Security Update [9/8/2022]"
KB5015684:"Update [9/8/2022]"
KB5016705:"Update [9/8/2022]"
KB5028380:"Update [9/4/2023]"
KB5029709:"Update [9/14/2023]"
KB5029923:"Update [9/14/2023]"
KB5031539:"Update [10/13/2023]"
KB5032392:"Update [11/16/2023]"
KB5032907:"Update [12/14/2023]"
KB5033918:"Update [1/11/2024]"
KB5034122:"Security Update [1/11/2024]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [9/8/2023]"
KB982573:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [9/8/2023]"
Microsoft ASP.NET Core 7.0.7 - Shared Framework (x64):".NET [10/18/2023]"
- "Processor"
- "12th Gen Intel(R) Core(TM) i5-12400F"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 151 Stepping 5"
- "Chipset Name":"12th Gen Intel(R) Core(TM) i5-12400F"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=12th+Gen++Core+i5+12400F"
CPU Speed:"2,5 GHz"
Current Voltage:"1.7 volts"
Driver:"Not Available"
Driver Date:"04.21.2009 12:00 ÖÖ"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.19041.3636"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"6 x 288 KB"
Level 2 Cache:"6 x 7680 KB"
Level 3 Cache:"18 MB"
Load:"12%"
Manufacturer:"GenuineIntel"
Model:"151"
Name:"12th Gen Intel(R) Core(TM) i5-12400F"
Number of Cores:"6"
Number of Cores Enabled:"6"
Number of Logical Processors:"12"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF00090675"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"5"
- "Storage"
- "KINGSTON SNV2S1000G"
Capablities:"Random Access, Supports Writing"
Caption:"KINGSTON SNV2S1000G"
Cylinder - Total:"121601"
Description:"Disk sürücüsü"
Driver Date:"06.21.2006 12:00 ÖÖ"
Error Code:"Device is working properly"
Firmware Revision:"SBM02103"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(Standart disk sürücüleri)"
Model:"KINGSTON SNV2S1000G"
Partitions:"4"
Physical Sector Size:"4096"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_KINGSTON_SNV2S10\5&35D1D170&0&000000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"1"
Sectors - Per Track:"63"
Sectors - Total:"1953520065"
Serial Number:"0000_0000_0000_0000_0026_B768_67DF_74D5."
Size – Available:"297,47 GB"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"31008255"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Yerel Sabit Disk"
File System:"NTFS"
Name:"Not Available"
Serial Number:"AEA324A2"
Size – Available:"91,2992782592773 GB"
Volume Dirty:"No"
- "D:"
Caption:"D:"
File System:"NTFS"
Serial Number:"327A899F"
Size – Available:"206,169700622559 GB"
Volume Dirty:"No"
...#SSU#...
Hugo_Intel
Hello Asphenix
Thank you for the information. In this case, there are a couple of general recommendations:
If the issue persists we wanted to let you know that mods can cause all types of issues with the game so we cannot commit to a specific outcome. To know the mod you are running please share a link to the mod you are using and let us know the version of the game that you are running, please note we can only support the latest version of the game so if not yet tested, use the latest version of the game.
Hugo O.
Asphenix
I Did DDU and Bios update and yet problem still happens...
Hugo_Intel
Hello Asphenix
We have not yet confirmed some important information from previous posts, please let us know if Resizable Bar is enabled on your system, also, share with us a link to the exact mode that you are using and share with us the exact game version that you are using.
Hugo O.
Asphenix
I have Resizable Bar ON Im Playing at 1.20.1 Version with Iris and Sodium
And Complementary Shaders - Reimagined
Hugo_Intel
Hello Asphenix
Based on the Minecraft website the latest version is 1.20.4, please update to the latest version and check if the same issue happens.
Hugo O.
Asphenix
Tried it and still happens but i found out when i go Borderless Fullscreen Mode my fps goes normal so it might be about focusing to game or game mode whatever something like that
Edit:Now it crasher randomly instead of  and in crash log it says
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (mmap) failed to map 2160066560 bytes for G1 virtual space
# Possible reasons:
# The system is out of physical RAM or swap space
# The process is running with CompressedOops enabled, and the Java Heap may be blocking the growth of the native heap
# Possible solutions:
# Reduce memory load on the system
# Increase physical memory or swap space
# Check if swap backing store is full
# Decrease Java heap size (-Xmx/-Xms)
# Decrease number of Java threads
# Decrease Java thread stack sizes (-Xss)
# Set larger code cache with -XX:ReservedCodeCacheSize=
# JVM is running with Zero Based Compressed Oops mode in which the Java heap is
# placed in the first 32GB address space. The Java Heap base address is the
# maximum limit for the native heap growth. Please use -XX:HeapBaseMinAddress
# to set the Java Heap base and to place the Java Heap above 32GB virtual address.
# This output file may be truncated or incomplete.
# Out of Memory Error (os_windows.cpp:3617), pid=5268, tid=13352
# JRE version: OpenJDK Runtime Environment Microsoft-8035246 (17.0.8+7) (build 17.0.8+7-LTS)
# Java VM: OpenJDK 64-Bit Server VM Microsoft-8035246 (17.0.8+7-LTS, mixed mode, tiered, compressed oops, compressed class ptrs, g1 gc, windows-amd64)
# No core dump will be written. Minidumps are not enabled by default on client versions of Windows
Command Line: -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xss1M -Djava.library.path=C:\Users\PC\curseforge\minecraft\Install\bin\14fc7cd04530164fad96b590c08e7e6823b2714c -Djna.tmpdir=C:\Users\PC\curseforge\minecraft\Install\bin\14fc7cd04530164fad96b590c08e7e6823b2714c -Dorg.lwjgl.system.SharedLibraryExtractPath=C:\Users\PC\curseforge\minecraft\Install\bin\14fc7cd04530164fad96b590c08e7e6823b2714c -Dio.netty.native.workdir=C:\Users\PC\curseforge\minecraft\Install\bin\14fc7cd04530164fad96b590c08e7e6823b2714c -Dminecraft.launcher.brand=minecraft-launcher -Dminecraft.launcher.version=2.15.23 -DFabricMcEmu= net.minecraft.client.main.Main -Xmx6144m -Xms256m -Dminecraft.applet.TargetDirectory=C:\Users\PC\curseforge\minecraft\Instances\B -Dfml.ignorePatchDiscrepancies=true -Dfml.ignoreInvalidMinecraftCertificates=true -Duser.language=en -Duser.country=US -DlibraryDirectory=C:\Users\PC\curseforge\minecraft\Install\libraries -Dlog4j.configurationFile=C:\Users\PC\curseforge\minecraft\Install\assets\log_configs\client-1.12.xml net.fabricmc.loader.impl.launch.knot.KnotClient --username Asphenix --version fabric-loader-0.15.6-1.20.1 --gameDir C:\Users\PC\curseforge\minecraft\Instances\B --assetsDir C:\Users\PC\curseforge\minecraft\Install\assets --assetIndex 5 --uuid 1c0a6378d139493ea4d1a866c41fa85a -3XM9bj35y8mMj1rMyPq10c72f6QwXHxVM --clientId NmMwODgzNWQtYTdkYy00MDEwLTljMjItMWYzNjc3MjI0MGRm --xuid 2535443300227395 --userType msa --versionType release --width 1360 --height 768 --quickPlayPath C:\Users\PC\curseforge\minecraft\Install\quickPlay\java\1705697081778.json
Host: 12th Gen Intel(R) Core(TM) i5-12400F, 12 cores, 15G, Windows 10 , 64 bit
Time: Sat Jan 20 00:42:20 2024 Türkiye Standart Saati elapsed time: 3458.833266 seconds (0d 0h 57m 38s)
Hugo_Intel
Hello Asphenix
To confirm if you set up the game at fullscreen there will be low performance and if you set it up at borderless windows mode there will be crahses, correct?
Hugo O.
Asphenix
If i play more than an hour the fps thing happens and if fps bug is happened if i stay in fullscreen i get 10-15 fps and if i go borderless i get to play for like 5-10 mins and get crash afterwards but this only happens after fps issue happens so i have no problem with fullscreen and borderless if fps issue did not happened which happens after an hour
Hugo_Intel
Hello Asphenix
Thank you for the information. Just to confirm, I understand this is the Java version of the game and not the Bedrock version correct? We will also, need a screenshot of your in-game graphics settings in case we need to test the game.
Hugo O.
Asphenix
Yeah i play at Java Version of Original Minecraft 1.20.1
Some people at Discord said it might happen bcz of JVM arguments,GPU incompatibility or Garbage Collection but idk if its true or not
Asphenix_2-1706040057449.pngAsphenix_3-1706040066775.pngAsphenix_4-1706040069983.pngAsphenix_5-1706040081284.png
Hugo_Intel
Hello Asphenix
We will continue to check this issue with our team, at the moment since the issue only happens when using mods we cannot commit to a specific outcome,however, once we have more information we will post back and let you know.
Hugo O.
Hugo_Intel
Hello Asphenix
I checked this issue with our team and taking into consideration that the problem only happens when using mods this will need to be reported to the mod developer, please contact the developer, and in case the want to look into this issue you can advise to contact us to the following links so we can help debugging the issue;
Hugo O.
Alex0072
It may be due to the integrated Intel Arc A750 graphics, which might struggle with demanding shaders. Upgrade to a dedicated GPU for better performance. Moreover, ensure your graphics drivers are up-to-date. Adjusting in-game settings, like render distance and shadow quality, can also help. In the end, monitor system temperatures to prevent thermal throttling, and allocate more RAM to Minecraft to enhance performance.
Asphenix
Now to think about the issue,this happens at most of the games; not just minecraft like it happened bunch of times before  (idk if it happens at all games) and just only crashed or game froze so this happens randomly and i didnt thinked abt it like there might be issue but now i think issue is not abt game or develpoers...
anyone know what might be issue or how can i fix?
Hugo_Intel
Hello Asphenix
As mentioned in our previous post, it would be better to get in touch with the developer of the mod for further support and to check if there might be compatibility issues, you can also refer them to the links we provided in our previous post so we can help in case they are interested in debugging this issue.
Please note we will no longer monitor this thread. If you need further assistance with any other issue, feel free to open a new topic.
HJugo O.
