Intel® Arc™ Discrete Graphics
4046 讨论
Mouthwashing white screen
Sandpiper
初学者
18,395 次查看
Me and the other users of Intel Arc GPUs have incountered the same problem in the game called "Mouthwashing", the first problem appears in the main menu: laying body on the bed is covered in some type of visual artifacts, firstly i thought that its just the game's graphic style, but soon I will know for sure that its not. After starting the game we are presented with opening cutscene after which the whole screen turns blue and then almost complitely white (important thing: the HUD, pause menu and invertory screen is not affected). after long and painful 20 minutes I finally played through the first minute of gameplay and was able to move (first moments of gameplay is based around some kind of controll deck and player needs to press some buttons there, but its quite hard when your screen is almost complitely white) I i figured something out. this "white screen" appears when you face the lightning source. When I walked away from all the monitores and stuff I was able to see the textures clearly and the "white screen" started to look more like colorful artifacts and dead pixels. My guess is that Intel gpus have a bad time working with some kind of lightning shader or some kind of ray tracing in this game. I've provided a screenshots for all of you to see. If you think you know how to deal with this problem I would really appreciate any help, I really just want to play the game and not reconsidering my life choises after buying Intel GPU
0 项奖励
1 解答
NormanS_Intel
主持人
15,747 次查看
Hello @Sandpiper, @filetburger, @papandbuddyg
Thank you for your patience. I'm pleased to inform you that our investigation indicates driver version 32.0.101.6732 provides a solution for the issue you've reported. I recommend updating your graphics driver to version 32.0.101.6732 (Latest) and letting us know the results. Please ensure you perform a clean installation using DDU to completely remove any remnants of the previous driver.
Norman S.
在原帖中查看解决方案
0 项奖励
14 回复数
DhannielM_Intel
主持人
18,204 次查看
Hi Sandpiper,
I have send you on email please check your inbox. Thanks
Dhanniel M.
0 项奖励
DhannielM_Intel
主持人
18,148 次查看
Hi Sandpiper,
First thanks for posting in the community, to further investigate this siutaion that you are encountering I would like to ask some few questions. Please see the following question below:
  1. Where did you download the game?
  2. What graphics driver version do you currently have?
  3. Can you tell me your Graphics Card model?
  4. Is this the first time it has happened, or has it happened before?
  5. Could you please share a screenshot of your game settings?
  6. Did you perform a clean installation when installing the driver?
  7. Have you tried rolling back the driver?
Also, to better understand your entire system information, please use the System Support Utility (SSU). This will generate a text file that compiles all your system information. You can follow this link for instructions and send the text file here. How to get the Intel® System Support Utility Logs on Windows
Dhanniel M.
0 项奖励
Sandpiper
初学者
18,109 次查看
Hello there! I'll list the answers below
1.The game was downloaded from Steam
2. Graphics Card driver version is 32.0.101.5768
3. Graphics Card model is Intel Arc A580 Challenger
4. It's the first time stuff like this happened to me with this Graphics Card
5.
6. Driver was installed correctly and no problems have accured through out this whole time
7. I didn't roll back the driver
The text file's atteched below
I'm not entirely sure that this problem lays in Graphics Card, but I just want to be sure
Thank you for your help
0 项奖励
papandbuddyg
初学者
18,116 次查看
i have the same issue as well i figured id also reply with my stuff to help out with the issue
1. steam
2. Driver Version: 32.0.101.6319
3. intel arc a580 sparkle oc
5. game settings is 2560x1440p with vsync off thats the only real settings
6. yes i have
7. yes i have as well
DhannielM_Intel
主持人
18,044 次查看
Hi Sandpiper,
Thanks for sharing this information with me, additionally, @papandbuddyg I got thanks for the information as well. Let me further investigate this graphics issue in the game
Dhanniel M.
0 项奖励
filetburger
初学者
17,694 次查看
Is there a fix for this available?
I got the same problem in the menu and even in game with lighting / bloom effects occuring.
The same goes for EA FC 25.
Temps are normal. Did the clean install of the drivers twice today.2475490_12.jpg2475490_8.jpg2475490_10.jpg2475490_11.jpgScreenshot 2024-12-21 204749.png
0 项奖励
filetburger
初学者
17,666 次查看
May be an issue with the unity engine in general?
0 项奖励
NormanS_Intel
主持人
15,748 次查看
Norman S.
0 项奖励
filetburger
初学者
15,681 次查看
You really did it! Thanks a lot guys!
0 项奖励
NormanS_Intel
主持人
15,651 次查看
Hello @filetburger
I appreciate your reply and am pleased to know that everything is functioning well for you. However, I am still awaiting a response from @Sandpiper.
Norman S.
0 项奖励
Sandpiper
初学者
15,632 次查看
It works! Thank you a lot guys
0 项奖励
NormanS_Intel
主持人
15,621 次查看
Hello Sandpiper,
Thank you for your reply; I'm pleased to hear that everything is functioning well, and you're most welcome. Please be assured that we acknowledge all reported issues.
I will now close this inquiry. Should you require further assistance, please feel free to submit a new question, as this thread will no longer be actively monitored.
Norman S.
0 项奖励
conate
初学者
14,907 次查看
The white screen after the intro in Mouthwashing points to a serious issue with Arc GPU compatibility. Even with updates, it’s still not fixed, which really affects user trust and gameplay. A quick and proper fix from Intel is needed.
0 项奖励
Sandpiper
初学者
14,881 次查看
You sure you have a latest driver version? After installing latest version on my a580 the "White Screen" problem disappeared
0 项奖励
回复
