Intel® Arc™ Discrete Graphics
4040 Discussions
OBS can't use AV1 on latest driver
垂垂
only x264(quicksync) can be selected
but there is an AV1(AOM/SVT) option on computers that are not arc gpu (even if it does not support av1 hardware decoding)
Andres_Intel
Hello 垂垂,
Thank you for posting on the Intel communities. I understand that you are not able to select AV1(AOM/SVT) option in OBS while using the Intel® Arc™ Graphics, I know it is very important for you to use this option, I will be more than happy to help you.
To understand this issue in a better way, please answer the following questions:
Andres P.
Andres_Intel
Hello 垂垂,
Were you able to run the Intel® SSU to know your system environment?
Andres P.
Andres_Intel
Hello 垂垂,
Andres P.
Andres_Intel
Hello 垂垂,
Before I close this thread, I want to let you know that this seems to be a situation that might occur in OBS. Refer to this link for more info: https://obsproject.com/forum/threads/intel-arc-av1-shenanigans-obs-29-beta-3-and-obs-29-0.163122/. The issue should be reported to the app developer.
For now, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
