Intel® Arc™ Discrete Graphics
4254 Discussions
Problem in GTA5
Petr_Bruzek
Hello, this is GTA5 online. In puddles of water a large square appears under the character see link.
https://www.youtube.com/watch?v=_PzURdHp6KM
Drivers: 31.0.101.4669
Used DDU in safe mode to change from nVidia to Intel.
SSU attached
Andres_Intel
Hello Petr_Bruzek,
Thank you for posting on the Intel communities. I see that you are having graphics corruption issues in puddles of water with your Intel® Arc™ A770 Graphics when playing Grand Theft Auto 5, I will be happy to assist you.
Thank you for sharing the file with your system information, that helps me a lot to provide you with the recommendation below:
Please let me know the results.
Andres P.
Petr_Bruzek
Hello, Andres,
-Images of the setup attached.
-Yes, it happens in story mode.
- The problem started right after I bought the ARC. I've owned it for about 4 days? + -My first drivers were 4669.
-Drivers 4669 via DDU deleted and new 4672 installed.
-Bios flashed to version 7D25v1D
Result still the same. Still the same problem in GTA5. Below I send a new video (the problem is better to see + video taken for a change from story mode)
Thanks for the advice and the effort to solve it. I believe the problem will be fixed.
Regards, Petr
https://youtu.be/5N3op4vFr_w
NickN
I would like to confirm the addressed issue.
The issue happens whenever GTAOnline & GTAV weather condition is "Raining".
I had been testing ARC A770 (8GB) on GTAOnline @ 31.0.101.4669 for awhile now, the major issue in this driver version on GTAOnline I've found is the rain puddle mentioned, and the increased frequency for game stuttering and freezing (not responding) - typically happens on fast ground movements.
I am currently testing GTAOnline @ 31.0.101.4672, but I have yet to encounter a raining weather. However, I did noticed FPS being lowered in this version from a 130-170fps to 100-120fps without changing any settings. Will, update once I have done enough sampling or create a thread if I've found any major issue.
A Casual 2000hr GTAOnline player.
Andres_Intel
Hello everyone,
Thank you for your response, and all the information provided, it has been really helpful.
I will start with an investigation of the issue and as soon I have further information I will let you know.
Andres P.
Andres_Intel
Hello everyone,
Thank you for your time and patience.
We still working on the investigation and now we are trying to replicate the issue, as soon I have the results I will let you know.
Andres P.
Petr_Bruzek
Hello Andres,
thank you for your reply. I will look forward to it.
Petr
Andres_Intel
Hello everyone,
Thank you for your time.
We have been working on the investigation, the issue was replicated with driver 31.0.101.4672 but with the latest driver 31.0.101.4826, the problem seems to be solved.
Please update the graphics driver to version 31.0.101.4826, for guidance, How to Install an Intel® Graphics Driver in Windows® 10 & Windows 11.
Let me know the results.
Andres P.
Petr_Bruzek
Hello Andres,
I have now tested and the problem is solved! Thank you thank you thank you thank you!!!! Perfect work!!!
Thanks a lot. I really appreciate it.
Greetings from Czech Republic and have a great time
Petr
Andres_Intel
Hello Petr_Bruzek,
Thank you for your answer and for completing all the steps.
I am happy to hear that the issue get solved after updating the graphics driver to version 31.0.101.4826. For now, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
