Intel® Arc™ Discrete Graphics
4126 Discussions
Problem is in the Adobe Primer Pro
Bob131
The time line slows down when editing video through Opencl acceleration
I tried installing different versions of the program and drivers, nothing helped, there are no such problems on the old rx 550 graphics card.
if I turn on hardware acceleration, the video will play normally, but the load will be on the processor.
my build
Rayzen & 3700x
B580 Maxun icraft
DDR4 64 GB
B550 MSI GEMING PLUS
GameMax 700w modular
Windows 11 25H2
Intel® Graphics Driver 32.0.101.8136
Bob131
I wanted to use the Intel ark b580 graphics card for video editing, is the problem with it or the drivers, will the intel arc b580 ever work properly in adobe premiere pro
Bob131
When Intel organizes support for this GPU for video editing programs, a year has already passed, and you are not doing anything, then why position the board as for content creators, none of the current video editing programs work fine on the Intel arc B580 board
JeanetteC_Intel
Hello Bob131,
Thank you for posting this issue, OpenCL acceleration on the Intel Arc B580. I understand your frustration with the timeline performance in video editing applications.
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information below:
  1. Can you confirm that the software (Adobe Premiere Pro) previously works fine with your old RX 550 graphics cards but having the issue with freshly installed app (Adobe Premiere Pro)?
  2. Can you confirm that the Above 4G Decoding and/or Re-Size BAR Support is enabled inside BIOS setup?
  3. Provide your power supply unit (PSU).
  4. Please share your SSU log file so we could check your system configuration that will be used for further investigation.
JeanetteC.
Bob131
Hello, yes, Re bar and Above 4G Decoding are enabled, I tested other video cards and there were no problems with them, my Gamemax 700w Modurar RGB power supply, help me solve the problems with premiere pro video editing software why does the time line slow down the video playback terribly, I attached the SSU file
KennethB_Intel
Hello Bob131,
To help isolate the issue, I recommend performing a clean driver installation using the Display Driver Uninstaller (DDU) tool. This will ensure that any remnants of previous drivers are completely removed before installing the latest version.
After running DDU, please reinstall the latest Intel Graphics Driver 32.0.101.8247 (Latest). If the issue persists, kindly try installing an older version of the driver to see if there is any improvement in performance. Additionally, please let us know which drivers you have tried for testing.
Please let me know the results after performing these steps.
Thank you.
Kenneth B.
JeanetteC_Intel
Hello Bob131,
Did you get a chance to review the previous post?
Please let us know if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello Bob131,
Since I haven't received any response from you recently, I will go ahead and close this thread.
Sincerely,
JeanetteC.
Sammertimesaga
The new Summertime Saga Mods update looks amazing The story and graphics just keep getting better! If you’re looking for the best working mods to make the game even more fun.
