Intel® Arc™ Discrete Graphics
3646 Diskussionen
Question about colors
Remlin379
Neuer Beitragender I
5.428Aufrufe
It might not be related to the gpu itself but rather to windows but I noticed some weird things with colors. First of all, even though I have set 32bit bit depth, windows settings still shows only 8 (on all 3 displays). I'm also pretty sure that on my TV that I'm using as a monitor the colors are better when I use it without the PC. The most interesting thing is that when going into windows safe mode, the colors are way more vivid and after using DDU, for some time before windows installs it's own drivers, the colors on my TFT display are actually better than on IPS, but as soon as I install intel drivers and reboot, they get washed out (and windows aero stops working).
Am I doing something wrong? Because even on GTX card my screens were never as beautiful as on ARC without drivers.
Beschriftungen (1)
13 Antworten
Andres_Intel
Mitarbeiter
5.383Aufrufe
Hello Remlin379,
Thank you for posting on the Intel communities. I see that you are having color depth issues with your Intel® Arc™ A770 Graphics it still shows at 8bit, I will be more than happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
Andres_Intel
Mitarbeiter
5.348Aufrufe
Hello Remlin379,
Were you able to run the report of the Intel® SSU to check your system information?
Andres P.
Remlin379
5.343Aufrufe
Sorry, I was pretty busy this week so I was unable to login here
Here's the SSU report
My monitors are:
DP - acer kg251qdbmiipx (main)
DP - Asus BE24A (I think it's colors are the best)
HDMI - TCL TCL 43C649 43" TV
The GPU is ASRock Arc A770 Phantom Gaming 8GB
Additionaly, it's likely not the arc's fault, that the colors are washed out, because I noticed similar thing with gtx, but I don't remember ever uninstalling nvidia's drivers so I don't know if colors were better without them like now without intel's. The problem might also be caused by a quirky main monitor, and the TV being incompatible with arc, since the second of my monitors looks quite okay.
Andres_Intel
Mitarbeiter
5.318Aufrufe
Hello Remlin379,
Thank you for your response and for sharing all the requested information.
We always recommend having the system up to date for a better performance on the graphics card please follow the steps below and let me know the results:
Andres P.
Remlin379
5.301Aufrufe
I use DDU every update, i hate the fact that i have to do this for better experience but I do
As for the bios update, I'm not sure how could it impact gpu when all the changes are cpu related, but I'll do this when I'll have time
Andres_Intel
Mitarbeiter
5.250Aufrufe
Hello Remlin379,
Thank you for your answer.
I will wait for you to complete the BIOS update, the reason why it is important to do it is because it may improve the performance, stability, and compatibility of the graphics card.
Please as soon as you have the results let me know.
Andres P.
Remlin379
5.227Aufrufe
I updated the bios, nothing really changed
Andres_Intel
Mitarbeiter
5.222Aufrufe
Hello Remlin379,
Thank you for your reply, that helps a lot.
This week we released a new graphics driver, before we proceed with the next steps, please follow the steps below:
Keep me informed of the results.
Andres P.
Remlin379
5.210Aufrufe
We  both know that won't help. This thread was more of a question if you knew why colors are better without drivers than looking for a fix anyway. Thanks for the help, you can close this thread and go finally fix Arc control for example.
Andres_Intel
Mitarbeiter
5.190Aufrufe
Hello Remlin379,
Thank you for your response.
I understand you want to close this thread, before doing that, to answer your question, I will start with an investiation, and as soon I have the information I will let you know
Andres P.
Andres_Intel
Mitarbeiter
5.172Aufrufe
Hello Remlin379,
Before closing this thread, I want to let you know that I have been working on the investigation of your question. In this case, Windows does not report the 8-bits used for the Alpha channel (transparency) that is part of True Color 32-bit, therefore in RGB mode, we have 8-bit for each Red + Green + Blue (24-bit + 8-bit Alpha channel).
When in Windows we see 'True Color - 32-bit' this is the equivalent to seeing in Graphics Settings = RGB mode 8-bit (in other words: it is expected to see Windows reporting 8-bit mode when using 32-bit, is the same).
As for the color differences you see, you should be working on each monitor setting and calibration in conjunction with Arc Control color settings (for example trying different Hue and Saturation values) and for the TV check if there is any option in the TV to change colors to full range.
Let me know if you have further questions.
Andres P.
Remlin379
5.169Aufrufe
Thank you, that's everything. I guess I have to start calibrating then : )
Andres_Intel
Mitarbeiter
5.160Aufrufe
Hello Remlin379,
Happy to hear that I have answered your question, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
Antworten
