Intel® Arc™ Discrete Graphics
4242 Discussions
Random reboot when playing X4
gwertheim
  1. What is the graphics driver you are using
    • 32.0.101.8826 Fresh install
  2. Tell us the name of the game or application and where to obtain it (Steam, Epic, etc.)
    • X4: Foundations by Egosoft
  3. Provide us with the Intel SSU report from your system.
    • Intel SSU in text doc
    • Lian Li A3 ATX case
      5900x
      Intel Arc B580
      Corsair SF1000 PSU
      Asus Tuf B550m motherboard
      WD Black SN850X OS drive
      WD Black SN770 storage drive
      Nocuta D15 cooler
  4. Tell us the steps to reproduce the issue (this is very important!).
    • Started happening on the 19th
    • Most times when this happened, I was going in a elevator to a different area of the station
    • This has happened many times in a day, each time I had HWinfo confirming it's not a temp issue
    • One of my co workers mentioned I might want to check Windows Event Viewer, there might be a crash report
    • The computer has rebooted from a bugcheck. The bugcheck was: 0x00000116 (0xffff86856f3e7010, 0xfffff8076ae225b0, 0x0000000000000000, 0x000000000000000d). A dump was saved in: C:\WINDOWS\Minidump\062226-4890-01.dmp. Report Id: 3e0079c8-efd1-4213-a1ab-c3d8f24057f5.
Let me know if you need anymore info or the dmp file from one of the crashes
Shane_Intel
Hello gwertheim,
Thank you for waiting, as per my discussion with my team since the issue persists after we exhausted all the troubleshooting and, on our end, we haven't experienced the issue during simulation.
I would highly suggest reaching out to the game developer for further troubleshooting regarding the concern.
With this I will be closing the thread as there is no more help needed on our end.
Thank you and have a wonderful case.
Shane E.
gwertheim
Fresh install and another game crash
Shane_Intel
Hello gwertheim,
Thank you for the update, I apologize if the issue still persists. I will be checking this with my team to further discuss the issue.
I will provide an update as soon as I have one.
Shane E.
Shane_Intel
Hello gwertheim,
Shane E.
gwertheim
Marry-Joseph22
A 0x116 VIDEO_TDR_FAILURE bugcheck usually indicates that Windows timed out waiting for the graphics driver or GPU to recover. Since it started recently, I'd recommend using DDU to completely remove the current Intel graphics driver and then reinstall either 32.0.101.8826 or, if available, the latest driver. Also disable any GPU overclock/undervolt, update your motherboard BIOS and chipset drivers, and check whether the issue occurs only in X4: Foundations or in other GPU-intensive games. If it's reproducible in the same scenario (e.g., elevators/station transitions), that information along with the minidump will be useful for Intel to investigate.
