Intel® Arc™ Discrete Graphics
4333 Discussions
Random reboot when playing X4
gwertheim
  1. What is the graphics driver you are using
    • 32.0.101.8826 Fresh install
  2. Tell us the name of the game or application and where to obtain it (Steam, Epic, etc.)
    • X4: Foundations by Egosoft
  3. Provide us with the Intel SSU report from your system.
    • Intel SSU in text doc
    • Lian Li A3 ATX case
      5900x
      Intel Arc B580
      Corsair SF1000 PSU
      Asus Tuf B550m motherboard
      WD Black SN850X OS drive
      WD Black SN770 storage drive
      Nocuta D15 cooler
  4. Tell us the steps to reproduce the issue (this is very important!).
    • Started happening on the 19th
    • Most times when this happened, I was going in a elevator to a different area of the station
    • This has happened many times in a day, each time I had HWinfo confirming it's not a temp issue
    • One of my co workers mentioned I might want to check Windows Event Viewer, there might be a crash report
    • The computer has rebooted from a bugcheck. The bugcheck was: 0x00000116 (0xffff86856f3e7010, 0xfffff8076ae225b0, 0x0000000000000000, 0x000000000000000d). A dump was saved in: C:\WINDOWS\Minidump\062226-4890-01.dmp. Report Id: 3e0079c8-efd1-4213-a1ab-c3d8f24057f5.
Let me know if you need anymore info or the dmp file from one of the crashes
Shane_Intel
Hello gwertheim,
Thank you for waiting, as per my discussion with my team since the issue persists after we exhausted all the troubleshooting and, on our end, we haven't experienced the issue during simulation.
I would highly suggest reaching out to the game developer for further troubleshooting regarding the concern.
With this I will be closing the thread as there is no more help needed on our end.
Thank you and have a wonderful case.
Shane E.
Shane_Intel
Hello gwertheim,
Thank you for reaching out to us via community. To further assist you with your concern and to provide you with the best possible support, could you please provide the following information?
  • Have you tried to use DDU to install the latest graphics driver?
  • Have you tried to roll back the driver?
  • Can you confirm if the Re-Bar is enabled in the BIOS?
  • Can you salso share a screenshot of the game settings?
I look forward to your response. Thank you and have a nice day!
Shane E.
gwertheim
    • Right after I made this post, so far so good
    • I picked up the game last week after not playing it for 2 yrs so I would not have a reference to how it worked on old drivers. I'll try that out if the problem continues
  • Can you also share a screenshot of the game settings?
Shane_Intel
Hello gwertheim,
Thank you for the update, and for providing the requested information.
I just wanted to clarify; you mentioned that after doing a DDU the system is good. May I know if the issue persisted or your system now run perfectly fine?
In will look forward to your response.
Shane E.
gwertheim
Hello Shane,
It is still an issue.
Let me know if you need anymore info from me
Shane_Intel
Hello gwertheim,
Thank you for the clarification, since the issue still persists, I will be coordinating the concern with my team to further investigate the issue. Rest assured that as soon as an update is provided, I will inform you immediately.
Thank you for understanding and cooperation.
Shane E.
Shane_Intel
Hello gwertheim,
Thank you for patiently waiting for our update, as discussed with my team, would it be possible for you to check the following.
  1. Can you check for overheating? Ensure that your GPU is not overheating. Check the temperatures using monitoring software and clean any dust from the fans and heatsinks.
  2. Can you run a hardware diagnostic? You may use the hardware diagnostics tools provided by your system manufacturer to check for any hardware issues.
  3. Have you tried to test RAM? Run the Windows Memory Diagnostics tool to check for memory errors. Faulty RAM can sometimes cause these types of crashes.
  4. Have you tried to disable hardware acceleration: If you are using applications that utilize hardware acceleration (like web browsers or video players), try disabling this feature.
  5. Also, if possible, test the old available driver version for testing?
I look forward for your response. Thank you and have a wonderful day!
Shane E.
gwertheim
    • GPU isn't even close to overheating
    • No hardware issues
    • I have never had this issue before with any video playing while I play any game. This time I only had the game and HWiNFO running
    • Current driver is Version: 32.0.101.8860 which came out June 30th. I updated it before I did my latest round of testing. I did not have any crashes or any issues I was experiencing over the last week or two. One thing I would suggest is to find a way to save your previous fan curves and other settings when you do a clean install of the latest driver
Let me know if you need more info
Shane_Intel
Hello gwertheim,
Thank you for the prompt response and for providing the result of the additional troubleshooting.
You mentioned that you are not having an issue with the driver 32.0.101.8860, is there anything else I can assist with?
Shane E.
gwertheim
I spoke too soon.
I happened again. Temps were within normal range as everything froze up
Shane_Intel
Hello gwertheim,
Shane E.
gwertheim
Next time I play, I will record the data from HWiNFO to see if it will give you any bit of information on what my system is like before it crashes.
gwertheim
Spent 5 hrs playing without doing anything else but recording the data from HWiNFO. I tried watching a YouTube video on my other monitor and it crashed. Not sure if that helps at all
gwertheim
I was playing today and it happened when I had no other applications open.
so who knows what triggers the shutdown.
I am at the point where I am keeping the card to help you guys track down the problem. Once that's done I am getting something else and my B580 is going in my media server that I am trying to put together.
Let me know what you want to do next
gwertheim
I tried to update to the latest driver.
Anything you can suggest?
gwertheim
Tried to update to the latest drivers but It's still crashing.
I am not sure what damage these crashes are doing to my computer.
I need to pull the card, I am sorry we couldn't find the source of this problem
Shane_Intel
Hello gwertheim,
Thank you for patiently waiting for our update and for providing more information regarding the concern.
We have tried to replicate the issue on our end with the same system configuration that you have. We played the game for more than an hour and left the system open as well as the game for 24 hours. Also, played YouTube while playing for more than 5 hours and we didn't encounter any issues.
  • Can you try performing OS reinstallation to further isolate the issue?
  • Also, can you please try using the graphics card on another known working system?
We will wait for your response and the outcome of the additional provided troubleshooting.
Shane E.
gwertheim
Hello Shane,
It's too bad you couldn't replicate my situation. I do not have this issue with any other game.
I am unable to do a full OS reinstall for at least the next month and a half due to my summer work hours.
My only other computer is a media server that is running a 4790k. Not sure if it is even worth putting the b580 in it.
I am sorry but I am unable to dedicate the time needed to do what's requested until September.
gwertheim
Looks like there was some damage done by the constant reboots.
Will be doing a fresh install when I get home from work.
Shane_Intel
Hello gwertheim,
I understand the situation and I apologize for the inconvenience.
Do let me know the result of the OS installation once done.
I will wait for your update.
Shane E.
gwertheim
OS reinstall and game install is done
