Intel® Arc™ Discrete Graphics
Render
Istiak75
Does intel arc a750 supports 3ds max2020 vray 5 renders?
Andres_Intel
Hello Istiak75,
Thank you for posting on the Intel communities.
I understand how important is for you to know if the Intel® Arc™ A750 Graphics supports 3ds max2020, Vray 5 renders.
Please answer the following questions to have a better understanding of the situation:
  • Are 3ds max2020 and Vray 5 software to create 3d models? Likes houses and more.
I was checking some info about it, but I just want to make sure, that I understand your question. You want to know if the graphics card supports this kind of software, is that correct?
Andres P.
Istiak75
Yes. 3ds Max is used to model, animate, photorealistic designs, and complex scenes for film and TV, games, and design visualization projects. and v-ray 5 is the one of the render engine real time ray tracing and render high-quality 3d visualizations. It is widely used in architectural visualization.
Andres_Intel
Hello Istiak75,
Thank you for the clarification.
I will investigate this, to provide you with more accurate information, as soon I have further information I will let you know.
Andres P.
Andres_Intel
Hello Istiak75,
As per our investigation what we recommend is to contact the developers of the apps to check if the software supports the graphics card, so we will close this thread. If you need any additional information or issues related to these apps and the graphics, please submit a new question as this thread will no longer be monitored.
Andres P.
