Intel® Arc™ Discrete Graphics
3555 Discussions
Some games crash with the last driver - Arc 770 LE
Mascready
EDIT : DDU to the latest stable driver seemed to solve the problem - Beta driver made it worse
Hello.
I found issue with some games like many other users of the Arcs.
Here is a list :
Farming Simulator 22
Euro Truck Simulator 2
Cyberpunk 2077
Spyro Remastered
Every time the log mentions a disconnect of the DX peripheral. For exemple :
Warning: Device removed! DXGI_ERROR code: 0x887A0006
Platform :
AMD Ryzen 5800X on X570 mb
32 Gb of RAM at 3600 MHz
My card is overclocked with a 23 enhancement factor - + 85mV
228W power limit and 90°C Temp limit
Fan curve adjusted
Labels (2)
Hugo_Intel
Hello Mascready
Thank you for posting on the Intel® ARC™ Graphics communities. I am sorry you are experiencing random crashes on your system with Intel® Arc™ Graphics.
I see you edited the post and mentioned that issues seem resolved after a clean installation of the latest stable driver using DDU, so we would like to know if you still need further assistance.
In case the crashes still happen, monitor the system and right after a crash occurs, create a log file using the DxDiag tool and attach it to your response.
Hugo O.
Hugo_Intel
Hello Mascready
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello Mascready
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
justin678
Thanks for sharing your experience, Mascready. It's helpful to see the specific games affected and the DXGI error code. I also appreciate the detailed specs and OC settings — those can definitely be a factor. Glad to hear DDU and the latest stable driver improved things; it seems the beta driver may still have some instability issues. Hopefully Intel continues refining support for Arc cards. Anyone else here seeing similar crashes with these titles?
