Hi 544545,
Thank you for reaching out to the Intel Community Forum. I appreciate your message and want to assure you that I’m here to assist with your concern. To better understand the issue and provide accurate support, could you please share the following details:
- What is the wattage and model of your PSU?
- What are your CPU and GPU temperatures during gameplay? Is there any thermal throttling on either component?
- Is XMP/DOCP enabled for your RAM? Can you confirm the actual memory speeds using CPU-Z?
- Did you perform a clean driver installation using DDU (Display Driver Uninstaller) before updating/installing the current graphics driver?
- Are you running any monitoring software (e.g., MSI Afterburner) that might interfere?
- Which Windows power plan are you using (High Performance or Balanced)?
- Is there any Intel software installed (Intel Graphics Command Center, Intel Graphics Software)? Are any performance overlays or optimizations enabled?
- What are your exact in-game graphics settings? If possible, please provide screenshots.
- Have you tested other games? How does performance compare in other demanding titles (especially DX11)? Have you tried different resolution scaling (e.g., 1440p downscaled to 1080p)? Are you experiencing similar issues in other Unreal Engine 4 games (PUBG uses this engine)?
- Does the issue occur in both online matches and offline training modes?
Please also install the latest graphics driver for your Intel® Arc A580: version 32.0.101.8250. Perform a clean installation using DDU (Display Driver Uninstaller) before updating the driver.
Additionally, to help us better understand your system configuration, we kindly request that you share the Intel® System Support Utility (SSU) logs from your device. These logs contain important details about your hardware and software environment, which are crucial for troubleshooting.
Steps to generate SSU logs:
- Download and run the Intel® SSU application.
- The tool will generate a text file containing your system information.
- Refer to this guide for detailed instructions: Help Guide for the Intel® System Support Utility
- Once completed, please attach the generated file to your response.
If you have any additional questions or need further assistance, please don’t hesitate to contact us.
Kent Russel P.
