- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
oops, I gave the same screenshots twice, this time I give the ones that were supposed to be a different region of the map
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
@megalordgier14 You know, there is an edit function you can use which will allow you to minimize the number of posts you are making.
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
and what does this have to do with graphical errors (and I uninstalled Copilot immediately)
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
My "tagline" is not a solution or instructions for you to follow. It is merely my opinion of the day, and is often intended to be humorous, although sometime it is used to make a statement.
The point of my post to you was that mutiple single line responses were poor forum etiquette and that you should have used "edit" to modify your post.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
