Intel® Arc™ Discrete Graphics
4128 Discussions
Tom Clancy's Ghost Recon
megalordgier14
while shooting in some places on the map, part of the terrain disappears, and after the fire stops, it magically reappears
megalordgier14
and not only when shooting
megalordgier14
and another region where I have graphical errors
megalordgier14
oops, I gave the same screenshots twice, this time I give the ones that were supposed to be a different region of the map
AlHill
@megalordgier14   You know, there is an edit function you can use which will allow you to minimize the number of posts you are making.
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
megalordgier14
and what does this have to do with graphical errors (and I uninstalled Copilot immediately)
AlHill
My "tagline" is not a solution or instructions for you to follow.  It is merely my opinion of the day, and is often intended to be humorous, although sometime it is used to make a statement.
The point of my post to you was that mutiple single line responses were poor forum etiquette and that you should have used "edit" to modify your post.
